Old 05-22-2012, 04:05 PM   #1
Trailer: 25b25fb
Bigfoot PLAS-T-COTE Alkyd Fibered Roof coating cracking up
So, after looking on the roof, the Plas-t-coating on the penetrations has small cracks forming, nothing looks gaping but what shall I do? Dicor lap seal right on top? Let it be? Anybody else have this problem?
stephonze is offline   Reply With Quote
Old 05-22-2012, 08:22 PM   #2
ahhhh Jeff, I'm not sure anyone here has ever (purposely) applied Plast-T-Cote to an all molded fiberglass trailer!?! Unless it was so gelcoat glazed there was nothing else to do to seal it up.
Is your trailer all molded? Or is it a slab sided Bigfoot with a molded roof? Forgive my ignorance. If it's something other than ALL molded, I can point you to a different forum for solutions (as can others).
Double Yolk
1988 16' Scamp Deluxe
Old 05-22-2012, 08:37 PM   #3
Trailer: Bigfoot 21
That model is the 25 foot, front bedroom (all-molded) Bigfoot
Model nomenclature for Bigfoot is (in this case) 25B25FB
Breaks out as follows: The leading "25B" means series 25B - winter model, all insulated, double pane windows, heated tanks, etc
The second 2 numbers are the size - in his case 25 footer
FB for Front bedroom
Mine is a 25B21RB - series 25B (winterized etc) 21 foot, Rear bedroom model
Bigfoot made some "weird ones", too but this would be a molded one.
Old 05-22-2012, 08:40 PM   #4
Thanks Dave... any suggestions for a roof repair other than removing that 'stuff' and trying Captain Tolley Creeping Crack Cure?
Double Yolk
Old 05-22-2012, 09:32 PM   #5
Trailer: Bigfoot 21
I think I'd fall back on the way Gina D was fixing up her Leocraft while she was in Cali. However, FIRST I'd get the PlastiKote Fibered roof coating OFF the roof of the trailer, and then I'd look into why it is on there in the first place - are there cracks in the fiberglass? leaks?
Then find a way to deal with those issues - but another coating on top of a coating that isn't working out real well - somehow just doesn't seem like a great plan. I'm NOT a fiberglass expert by any means - that's one of the many reasons I that read virtually every message on this site - I need to learn - a lot!
From the description, "the Plas-t-coating on the penetrations has small cracks forming" makes me wonder if it isn't just leaks around fan openings, fridge openings, sun roof opening, antenna openings, vent openings and etc. that were patched with the "plasti-kote"
If THAT is the case, the answer is to remove the vent or what ever, clean up the opening and reinstall with Butyl rubber tape (NOT SILICONE!!!!) and clean around the area., getting rid of the "foreign material" which likely won't adhere well to the fiberglass gelcoat anyway.
Unless of course, I'm completely wrong. (I was wrong about something once - I thought I'd made a mistake, but I really should have known better than that! )
Old 05-23-2012, 06:13 AM   #6
Trailer: 25b25fb
Thanks for the interest..so to clarify, the molded roof top has fans, a/c, and tv antenna and a roof rack/ladder mounted. If looking at the fan, the Bigfoot factory used masking tape and applied in a square shape around the fan, then plas-t-cote was brushed on the overlap of the fan's base flange to the fiberglass roof, masking tape removed and nice squares of Plas-t-cote remain. I would think a b-tape or a gasket was used under the flange as it was mounted (it's an 2009) but I don't know. It looks like the Plas-t-cote was a extra over the flange base, screw holes for the rack etc. It's just that it is showing small cracks, i was planing on removing and resealing the small dabs of plas-t-cote on screws etc. but on the fans and a/c the plas-t-cote looks good under the cracks...so maybe the best thing is to eternabond tape the square sections around the fans and a/c...or brush on more plas-t-cote to fill the small cracks...I would hate to take up the sealant when it looks half good. Also, there are no leaks.
Old 05-23-2012, 11:35 PM   #7
Trailer: 2007 Bigfoot 25b25rq
I have read elsewhere that the Plas-ti-cote is from the factory. Scrub it well, mask it off and apply another coat.
Derek
Derek Johnson is offline   Reply With Quote
Old 05-24-2012, 09:19 AM   #8
Tim Wood's Avatar
Trailer: 2012 ParkLiner
NY
Derek
Yep what he said. And If I remember right my old 17' Bigfoot had the same thing.
Old 05-30-2012, 02:21 PM   #9
Gina D.'s Avatar
West Coast
I did actually end up doing a rubber coat on mine. I used Dicors product, however, not plasticoat.
After epoxying and glassing in every single visible spot that *might* be a cause of leakage, and still having some issues, I coated it.
I knew it was not the vents or other typical leaks spots. On a 1977 trailer that spent most its life in the desert, I could only "guess" that the gelcoat was so worn and bad that it would be impossible to find the few spots left that still leaked. 2 coats per instruction fixed them all.
That said, I would do everything in your power to NOT do that. It will need to be done again in 5 years if you do. Getting the coating off is near impossible, and very expensive if done professionally.
AFTER I used Dicor rubber, which is good to use on glass too, Dicor has come out with a product specifically for glass. (Ya, a day late and a dollar short for me!)
bigfoot
Acrylic Elastometic RV Roof Coating. David Duxbury Modifications, Alterations and Updates 21 09-06-2009 07:02 AM
roof coating Bryan B. Problem Solving -- Owners Helping Owners 0 07-24-2009 07:52 PM
Under coating for Eggs Robert Scallan Problem Solving -- Owners Helping Owners 3 10-22-2007 05:52 AM
cracking a burro Jason L. Problem Solving -- Owners Helping Owners 8 01-25-2006 09:35 PM
Under coating for Eggs Robert Scallan General Chat 0 12-31-1969 06:00 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
