Parkliner Tire Rub issues? - Page 6 - Fiberglass RV
Old 04-30-2013, 08:15 PM   #71
Trailer: Parkliner
Alabama
Originally Posted by accrete View Post
Mark, Cameron will know your hull number.
As an FYI, mine was finished late in the day on Tuesday April 9th as #35
I am likely #37 then, as I picked it up on April 27th. I would just guess they built one additional unit between those dates.
Birmingham1 is offline   Reply With Quote
Old 04-30-2013, 08:36 PM   #72
accrete's Avatar
Trailer: Chevy AWD Van Conversion
Astoria Oregon
on tires/wheels...
we have 205/75/r14 in load range C with max cap @ 1760lbs.
I was unable to find much else in 14" size.
But in 13" i found load range D with 2" less overall size, which would give ~1" more clearance?? with a max capacity of 1610lbs. Still well above what any of us would have in our rigs (i'm at 2400lbs fully loaded at scales). But then i wonder if we would have to change brake assym also. Too much thinking...gonna chill with Cari, PopCorn, and SciFi.
Blogging from the WET! Coast of Oregon
Bed, Bath, & Beyond...
2010 Chevy Express 1500 AWD Van
Archive: Parkliner #35 build thread
accrete is offline   Reply With Quote
Old 04-30-2013, 09:23 PM   #73
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
I know from my association with the four wheel drive crowd, whole articles have been researched and written about the "real world" tire sizes and what is printed on the sidewall in such publications as Peterson's Four Wheel Drive and Sport Utility, Four Wheeler, JP magazine, and others. Between manufacturers and even different line-ups from the same manufacturer, there is a vast variance in the actual tire size and what is stamped into the sidewall. It should be criminal, as tire rubbing causes damage and safety issues. Things look good on paper, but when one can not rely on a "standard" of a size, things go awry. I wonder if something changed when disc brakes were replaced by drum units?
Old 04-30-2013, 09:30 PM   #74
Trailer: Looking At Options
Louisiana
Mark, Thom, and Brian;
Do all of you have HI-RUN ST 205/75/D14 tires on your ParkLiner? Is it possible that these tires are out of specification? Regarding your axle, I believe ParkLiner changed from FlexRide axles to Dexter axles at some point in production. Do you know what brand axle you have?
Tim,
What brand of tires is on your ParkLiner? Since your unit is a bit older, I am assuming your ParkLiner has a FlexRide axle. Is that correct?
Mark
Mark McMorris is offline   Reply With Quote
Old 04-30-2013, 09:36 PM   #75
Mike Magee's Avatar
Trailer: Li'l Hauley
for Francesca
I'm just as curious as anyone, but probably have more time than many to follow these interesting threads.
In "normal folks time", it's been a mere 24 hours. I try to bear in mind that such people probably have other things to attend to as well, such as having an actual life!
Francesca
Francesca, I came across this graphic just today. And when I saw the post you made, it seemed like perfect timing.
How to prepare Tofu
Step 2: grill some meat
Old 05-01-2013, 05:09 AM   #76
Trailer: Parkliner
Alabama
Tim,
Mark
Yes on HI-RUN ST 205/75/D14.
Yes on Dexter axle.
Old 05-01-2013, 05:13 AM   #77
Trailer: Parkliner
Alabama
on tires/wheels...
I really hope the solution isn't going to a 13" tire. The ground clearance is fairly low already and going lower doesn't seem like a step in the right direction.
Old 05-01-2013, 06:16 AM   #78
Trailer: '07 Scamp 16' SD
Wisconsin
Luckily, wheel size has little to do with tire size.
Ok, I apologize for the snarky comment, looks like it's going to be one of those days
glennco is offline   Reply With Quote
Old 05-01-2013, 06:44 AM   #79
Trailer: Parkliner
Alabama
Are you saying that going to a smaller combination to increase the clearance to avoid the rubbing won't decrease the ground clearance? If so, please explain!
Old 05-01-2013, 06:46 AM   #80
Mike Magee's Avatar
I think the solution they come up with will involve moving the axle. Either down or back, or both. Asking folks to accept smaller tires (and tire lower load capacity) does not seem sensible, especially since the problem is likely to worsen as the torsion axles age.
How to prepare Tofu
Old 05-01-2013, 06:58 AM   #81
Tim Wood's Avatar
Trailer: Class B for now
NY
Tim,
Mark
Mark, I also have Hi-Run tires and I do have the flexride axle.
Old 05-01-2013, 07:09 AM   #82
Brian M. in NY's Avatar
Trailer: 2013 ParkLiner
Upstate New York
Tim,
Mark
Yes on the above - HI-RUN ST 205/75/D14 and Dexter axle.
Brian M.
Always remember you're unique, just like everyone else.
Brian M. in NY is offline   Reply With Quote
Old 05-01-2013, 09:09 AM   #83
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
Just checked... it is welded in 10 points and looks a part of the frame/trailer. nicely done...but not coming out easy!
I wonder how they adjust them? Pull out the guts? Replace? just random ponderings that don't mean a thing either way It'll get done. I'll do some reading just for fun before watching some SciFi with Cari.
The angle on a Dexter axle arm is set at the factory and cannot be adjusted. To change it you have to replace it.
Looks to me that there just isn't enough room in the wheel well for the size of the tire installed.
But as the Spanke family motto goes "We may be wrong, but we're never in doubt."
Spanke
Trilliums Rock!
Old 05-01-2013, 09:12 AM   #84
accrete's Avatar
Astoria Oregon
I gotta remember i'm rubbing elbows with a bunch of easterners...you guys get the jump on me with your early rising and yes the SciFi night was good. We can hardly wait to hit the theater for the new Star Trek.
Yuppers:
and though i don't know the model number of axle though i would imagine it is the same as Brian's #34 and Mark's #37.
(Post script note...i just now saw the above post by Spanke, must have posted as i was composing this thought: )
I remember reading over at the ExpeditionPortal.com forum about a guy that had some adjustments made to his dexter by the manufacturer at time of order, something to do with making the trailing arm's angle greater so it came with more ground clearance...i have no idea if that is an available post-delivery type adjustment or not.
Thom
parkliner
WA: Parkliner Thomas G. Referrals: Molded Fiberglass Trailers 19 04-15-2013 09:37 PM
Looking for a Parkliner Jomoflymo General Chat 29 03-02-2013 07:12 PM
Parkliner WaltP General Chat 70 11-08-2012 05:54 PM
Parkliner, Anyone? GingerB Hi, I am.... 6 04-25-2012 06:56 AM
Something going on with ParkLiner? harryjhere General Chat 32 11-17-2011 02:27 PM
