Parkliner hinges rusting! - Page 4 - Fiberglass RV
Old 08-28-2015, 07:15 AM   #43
frank_a's Avatar
Trailer: 2012 ParkLiner #006
Just a re-cap here. Looks like I need some 316 SS washers in 3/8 size, and a spary can of Boeshield T9. My door works fine, it's the darn rust that harms my aesthetic sensitivities. It's good to know about the Husky u-joints too. Hopefully I'll not need them. Once I get a chance to get at this I WILL report back. Thanks all!
Frank
2012 ParkLiner #006
Old 08-30-2015, 02:25 PM   #44
deryk's Avatar
New Jersey
I ordered a bottle of it for mine as well...and to squirt some into door locks as well.
deryk
Old 09-04-2015, 09:19 AM   #45
Trailer: Shopping
The hinges were done in this way because he was hanging a curved door on a curved trailer side so accurate alignment was not the solution. Molding flats in the two parts would have allowed a wider choice of higher quality stainless fittings.
rdcastle is offline   Reply With Quote
Old 09-04-2015, 09:22 AM   #46
deryk's Avatar
New Jersey
or if he had some custom stainless steel parts made exactly like what was being used.
deryk
Old 09-04-2015, 09:06 PM   #47
DJO
DJO's Avatar
Trailer: Parkliner #40 something
door not lining up
The upper left corner of our door is digging into the door frame. The upper hinge is not properly supporting the door. Looks like I may need to replace some parts here.
DJO is offline   Reply With Quote
Old 09-05-2015, 03:34 AM   #48
Raz
Raz's Avatar
Vermont
Molding flats can have it's issues as well if the hinges are not set correctly. I ran into that on my Trillium. This is a clever solution with a poor choice of parts. Has anyone removed a hinge and looked for a manufacturer? From the picture it looks like a plated strap hinge that they welded the universal joint to. Since Kobalt is a Lowes brand I wonder if the hinges came from there as well. If you can get the same parts, you could make a spare should the hinge fail down the road. Not perfect but better than nothing. Good luck, Raz
Old 09-05-2015, 06:37 PM   #49
Trailer: Parkliner; 2013 Honda Ridgeline
Sounds like a plan. I will do the same. A friend of mine has a Harbor Freight shop lift which I plan to use to lift and hold the door while I replace the washers and lube the hinges.
Bill
BillC is offline   Reply With Quote
Old 09-05-2015, 06:43 PM   #50
When I visited Parkliner last year for installation of my awning, the techs noted a similar problem with my door. They removed the door and upper hinge and moved the hinge a bit to the right by re drilling the holes. The door lined up fine after that.
Bill
Old 09-07-2015, 09:27 PM   #51
DJO
DJO's Avatar
Thanks Bill. So I've got one option here.
Old 09-08-2015, 05:12 AM   #52
Trailer: ParkLiner
Virginia
Bill
Same with mine.
I think what happened with mine is my site was extremely sloped, so I had to use 3 2x6's plus crank it all the way up. A big gust of wind hit me and ripped the door out of my hand when I was getting out of the trailer. I think the stress was enough to twist the door and get it out of alignment.
I added some washers which made the door usable until Parkliner fixed it.
Huck is online now   Reply With Quote
Old 09-15-2015, 03:30 PM   #53
Trailer: Shopping
Frank, Check out the hinges that Scamp uses. They are also "articulated" to accommodate the curved door and trailer surfaces.
Old 09-18-2015, 05:20 PM   #54
DJO
DJO's Avatar
Nice!!
Old 09-18-2015, 05:23 PM   #55
frank_a's Avatar
Thanks Robert, but no problems with the hinges other than aesthetics. I got my can of T-9, just need some SS washers. Heck, even SS can rust. I got small SS clasps for my stinky slinky holder last year and they're rusting already!
Thanks,
Frank
2012 ParkLiner #006
Old 07-01-2019, 01:04 PM   #56
Trailer: Parkliner
Virginia
Ok, let's reopen this door hinge wound. What an Achilles heel this issue is for the PL!
On my 2016 Parkliner, the door hinges can't keep paint on the hinges. It flakes off in short order whenever I repaint it. I even took it to the guy who fixes our cars when deer or bears run into us (a good bit around here) and asked him about it. He said he didn't think he could get conventional paint to adhere to those hinges.
As a first alternative option, he suggested trying the product, "Flex Seal." It comes in white.
I find it an interesting possibility. At this point, what do I have to lose?
What do y'all think?
John
2016 Parkliner
iamjiwjr is offline   Reply With Quote
parkliner
Wanted: Boler Hinges - Looking for a pair of Boler Entry Door Hinges idiotsniff Parts: Buy | Sell | Trade 6 01-13-2012 11:02 AM
Trillium windows hinges Legacy Posts Problem Solving | Owners Helping Owners 1 04-29-2003 04:23 PM
hinges - for Ches Legacy Posts Problem Solving | Owners Helping Owners 1 04-26-2003 12:59 PM
Hinges,catches,etc. resource Legacy Posts Care and Feeding of Molded Fiberglass Trailers 3 10-02-2002 03:21 PM
