08-22-2013, 05:05 PM
#281
Trailer: Parkliner
Alabama
Is there anyone on this thread/site/forum who is a fiberglass repair guru?
I would really like to go down the road of expanding the wheel wells on my unit, but I don't really know the impacts to the overall integrity of the structure if I do that. It appears to my untrained eye, that the wheel wells are part of the basic support due to their overall thickness...if I have someone who doesn't understand fiberglass trailers go cutting on that, it seems like I could risk ruining the whole unit.
I could try a boat repair shop, but I am not sure they would have enough knowledge to know how to proceed.
Is Parkliner really the only source who can ultimately answer this question?
08-22-2013, 05:13 PM
#283
Mark, there is Oliver in TN. They are experts.
08-22-2013, 05:19 PM
#284
Trailer: Parkliner
Alabama
Do you know if they do repair to non-Oliver units?
08-22-2013, 05:23 PM
#285
Don't know, thought it would be worth an ask since it's not too far from you.
08-22-2013, 05:28 PM
#286
Mark,
going off memory here, but i think snoozy said on the forum here they would at one time. A further drive for you, but it might be a plan B for you. Best of luck.
08-22-2013, 05:29 PM
#287
Trailer: Parkliner
Alabama
I appreciate the tip. I just checked out their website and sent them a note!
08-22-2013, 05:34 PM
#288
If you dont get a response, Robert a member of the forum here, said try his email robertpartee@olivertechnologies.com
I don't want to side track this thread so I better back out, Good luck.
08-22-2013, 06:19 PM
#289
Trailer: Parkliner
Alabama
Still the same thread for sure. I am just trying another angle on fixing the rubbing issues.
08-22-2013, 11:33 PM
#290
Trailer: Chevy AWD Van Conversion
Astoria Oregon
Cari & i've been down at a river camping since last weekend...
As of this post i've received no reply from Cameron/Chandler/Parkliner on what they plan to do for our PL#35's ongoing tire rub issue. I will certainly report in here once they share any ideas.
Thom
08-23-2013, 12:38 AM
#291
Trailer: 2010 Scamp 16
Originally Posted by Ice-breaker
Another question I would want resolved is whether 5 or 10 yrs down the road when your axle begins to wear and some sagging occurs (happens to all of us), will the tire rub issue reappear at that time? I feel the same as Brian when he said, "it seems like there isn't enough margin for reasonably expected variations".
In one of the earlier post I thought I read that an owner had 4 or 5 large guys from the tire store stand on the floor over the axle, moving the tire up from load increased clearance. Not an absolute duplication of a worn axle but might be a reassuring indicator of tire position as axle rubbers age and trailer sags.
Sorry just not willing to dig back through 20 pages to find a page and post number.
08-23-2013, 07:13 AM
#292
Trailer: '98 BURRO 17WB
Delaware
Accrete's post #150 on page 11, Roger. I doubt if revisiting the ephemera of observation is going to improve on Brian's conclusion.
jack
08-23-2013, 09:14 AM
#293
Delaware
The prediction of a future "sweet spot" in the orientation of a torsion arm reminds me of the "Are You Being Served?" universal response to the problem of fit in off-the-rack suits for men: "It'll ride up with wear." No alterations necessary. The difficulty of grasping such straws, except in humorous relief, is immense.
jack
08-23-2013, 04:45 PM
#294
Good, but how did they simulate the growth in overall diameter of the tire due to the speed of rotation? Oh, right, missed that detail...
Also, the trailer weight plus a thousand pounds of added static load seems likely to be less than the dynamic load of two thousand pounds of trailer going over a significant bump.
I probably wouldn't think of every factor that would affect clearance if I were designing a trailer from scratch, but it's easier to spot them with hindsight. Apparently there's a reason most trailers have a bunch of space around the tire. "Learn from the mistakes of others. You can’t live long enough to make them all yourself."
- common saying, perhaps attributable to Eleanor Roosevelt
08-23-2013, 06:25 PM
#295
Originally Posted by Brian B-P
... "Learn from the mistakes of others. You can’t live long enough to make them all yourself."
Me like, will add to my collection, right by "If I can't make it right, I guess I'll just make it adjustable" - anon
It did seem like from that ad hoc test sag at least might not make problem worse once dealt with in current configuration.
Innovation is often painful process of having to make your own mistakes, I wish the company and the customers that support that innovation the best of luck in finding a good solution.
Now I'm off to see if HD has an oval drill bit that drills slotted holes, tired of the darn things not lining up after I drill both parts.
08-23-2013, 06:45 PM
#296
You jest, but there are at least two different designs of drill press rigs which make a square hole in a single pass. I wouldn't be shocked if someone made oval holes... although of course not with an oval bit!
But seriously... drill with a plunge router, shift it one direction after plunging all the way through and voilà: oval hole.
I remember one of the major auto manufacturers proudly announced (now many years ago) that a new model was their first which didn't have oval bolt holes on the front fenders because they had reached new heights of precision and bolt-sized round holes actually lined up well enough that they could put the fenders on.
08-23-2013, 06:55 PM
#297
Trailer: 1984 19' scamp
Kansas
End mill. It's not exact good on the bearings.
08-26-2013, 10:58 AM
#298
In addition to GPJ's post and #297 above, here is 8-22 update for further reading if interested.
http://www.fiberglassrv.com/forums/f...tml#post412876
Originally Posted by frank_a
I guess not everyone is reading these threads. Cameron said "As for the customers, the warranty process went as follows: Send in your pictures. Take your ParkLiner to the nearest tire shop. We will ship them the correct tires, and then cover the costs."
So to my mind, the issue is resolved.
All my best to you.
Frank
08-26-2013, 11:32 AM
#299
Jared; nice work there. I've got an old Timken bench top milling machine, haven't used it since I bought it, got it along with an old Atlas lathe.
08-26-2013, 11:35 AM
#300
looks like someone is building a steam powered bike?
Jim
Never in doubt, often wrong
