Join FiberglassRV Today
Old 02-20-2012, 06:37 PM   #1
D Davis's Avatar
Trailer: u-haul ct13
Virginia
Please advise, Wiring on CT13
I feel very humble in asking for your advice. I know there has been much discussed on this subject. I still am at a loss as I know nothing about AC-DC wiring. I do try to do as many things as I can myself but ...Electric Stupid I have read the U Haul manual and Parts manual someone so graciously provided on this site under the Documents center. Still stupid and maybe trying to do too much. I will post some pics as everything is loose and wires are cut everywhere. I need 12 volt system working as I camp primitively. Previous owner cut out the back window and put a window airconditioning unit in. Will get a fantasitic sometime in the future instead.
1. I have bought a battery, an Optima 24 group agm
Not sure where to start. Do I need a vented battery box? Is it safe to sleep on top of it.
I will post some pics and show you what is there or not.
D Davis is offline   Reply With Quote
Old 02-20-2012, 06:49 PM   #2
Thomas G.'s Avatar
Trailer: UHaul CT13
You need to get a fuse panel to hook to the battery, then run wires from the fuse panel to each of the lights, fans, etc. You can make one with a sheet of metal and a bunch of these.
2 Pcs Electrical Locking Nut 6 x 30mm Fuse Holder Black | eBay
or buy one all made up at a boating or camper place.
Old 02-20-2012, 06:58 PM   #3
Dennis Clinton's Avatar
Trailer: Scamp 16'
Utah
Get a fuse block as suggested by Thomas G. AGM batteries do not outgas so do not need a vented battery case(but still need to be strapped down).I would use stranded wire(I prefer 12awg, but some use a smaller guage), color code your work-red or black for hot and white from common.
Dennis
Dennis Clinton is offline   Reply With Quote
Old 02-20-2012, 07:15 PM   #4
D Davis's Avatar
Virginia
Thank you Thomas and Dennis for sharing. I think I will divide this work into little blocks, one step at a time as I am getting overwhelmed. Will start with the Fuse panel first. I thank you so much for your advise.
Old 02-20-2012, 07:34 PM   #5
The Uhauls had a battery box with a vented cover located center rear. If it is gone I would buy one, at Walmart or auto parts store or boat place. Screw it to the floor. How about the power converter, is it still there, but I'm guessing it's not. What about the original 12 volt lights. Otherwise from your pictures it looks like a wiring butcher job that someone did there. Uhaul's original wiring wasn't so great from what I'm seeing in ours. Right now I'm doing the 110Volt wiring, then going to upgrade the 12 volt and add a couple more lights. And what about the rear window, I'm looking for a replacement for ours as it is in bad shape, but haven't made a final decision yet. If you need to talk to someone about the wiring let me know. How about joining us at Jane's Uhaul rally in SC in April for a wiring lesson. Bob
Old 02-20-2012, 08:11 PM   #6
Mouse's Avatar
Trailer: U Haul CT13
I just put in a LifeLine AGM battery. This is one of the warnings they give:
Battery Charging:
WARNING: All batteries must be adequately vented during charging to avoid accumulation of explosive hydrogen gasses. Never install or charge in a sealed container or room.
The uhaul battery box has a vent tube to the outside. It is important to have it connected. AGM's vent less but it can still happen.
Mouse is offline   Reply With Quote
Old 02-21-2012, 05:52 AM   #7
Thomas G.'s Avatar
Trailer: UHaul CT13
You can buy a replacement battery box at an RV or boat place. It should have a gasketed top.There should be a vent on the back of the UHaul to attach a 3/4" or so diameter tube to the box.
Old 02-21-2012, 06:09 AM   #8
NAPA auto parts has a 6 circuit fuse block with a single input for a wire from the plus side of your battery. It is part # BK7825316, price is about $18.
Old 02-21-2012, 06:31 AM   #9
Thomas G.'s Avatar
Trailer: UHaul CT13
Just a caution to the OP, you should get a book or other learning material and understand basic DC circuits. That battery has the capacity to do great damage (think burns, fire) if shorted out. Understand about minimum wire gauges, fuse sizes, how to wire a switch.
It is not complicated, but you really owe it to yourself to get down the basics. Plus you will save yourself from doing the job twice.
Amazon.com: Used and New: Basic Electricity and Dc Circuits
Old 02-21-2012, 07:02 AM   #10
Here's a real easy solution, buy a few of the stick-on LED lights that use AAA batteries. No wiring required. We have a couple in our teardrop as we don't have room for a big battery in that.
Old 02-21-2012, 07:46 AM   #11
Trailer: none
Wisconsin
DC Overcurerrent
Make sure any overcurrent devices you buy are rated for DC when used in your 12 Volt system Standard home circuit breakers are rated for AC only and will not function properly on DC . The spacing and design of the contacts in DC devices are designed differently because of the way DC arcs
Old 02-21-2012, 08:09 AM   #12
Thomas G.'s Avatar
Trailer: UHaul CT13
That's a good temporary solution. I've found the ones at Dollar Tree to be of reasonable quality. I peppered the underside of my closet shelves in my linen closet with them. No black hole corners.
Old 02-21-2012, 09:37 AM   #13
Trailer: scamp 13
i sugjest you go to the local library and get a book. "the 12 volt bible" is a good one. its really not hard stuff. but its good to study a little first.
Old 02-21-2012, 10:10 AM   #14
Thomas G.'s Avatar
Trailer: UHaul CT13
Originally Posted by john warren View Post
i suggest you go to the local library and get a book. "the 12 volt bible" is a good one. its really not hard stuff. but its good to study a little first.
I'm a big fan of buying used books online.
BookFinder.com: Search Results (Matching Books)
CT13 - Exterior Lighting Wiring Wolfyjedi Problem Solving -- Owners Helping Owners 4 09-13-2011 05:39 PM
Some wiring advise? Rob L Problem Solving -- Owners Helping Owners 10 12-14-2009 04:32 PM
Need advise on new converter upgrade FredericL Problem Solving -- Owners Helping Owners 9 05-14-2009 08:52 AM
Advise on Foam for cushions MikeCM Problem Solving -- Owners Helping Owners 16 04-19-2009 02:54 PM
Help! Need some advise Adrian W General Chat 1 02-27-2007 07:16 AM
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
