Parkliner Tire Rub issues? - Page 17 - Fiberglass RV
Old 09-21-2013, 02:59 PM   #321
Brian M. in NY's Avatar
Trailer: 2013 ParkLiner
Upstate New York
[QUOTE=Birmingham1;419657]My door has the same issue. I don't use the lock on the handle as it's worthless. The deadbolt, which is an option I did get, does seem to keep the door secure. I think the only proper way to fix the door would be to use a completely different set of hinges that didn't have any flex to them. Since the deadbolt is a sufficient backup, that fix is lower on my list./QUOTE]
FYI, I removed both strike plates and using a file and Dremel tool removed about a sixteenth of an inch of material from the bottom of each. Now I don't have to pry up on the corner of the door to get them to latch. I tried to deepen the holes for the latch and deadbolts as well but as the screws for the belly band run through the center, all I did was ruin the edge on my chisel.
Brian M.
Always remember you're unique, just like everyone else.
Brian M. in NY is offline   Reply With Quote
Old 09-21-2013, 03:37 PM   #322
Trailer: Parkliner
Alabama
If you just lock the handle, can you open your door by wiggling it in the frame?
Mine bolt and latch fine, but the door has so much play on the hinges that it can be opened in less than a second if only the handle is locked.
Birmingham1 is offline   Reply With Quote
Old 09-21-2013, 04:11 PM   #323
Alabama's Avatar
Trailer: Previous 2012 Park Liner, New Parkliner Ordered
Alabama
Hey Birmingham1,
I am having problems with my battery/converter. Previous posts indicate that you may have had the same problem. I am ready to contact the BBB also. I may have met you. Did you happen to stop by and look at my camper north of Birmingham? Not sure if you are the same person or not. If so, do you mind getting my cell from DC and call me?
Alabama is offline   Reply With Quote
Old 09-21-2013, 04:13 PM   #324
Brian B-P's Avatar
Originally Posted by Donna D. View Post
Call them, they have an 800 number. Or maybe sending an email from THEIR website? Contact Us...
Calling makes sense. Since they don't seem to publish an e-mail address, this web form may be the only way to send a message without using something like Facebook or Twitter.
How have owners been trying to contact Parkliner?
AND, they have a Facebook page. Use the power of Social media to get a response?
Right, the "power" of social media... which means that with too many ways to communicate, many companies ignore the universally available ones and instead play around with some poorly functional junk that requires me to use an account. I tried contacting Parkliner long ago through Facebook - they don't handle that properly, either.
Old 09-21-2013, 04:16 PM   #325
Upstate New York
Sure can, but until I modified the strike plates, I couldn't even throw the dead bold until I placed my cane under the corner of the door and levered the whole door upward. Way too much play in the hinges. I asked ParkLiner if there was any way to adjust the hinges but, as usual, no response. I expect that the wheel well modification will cost me about $1000 when I pick up my PL on Monday. For now, my personal door lock modification is free and doing the job. Hopefully, the door won't sag further over time and cost additional $$$.
Brian M.
Old 09-21-2013, 04:25 PM   #326
accrete's Avatar
Trailer: Chevy AWD Van Conversion
Astoria Oregon
...Thom, you are so good at blazing the trail for the rest of us! I respect your opinions and I always look forward to your posts.
Thanks Mark, and for the record... it might have been weeks or months before i recognized any tire rub issues on our #35 if i hadn't read of your situation. ; ) So who's the trail blazer ?
...FYI, I removed both strike plates and using a file and Dremel tool removed about a sixteenth of an inch of material from the bottom of each...
Yup, that is what Cari did on our PL handle lock stike plates also. Though we don't even use the door lock, only the dead bolt.
All that said, I soooooo feel for you two (and i know our PL#35 makes it three). Cari and i were camping this week and she stated, and i agreed, that even with these issues the PL layout is still such a good fit for us.
I am going to attempt contact in ernest with Chandler and if no response will go with your suggestion on contacting the NC Consumer Protection services and let them do their thing. Though i would rather it not come to that for any one.
Cheers,
Thom
Parkliner contact info from PL Website just for archival sake:
Feel free to call us
800-418-2120
Our fax number:
866-296-3606
Mailing and Shipping Address is…
Park Liner, Inc.
106 Railroad Ave, Suite G
Gibsonville, NC 27249
Blogging from the WET! Coast of Oregon
Bed, Bath, & Beyond...
2010 Chevy Express 1500 AWD Van
Archive: Parkliner #35 build thread
accrete is offline   Reply With Quote
Old 09-21-2013, 04:35 PM   #327
Upstate New York
Last time I actually spoke to Mr. Palethorpe on the phone (several months ago), he assured me that he would put my phone number into the directory on his cell phone so that my name would come up and he would answer or return the call as soon as possible. He lied.
Brian M.
Old 09-21-2013, 04:45 PM   #328
Trailer: Parkliner
Alabama
Originally Posted by Alabama View Post
Hey Birmingham1,
It wasn't me that looked at your camper.
I haven't had any battery/converter problems but there is a whole thread devoted to that. As I recall, there was one person who let the batteries get completely drained, sit, and then during the recharge process they vented. From the posts, even some from the battery manufacturer, it seemed to me the problem is at least in part allowing the batteries to sit completely discharged.
What kind of problems are you you? I might suggest you post in that previous thread related to the batteries. Several folks were following it and it had some great responses that may help you out.
Old 09-21-2013, 04:47 PM   #329
Trailer: Parkliner
Alabama
Ha. I don't mean to pile on, but I as a funny (not really funny, haha) part of my experience is that he told me this three times. Each time he forgot he told me the time before. I really did laugh at the time. Not so much now.
Old 09-21-2013, 04:57 PM   #330
accrete's Avatar
Astoria Oregon
Ha. I don't mean to pile on...
well, to keep the humor going... i dialed his cell # one day and Chandler answered; "Hi Thom, how's the camping going?", I was shocked and flattered.
and i will say it again, loudly...
I WOULD LOVE TO SHARE A CAMPFIRE WITH CHANDLER!
Just wish it could be under better circumstances.
Thom
Old 09-21-2013, 05:05 PM   #331
Alabama's Avatar
Alabama
The converter was cooking our batteries and overheating. We woke up in the middle of the night with the dogs barking, a hissing sound and the smell of sulfur. The underside of the plywood was scorched as well. That was in June..... Need i say more? Thanks for the input about the other threads. I will definitely check them out.
Old 09-21-2013, 05:21 PM   #332
accrete's Avatar
Astoria Oregon
The converter was cooking our batteries and overheating..
My solution is well documented on my thread, in summary, i chose to spend the $ on an Optima brand charger (1200 digital) for the Optima Blue tops in our PL#35 after discussing the needs of the Optimas with both the Progressive Dynamic techies (you should have a PD4045 in your rig) and the Optima techs. I have really appreciated the Optima charger doing what it's designed to do. The batteries are charged now in about ~8 hours rather than several days of waiting with the PD unit.
cheers,
Thom
Old 09-21-2013, 05:33 PM   #333
Alabama's Avatar
Alabama
Thank you so much! I should have visited this website first. I feel like I have wasted a whole summer waiting on Chandler while I could have been camping.
Old 09-21-2013, 05:35 PM   #334
accrete's Avatar
Astoria Oregon
Well welcome to the forum! Hope you get things worked out with your PL and have some peacefully-memorable adventures (rather than the _other_ type of _memorable_ adventures!)
Old 09-21-2013, 06:14 PM   #335
Upstate New York
Thom
I sincerely hope those better circumstances come. My pre and post sales experiences would dictate otherwise. While standing face to face and conversing with Chandler, you can't help but empathize with someone who is obviously passionate about what he does, and is, in many ways, seemingly clueless as to how is is going to accomplish it. I have met Chandler, I have met his employees, I have met one of his children. I wish none of them any ill will. I do not wish to make a lifetime commitment to tilting at the windmill named ParkLiner. I expected the value that I was promised for the price that I paid. If Chandler chooses to not live up to this promise, he will probably fail. That will not be my doing, it will be his own. There are many orphan FGRVs out there. I don't want to make a career of litigation with ParkLiner, I'd rather be camping. We will make ours roadworthy, with or without Chandler's help, because it suits us. We will make such improvements as we find necessary and are consistent with our lifestyle. We will not let this failure of one company's promises define our lives. We are sorry it has come to this.
Brian M.
Old 09-21-2013, 07:18 PM   #336
Melanie B in NC's Avatar
Trailer: Lil Snoozy "Marigold"
Alabama
Park Liner does not appear to be BBB affiliated or accredited. It is possible for whatever their own reasons may be that they have not applied for BBB accreditation. So it is not possible to enter a complaint there (unless I am just missing their listing).
Melanie B in NC is offline   Reply With Quote
Old 09-21-2013, 07:39 PM   #337
Upstate New York
I am not surprised, Melanie, nevertheless, I thought it reasonable to make the complaint one of record and will be more than happy to publish whatever response I get. The response from BBB was as follows:
Complaint ID#: 33025262
Business Name: ParkLiner, Inc
Thank you for contacting the Better Business Bureau. Your complaint was received by the BBB on September 19, 2013 and has been assigned case# 33025262in our files. Please make a note of this number for future reference.
The text of this complaint may also be publicly posted on BBB's Web site. Please do not include any personally identifiable information in describing the nature of your complaint. BBB may edit your complaint to remove personally identifiable information and inappropriate language.
Your complaint has been applied to the following business:
ParkLiner, Inc
The case has been reviewed by one of our Complaint Specialists and has now been forwarded to the business for their response.
We encourage you to use our ONLINE COMPLAINT system to keep up with the progress of this complaint. To view the details of your case please go to the following website address: http://www.greensboro.bbb.org/compla...25262/c/49p29e .
Sincerely,
Michael Henson
Dispute Resolution Specialist
BBB Complaint Department
mhenson@greensboro.bbb.org
If anyone would care to use the above referenced case number to add their input, please feel free to to so. I will follow up with any information or response I receive either from ParkLiner or BBB.
Brian M.
Old 09-21-2013, 07:58 PM   #338
The company you are complaining about doesn't have to be a member of BBB.
I just had my furnace at home replaced. I checked out the company ( which has been in business for more than 50 years ). They are not a BBB member, but BBB gives them an A+ rating, with no complaints reported.
So, anyone checking ParkLiner on the BBB site will discover that there are several unresolved complaints and I suspect the rating will be significantly lower than A+.
Old 09-21-2013, 08:01 PM   #339
Mike Magee's Avatar
Trailer: 2012 Escape 19
When a firm is not a member of the BBB, a complaint about that firm to the BBB is not likely to get very far. The BBB has no teeth to influence a non-member.
The lack of after-the-sale assistance is truly disappointing. Owners of a five-figure purchase should not be left to fend for themselves.
Do PL owners receive any written warranty? If so, and depending on its provisions, PL could be in breach of it.
Old 09-21-2013, 08:46 PM   #340
I don't think BBB has any sharper teeth if the company is a member. What can they do? They report the complaints, try to resolve them and give them a rating.
Most they can do is refuse to let the company use the BBB logo ( and that doesn't stop some companies from using it without authorization ).
In any event, complaints to BBB are recorded and the existence of complaints appears on the BBB site, whether the company is a member or not.
parkliner
WA: Parkliner Thomas G. Referrals: Molded Fiberglass Trailers 19 04-15-2013 09:37 PM
Looking for a Parkliner Jomoflymo General Chat 29 03-02-2013 08:12 PM
Parkliner WaltP General Chat 70 11-08-2012 06:54 PM
Parkliner, Anyone? GingerB Hi, I am.... 6 04-25-2012 06:56 AM
Something going on with ParkLiner? harryjhere General Chat 32 11-17-2011 03:27 PM
