"Peel-n-Stick" products in a Boler - Page 2 - Fiberglass RV
Old 08-30-2018, 11:47 AM   #15
Trailer: boler
Originally Posted by Marinab View Post
Attachment 93243Attachment 93244
What was the backer you use and was there elephant skin/ensolite on the wall?
Nancy F is offline   Reply With Quote
Old 08-31-2018, 11:53 AM   #16
ststefan's Avatar
Trailer: 1979 Boler1700
Maple Ridge, B.C.
I used 1/8th inch plywood and glued arborite (formica, wilsonart) to it. Then I stuck the peel and stick to the arborite for the backsplash. I also glued arborite to the countertop and tabletop. Then I added aluminum transition strip fir a retro look.Click image for larger version
ID:	124130Click image for larger version
Old 09-15-2018, 10:26 AM   #17
Trailer: trail mite
Hi,
Newbie here, did you glue the 1/8 plywood to the fiberglass, then the arborite?
Also, Donna mentioned putting linoleum right over the carpeting. I have very thin carpeting and wondering the cons of putting flooring right on top. Sure would be easier
thanks!
Julie
jbenkovich is offline   Reply With Quote
Old 09-15-2018, 12:25 PM   #18
ststefan's Avatar
Maple Ridge, B.C.
Originally Posted by jbenkovich View Post
Hi,
thanks!
Julie
The arborite is glued to the plywood then the peel and stick to the arborite. It was all set in place, tucked under the top cabinet gap and set on top of the cabinet frame. The countertop was installed afterwards.
I would remove the carpet for the mew flooring. Carpet tends to hold water if it gets wet. More so if its under laminate. Also will the lower cabinet doors be able to open with the new flooring and carpet combined.
Old 10-04-2018, 12:27 PM   #19
Trailer: boler
Originally Posted by RoseandtheDoctor View Post
Thanks for the advice, everyone!
Looks like it's time now to start testing things out....
Hello, I am doing exactly the same thing to my 76 boler. Research I have done indicates the tiles would not stick as the surface is not smooth. You need a smooth surface such as arborite, smooth acrylic, painted plywood. I am choosing arborite as it is thin and I was able to buy a
2 x 4 off cut for $5.
My issue is what adhesive to use to attach it to the ensolite, and would I need to secure it in another way as well. Anyone have suggestions?
Old 10-04-2018, 12:29 PM   #20
Trailer: boler
Originally Posted by ststefan View Post
I used 1/8th inch plywood and glued arborite (formica, wilsonart) to it. Then I stuck the peel and stick to the arborite for the backsplash. I also glued arborite to the countertop and tabletop. Then I added aluminum transition strip fir a retro look.Attachment 124130Attachment 124131
How did you attach the plywood to the wall?
Old 10-05-2018, 01:41 PM   #21
ststefan's Avatar
Maple Ridge, B.C.
It isn't attached to the wall. I had the counter top off so I was able to tuck the top behind the upper cabinet and rest the bottom on the lower cabinet. then it got pinched in place when I installed the new counter top.
Old 10-05-2018, 04:49 PM   #22
Trailer: boler
Thankyou, I am also going to tuck the arborite up a little behind the top cabinets and in behind the lowers. I am planning on using an automotive spray adhesive on the back of the arborite for some added bonding.
Old 10-05-2018, 05:30 PM   #23
+10 the click together 100% waterproof floating vinyl flooring is pretty nice. I did the main floor in th Trillium today, I’ve got the dinette area and trim left to do. I removed old carpet and knocked the high spots off the original fiberglass floor. Cleaned up a couple of areas with acetone and green scrub pad where the old glue would show.
I got the Shaw branded stuff at Lowes.
I believe the Allure branded stuff is water resistant not water proof. I think it is because of the glue on it.
Old 10-24-2018, 03:49 AM   #24
Trailer: boler
Tried the automotive spray adhesive on both ensolite and back of arborite it did not work. It seemed to hold in some places but not a solid adhesion, didn't think it would be strong enough to hold the peel and stick tiles. The arborite pulled off without much difficulty even after 48 hours. Now to figure out something different.
Old 10-24-2018, 06:04 AM   #25
ststefan's Avatar
Maple Ridge, B.C.
I glued the arborite to some 1/4 inch plywood. It sits on top of the frame for the lower cabinets and is tucked under the upper cabinets. I had the countertop removed to do this.
Old 10-24-2018, 10:01 AM   #26
Trailer: boler
Thank you , I did see your information earlier. I am concerned a little about the thickness as I am not removing the window above the stove. The original counter has a lip that comes up about an inch, I did tuck the arborite down behind it, did the same at the top, this was a little tricky when trying to remove the arborite. I am wondering if I an cut away the ensolite and glue right to the fiberglass, or would this casue sweating/condensation in the area.
Old 10-24-2018, 11:42 AM   #27
ststefan's Avatar
Maple Ridge, B.C.
It might cause sweating. The walls under the ensolite is quite rough. The tiles might not stick too well.
boler
14' "Fun Finder," FGRV or stick? Ellpea in CA Care and Feeding of Molded Fiberglass Trailers 23 05-23-2015 06:28 PM
"Recommended Products Section?" BCDave Forum Admin, News & Announcements 62 06-16-2012 10:37 PM
EZ UP/First Up/Shelter Logic/Coleman products ??? DanPatWork Problem Solving | Owners Helping Owners 4 07-20-2008 09:24 PM
GEL COAT REPAIR PRODUCTS Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 05-08-2007 12:04 PM
New LED products for RV's Yves Pelchat Modifications, Alterations and Updates 2 05-30-2006 09:50 AM
