Play Pac VIN? - Fiberglass RV
Old 05-27-2011, 01:25 PM   #1
Meghan's Avatar
Trailer: Play Pac
Play Pac VIN?
Does anyone know where the VIN is? I searched ALL over and cant find it. 2 others before me also looked for it, and cant find it.
Meghan is offline   Reply With Quote
Old 05-27-2011, 05:40 PM   #2
Trailer: 1985 16 ft Scamp
Ohio
Look very carefully at the tongue in the front. Look on the top and the sides of the frame, inch by inch with a strong light, at a 45 degree angle. It probably has been painted over. If you find some irregular bumps, use some 320 grit, wet and dry sandpaper, wet and scrub that area until the vin appears. If it remains, it should be right up there on the tongue. Also, look for a tag, probably pop riveted on and painted over. Unless there is foul play, it should still be there. I had to call Scamp to locate mine and if I did not know exactly were to look, I would have missed it and did several times before. They hide well under layers of paint...Best of luck to ya! How about some of you other PlaPac owners/former owners. Anyone recall where the VIN is?
Michael
BigMike is offline   Reply With Quote
Old 05-27-2011, 05:43 PM   #3
Meghan's Avatar
Trailer: Play Pac
I will look again, but it has never been re painted and is all original. I think this is a common problem with the Play Pac. Thank You for your advice I will deff. look again
Michael
vin
Play Pac Bonnie General Chat 161 06-24-2016 02:47 PM
Play Pac Redo Bonnie Problem Solving | Owners Helping Owners 35 06-08-2011 06:49 PM
Hi! I just bought a play pac Meghan Hi, I am.... 16 05-29-2011 05:29 AM
New (old) Play Pac owner. James McKnight General Chat 3 05-08-2010 06:51 AM
