Pink Vinyl - Fiberglass RV
Old 07-07-2017, 05:47 PM   #1
Trailer: 2014 Scamp 16, 2011 RAV4 V6
Pink Vinyl
The vinyl flooring under the dinette and in the front storage compartment in our 2014 Scamp has turned from tan to pink. The vinyl in between is okay. Does anyone have an explanation for this?
Doug in Sacramento is offline   Reply With Quote
Old 07-08-2017, 09:24 AM   #2
Trailer: 13 ft Scamp
Weird
Might try a call to scamp
Old 07-08-2017, 10:29 AM   #3
melissab's Avatar
Trailer: 2008 20 ft Flagstaff Pop-Up (206ST) / 2005 Sienna
Mine did that where the carpet square provided by the factory was in front of the door. They put adhesive on the square to prevent it from sliding around so we figured maybe the adhesive did it from the heat. It happened within the first year of ownership.
Melissa in Florida
1999 Toyota Sienna XLE
melissab is offline   Reply With Quote
Old 06-06-2022, 05:30 PM   #4
Trailer: 2013 16 ft. Scamp
2013 Scamp 16'...same problem, same location.
anne myette is offline   Reply With Quote
Old 06-07-2022, 07:18 AM   #5
melissab's Avatar
We ended up replacing the entire vinyl flooring. From what I've read this happened to most Scamps from that year. They tried a different adhesive and this was the result.
Melissa in Florida
Old 06-07-2022, 08:21 AM   #6
Sounds like they installed an inferior product to save a couple of bucks...
Old 06-07-2022, 09:02 AM   #7
Its Scamp, Nuf Said
Old 06-07-2022, 11:08 AM   #8
This is an old problem, long rectified. Yes, there was a miscalculation on something by Scamp, not sure if it was the adhesive, the vinyl, or some unusual interaction between them. If these were newer trailers, certainly I would expect some adjustment from Scamp.
Most residential finish materials are not warranted for RV use due to vibration, temperature and humidity extremes, and heavy wear.
At this point, I would just rip it out, sand off as much of the adhesive as possible, apply a stain blocking primer, and install the finish flooring of your choice.
vin
Glue for vinyl to vinyl Cmtravels Problem Solving | Owners Helping Owners 8 08-14-2015 06:18 AM
Pink Glove Dance Donna D. Jokes, Stories & Tall Tales 4 12-02-2009 08:51 PM
I'm "In The Pink" & It's Spring! Alf S. Care and Feeding of Molded Fiberglass Trailers 7 04-03-2009 05:31 PM
pink flamingo knobs.... Christi V. Classified Archives 0 07-29-2008 05:25 PM
If you don't mind pink... emergency radio Bobbie Mayer Problem Solving | Owners Helping Owners 13 02-18-2008 07:11 AM
