Parkliner Tire Rub issues? - Page 18 - Fiberglass RV
Old 08-17-2013, 04:50 PM   #239
Trailer: Parkliner
Alabama
Knowing what I know now I would have taken more pictures of that stack of frames than I would of Marisa Miller.
That's a lie. But I would have taken many pictures.
Birmingham1 is offline   Reply With Quote
Old 08-17-2013, 05:01 PM   #240
Brian B-P's Avatar
Originally Posted by Birmingham1 View Post
The frame of the trailer has beams, front to back. The axle tube is basically used as a left to right support beam in the middle of the trailer.
This is the abnormal feature of this design. I'm pretty sure if you contacted Dexter and asked them if this is okay, they would say that it is not.
To accomplish that, they made cut-outs across the width of the trailer in each of the front-to-back beams.
Okay, but did they cut out only the L-shaped (angle iron) beams in the middle, or did they cut out the big (1.5" wide by probably 3" high) main frame beams on the sides? It appears that the angles pieces in the middle are lower than the frame rails, because the angles are of course under the floor, and yet the floor is mounted at the bottom (rather than the top) of the frame rails; the result is that the angles are lower than the frame and need to be cut around the axle tube. Again, a typical manufacturer would not use longitudinal (front-to-back) floor supports.
Old 08-17-2013, 05:06 PM   #241
My 2 cent opinion. Axle alignment is measured from the center of the ball to some point on the outer edge of the axle, preferably but not necessarily to the center of the spindle. This is how we did big cargo trailers, center of the kingpin to a pointed tool that centered on the spindle. Many manufacturers use a jig or fixture to align parts that are to be welded together. I believe if this is the case with the Parkliner frames, if that fixture is a little off, then the axle alignment could be off of its correct position. Another idea; how were the molds made for the trailer body, could it be they were hand made and the left and right wheel wells are not exactly the same size and shape, or the body is not perfectly aligned on the frame when bolted down, resulting in a variance of clearance between the well and tires from one side to another. I have encountered incorrect alignment of welded parts on big trucks, and many of these parts get out there before someone catches the error. Just my opinion of a possible explanation, but a good alignment check will have to be done to narrow down the problem.
mary and bob is online now   Reply With Quote
Old 08-17-2013, 05:53 PM   #242
cpaharley2008's Avatar
Who is Marisa Miller?
Jim
Never in doubt, often wrong
Old 08-17-2013, 06:06 PM   #243
LindaK's Avatar
Trailer: Chinook
I was wondering the same thing. Glad you asked!
Linda
Linda
LindaK is offline   Reply With Quote
Old 08-17-2013, 06:36 PM   #244
You guys lead sheltered lives, even I know who Marisa Miller is. Careful when you open up this website... your eyes might bleed: Marisa Miller
Old 08-17-2013, 06:59 PM   #245
LindaK's Avatar
Trailer: Chinook
There we go getting off topic again! I don't think anyone will mind this time, though!
Old 08-17-2013, 07:46 PM   #246
I thought she may have been the welder these guys were complaining about
Jim
Old 08-17-2013, 07:48 PM   #247
carlkeigley's Avatar
NE Oklahoma
Never heard of her.
Old 08-17-2013, 07:49 PM   #248
Trailer: FunFinder
I too had to do a yahoo search for Miss Miller. I must be getting old......
gmw photos is offline   Reply With Quote
Old 08-17-2013, 07:54 PM   #249
I went to the site, and I still don't know who she is.
Old 08-17-2013, 07:57 PM   #250
Glenn, she's a Victoria's Secret model. Now, back to the original topic. I just thought pointing a website of Ms. Miller y'all would be rubbing your eyes... and this thread title is about "Rub Issues." Hey, I can spin anything...
Old 08-17-2013, 08:37 PM   #251
Trailer: 1980 Burro
Originally Posted by accrete View Post
i realize this next bit is not to scientific
I can fit my thumb between the street side tread and wheel well, but can only fit my pinky (thickness) between tread and well on curbside... so there is a difference.
With the 205's i couldn't even fit my pinky in there!
I have not read all the posts, but if I understand correctly the tires rub on the inside of the wheelwells and there is enough room at the outside of the wheelwells. If that is the case, how about using wheel spacers, like in the link below.
Wheel Spacers and Wheel Spacer Parts at JCWhitney.com
Eibach Wheel Spacer at Auto Parts Warehouse
Andy B is offline   Reply With Quote
Old 08-17-2013, 10:22 PM   #252
Mike Magee's Avatar
Trailer: Li'l Hauley
Yeah, forget Victoria's Secret; let's stay on topic... "Parkliner's Secret."
Hey, those wheel spacers sound interesting. What about it, PL owners? Could they help? It would be less expensive than two new tires, or moving or changing the axle.
About frame building, I bet PL is farming that out. I do know that Snoozy has frames built for them; they get them in all complete and attach their FG bodies. It seems sensible and common for a small startup to farm out some fabrication. But some knowledge of the farmed-out work is still needed, to ensure that it is done appropriately.
How to prepare Tofu
Step 2: grill some meat
parkliner
WA: Parkliner Thomas G. Referrals: Molded Fiberglass Trailers 19 04-15-2013 09:37 PM
Looking for a Parkliner Jomoflymo General Chat 29 03-02-2013 07:12 PM
Parkliner WaltP General Chat 70 11-08-2012 05:54 PM
Parkliner, Anyone? GingerB Hi, I am.... 6 04-25-2012 06:56 AM
Something going on with ParkLiner? harryjhere General Chat 32 11-17-2011 02:27 PM
