Parkliner Tire Rub issues? - Page 10 - Fiberglass RV
Old 05-02-2013, 12:21 PM   #127
accrete's Avatar
Trailer: Chevy AWD Van Conversion
Astoria Oregon
As an FYI... i ended up at a local tire Centre and had two tire pros look for solutions (they are also a certified dexter dealer/repair Centre) they said the easiest fix is a tire swap... They test installed a LTT 185R14 8 ply with an 1870 load rating that gave at least an additional 1/2” more clearance than what is now on there.
Blogging from the WET! Coast of Oregon
Bed, Bath, & Beyond...
2010 Chevy Express 1500 AWD Van
Archive: Parkliner #35 build thread
accrete is offline   Reply With Quote
Old 05-02-2013, 12:28 PM   #128
Trailer: FunFinder
Thom,
If you are going to swap tires, see my earlier post regarding this. Might be a good op to "up the quality" of chosen tire.
george
gmw photos is offline   Reply With Quote
Old 05-02-2013, 12:29 PM   #129
accrete's Avatar
Astoria Oregon
Here is a better shot after they took wheel off... Street side
Old 05-02-2013, 12:59 PM   #130
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Originally Posted by Birmingham1 View Post
(my trailer was several days late, which is why I ended up waiting on it...in fact, I helped clean it to speed things along the day I picked it up.)
My trailer was only hours late, and while they worked feverishly to get it done for me, I too helped out in the cleaning of it and a couple other small things. They were putting in a good effort, so I had no problem helping out at all. Folks from Vermont picked their 19 up just the day before and were quite impressed after seeing the readiness of mine, that it was done in the time it was.
Glad to see PL is taking care of the issue. That certainly is a tight clearance, though equates to minimal wasted space inside.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 05-02-2013, 01:24 PM   #131
accrete's Avatar
Astoria Oregon
Question
Originally Posted by gmw photos View Post
...Might be a good op to "up the quality" of chosen tire.
Factory stock tire:
205/D14 Bias Ply - 6 ply with 1760lb cap
Possible solution tried as mentioned:
185/r14 Light Truck Radial - 8 ply with 1874lb cap
I'm not a tire guy, but the possible solution looks to be "up" in quality than factory stock?
Old 05-02-2013, 01:31 PM   #132
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
In my opinion, putting an LT tire on is not an automatic upgrade, and in this case could be a mistake. LT tires have more flexible sidewalls than ST's, which may only aggravate the problem here.
I also have a "bias" for bias-ply in trailer tires, so think the type chosen correct for the application...one more bit of attention to detail for which Parkliner should be congratulated.
But I'm sure we're about to find out that I'm in the minority here as to my type-of-tire opinions!
Francesca
Old 05-02-2013, 01:43 PM   #133
accrete's Avatar
Astoria Oregon
Who knows?!
Though here in Oregon you can see many trailers with LT tires... Especially boat trailers.
But we are a strange lot & like or came too
Old 05-02-2013, 02:02 PM   #134
Ice-breaker's Avatar
If it was my trailer that was suffering from this issue, I would want to assure myself that the proposed solution is in fact a long-term solution. Given that many suspension systems will tend to "ride a bit lower" as the years go by, I would be a little wary of any solution that provides the minimum amount of clearance necessary at the present time (such as a slightly smaller tire). For me, I would be thinking in terms of adding a spacer between the frame and the axle to give both immediate and long-term clearance.
Ice-breaker is offline   Reply With Quote
Old 05-02-2013, 02:26 PM   #135
Trailer: Looking At Options
Louisiana
I am not a tire expert so read this with that in mind.
The following two tires have some good reviews with trailer-folk. I believe both are Load Range D and spec'd at 25.6" diameter with 1874lbs rating at 65psi.
Kumho 857 185R14
Hankook RA-08 185R14
This 25.6" diameter is approximately 1/2 inch smaller in diameter (based on specifications) than the Hi-Run tires that Chandler has been shipping with the ParkLiner. Can you trust the specifications? Maybe not. It appears that manufacturers are not held tightly to the specifications as Chandler has found a disturbing variance in the diameter of the Hi-Run tires that he currently has on hand, with some being closer to 1 inch over the specification. That might explain the tire rubbing with a group of trailers shipped out around the same time with tires from possibly the same shipment.
Anyway the above tires give more clearance and may be the solution if it turns out to be a problem with inconsistencies in tire diameter. If Kumho or Hankook has better manufacturing tolerances, you may even be able to go up to their 195R14 which is approximately the same diameter as the Hi-Run tires.
If another manufacturer has tighter manufacturing tolerances, you might be able to use another 205/75/14 as that size has worked for ParkLiner in the past.
Again, I am not an expert with tires so please verify the above specifications and by all means, talk with an expert that knows tires, rims, ratings, psi, load, etc.!
Mark
Mark McMorris is offline   Reply With Quote
Old 05-02-2013, 02:46 PM   #136
Who knows?!
Some of us Oregonians that have been towing a Travel Trailer for a number of years will only use ST tires. ST tires are built for trailers, Light Truck tires are built for mostly for pick up trucks. Where's similarity?
Old 05-02-2013, 02:56 PM   #137
What would the manufacturer know about tires??
Old 05-02-2013, 03:29 PM   #138
Trailer: FunFinder
Factory stock tire:
the following is my opinion.
radial tire:
runs cooler
has less rolling resistance
.....in the case of the Kumho 857:
has slightly higher load capacity
has a higher speed rating
is a tire that is designed AND marketed by Kumho to be SPECIFICALLY suited to both trailer and commercial vehicle use ( see their worlrdwide website )
And so, again, my opinion, the suggested tire is an improvement in every single performance category. It's downside is that it might cost an additional $20 to $30 per tire.
EDIT: info on the Kumho 857 tire is also on the kumhousa site
Old 05-02-2013, 04:17 PM   #139
Is there more than one "Kumho 857", perhaps in sizes other than the 14's mentioned?
I ask because according to this link, the Kumho 857 14" radial is for trailer use only, which makes it pretty much an ST whether it says so on the sidewall or not.
It's also not a commercial tire, since it lacks the UTQG rating required for such a designation.
Francesca
Old 05-02-2013, 04:19 PM   #140
Dave raises a VERY important point. Lots of ways to temporarily fix the issue by changing tires but for how long is that really going to be the fix? How many years of use will it be before the trailer starts to sag down as they all eventually start to do - depending on the mileage and road conditions the trailer has faced, 1 inch of additional clearance could vanish pretty fast. Then what? Trailers off warranty and your left holding the bag for a more expensive fix that perhaps should have been done originally.
My experience with trailer tires is that I would much rather use radial tires specifically designed for a trailer than for a light truck so would not be very happy customer if the solution to a problem was to use LT tires only.
parkliner
WA: Parkliner Thomas G. Referrals: Molded Fiberglass Trailers 19 04-15-2013 09:37 PM
Looking for a Parkliner Jomoflymo General Chat 29 03-02-2013 07:12 PM
Parkliner WaltP General Chat 70 11-08-2012 05:54 PM
Parkliner, Anyone? GingerB Hi, I am.... 6 04-25-2012 06:56 AM
Something going on with ParkLiner? harryjhere General Chat 32 11-17-2011 02:27 PM
