ParkLiner shower drain - kinked hose - Fiberglass RV
Old 06-16-2014, 12:37 PM   #1
frank_a's Avatar
Trailer: 2012 ParkLiner #006
Any of you other ParkLiner owners had a kinked shower drain hose? I'd be interested in how you fixed it, what the i.d. of the hose is, what you used for the repair/replacement, etc.
It was previously a minor thing I hoped to have done with other warranty work in May at the factory, but I got bopped out of that long planned trip a week before we were taking 006 down. I have other problems now as a result, but would sure like to fix this drain hose (kinked on both ends, one end real bad) soon, as I can'tr even wash the floor in there without standing water!
Thanks for any help, suggestions and/or advice.
Frank
2012 ParkLiner #006
Old 06-16-2014, 04:05 PM   #2
deryk's Avatar
New Jersey
Pictures! No, no problem with the shower. How is it kinked?
deryk
Old 06-16-2014, 04:27 PM   #3
frank_a's Avatar
Best I can do. Can't get both ends in at once, and only took the one pic. I think ya can see what I mean!
2012 ParkLiner #006
Old 06-16-2014, 05:02 PM   #4
Can you put a barbed 45 degree plastic fitting into the line? Maybe one at each end. Most home centers sell them and they are not expensive
Old 06-16-2014, 05:36 PM   #5
deryk's Avatar
New Jersey
Yeah a 45' elbow or add some more hose to Mae a better bend....I guess I should check mine.....it pumps right out though.
deryk
Old 06-16-2014, 05:48 PM   #6
frank_a's Avatar
The "thing" it hooks to under the shower swivels, so with one right angle "thing" this should work.
Frank
2012 ParkLiner #006
Old 06-16-2014, 06:06 PM   #7
If the end swivels more than likely the hose is too long. The other fix is the auto parts store carries springs that go around the hose.
http://mackexperts.com/Products/admi...39528514_L.jpg
Old 06-16-2014, 06:39 PM   #8
Paul O.'s Avatar
Trailer: '04 Scamp 19D, TV:Tacoma 4.0L 4door, SB
45 degree would do it with better flow than 90 degree.
Old 06-16-2014, 07:05 PM   #9
deryk's Avatar
New Jersey
steve I doubt the hose is too long...if it was they could have done a more graceful curve and no bending of the hose....like the idea of the spring though!
deryk
Old 06-16-2014, 07:14 PM   #10
deryk's Avatar
New Jersey
Oh and I took a look at mine, no sharp bend they seem to have used a longer piece of hose and can only see 1 end where the sump is, the other goes into the fiberglass heading back to my grey water tank.
deryk
Old 06-16-2014, 07:30 PM   #11
Paul O.'s Avatar
I might as well share my newbie experience with a kinked hose. Filling my fresh water tank from a bucket worked OK, but it seemed to take the water slowly. The vent tube was not clogged by mud wasps, all else seemed fine, so what gives? Then, when I was doing something else under the bench where the tank is, I felt where the vent hose is attached to the underside with a clip and found that it was kinked, or actually squeezed. It did pass some air, but not enough. After ten years the plastic hose took a set, but it relaxed after I removed it from the clip, enough for a nice fast fill, finally working as expected.
Old 06-17-2014, 05:06 PM   #12
frank_a's Avatar
Here's what I did for now. I don't like the right angle, but it's better than what I had. It's easy to disassemble and play with, so more to come, but for now, I like it. I think the main problem is the placement of the pump, so may have the folks at ParkLiner revisit it when 006 heads south.
By the way, the pic with clamps was fuzzy, so I used the good pics. It's clamped securely.
Frank
2012 ParkLiner #006
Old 06-21-2014, 05:56 PM   #13
accrete's Avatar
Trailer: Chevy AWD Van Conversion
Astoria Oregon
Lightbulb
I see you have a temporary fix...i modded mine a while back as i wanted to be able to drain directly (before) the pump and into a bucket while dispersed camping at times (bio soap and water ok to water plants with in some areas we camp in)... Here is my fix/mod with parts from home depot:
Cheers,
Thom
Blogging from the WET! Coast of Oregon
Bed, Bath, & Beyond...
2010 Chevy Express 1500 AWD Van
Archive: Parkliner #35 build thread
accrete is offline   Reply With Quote
Old 06-21-2014, 06:26 PM   #14
frank_a's Avatar
Cheers,
Thom
Very nice Thom, I like it. I don't have that original fitting I don't think, but too late to look right now. Mosquitoes are out for blood (8:30 here). I bought some 45 degree fittings and new clamps yesterday. Maybe I'll pick up a few new things, and do that. Great idea, thanks!
Frank
2012 ParkLiner #006
parkliner
Hose Buddy --For sewer hose Kevin K General Chat 5 12-09-2012 07:37 PM
Drain hose (sink) specs and availability? Darrell O Plumbing | Systems and Fixtures 3 09-07-2012 07:10 PM
Shower Drain? Christi V. Plumbing | Systems and Fixtures 26 11-02-2010 10:17 PM
Replace sink drain hose 13' Trillium Barrie Bochoff Problem Solving | Owners Helping Owners 5 07-20-2010 08:48 AM
Trailer shower drain question? Randya Problem Solving | Owners Helping Owners 13 10-09-2008 05:07 AM
