Please don't do this to your trailer! - Fiberglass RV
Old 08-14-2014, 08:27 PM   #1
sarahspins's Avatar
Trailer: 1984 13' Scamp named "Ramblin Rose"
Yet another "what on earth were they thinking" discovery today.... I am almost speechless. I knew there was a "patch" of some sort over the previously rotted rear floor, but this is truly not what I expected when I finally removed one of the benches and peeled back the linoleum to take a look.
I really just don't get this... no matter what this was always going to be a half-assed job because of the way the prior owner approached fixing it (which I could feel under the linoleum), but peg board is the absolute last thing I would have expected to uncover.
Granted, I expected to replace most of the rear floor because of water damage visible under the bench (where the OSB had chipped away under the fresh coat of paint it got at some point) and because the old leaks were never really fixed (as you can see by the trails down the ensolite under the rear window), so whatever, but I just don't get it.. if you are going to go through the trouble to pull everything out and put down new linoleum, why not actually take the time to fix the floor better than this? Or better than that, fix the cracked and leaking window seals that led to most of this in the first place... that job took me all of 30 minutes per window, it honestly wasn't that difficult (it was easier than I expected to get the lockstrip in, once I lubed up the channel very well), and I even did one of them in the dark
I should have snapped a shot of what was underneath the soggy rotting peg board, but the OSB has completely disintegrated, there were some holes patched with who knows what that was barely clinging on (might be caulking, might be construction adhesive... I'm honestly not sure).
We won't even get into the wiring.. it's a mess and full of splices wrapped in nothing more than wire nuts and electrical tape, and I can't even imagine how corroded everything is since none of the leaks were ever fixed until just recently, and it's coming out as soon as I get the other bench free (I needed a flashlight to locate the screws attaching it to the closet cabinet, so that seemed like a good place to stop for the evening) so I have easy access to everything all at once. I did "replace" the taillights a while back, but they're not wired in yet since there was no continuity in these wires from the front of the trailer. I have all of my supplies ready to go, but re-wiring has been low on the list of priorities
On tomorrow's agenda is to get the other dinette bench out and start working on removing the rotted floor... should be fun
sarahspins is offline   Reply With Quote
Old 08-14-2014, 09:32 PM   #2
Alabama
Sarah, Maybe yours can be the first entry of a new "What were they thinking?" contest. I'm sure there are lots of other photos and restoration horror stories out there. Find a way to post them in a photo gallery and eventually let people vote for the "Worst of the Worst (WOW) Award".
Old 08-15-2014, 01:31 AM   #3
Hi, I have recently had almost the same situation in our newly acquired old boler. I am curious as to your steps to replace the floor? I'm to the point of Lino pulled up and now plan on cutting the rotten section out.
Shields is offline   Reply With Quote
Old 08-15-2014, 01:58 AM   #4
Borrego Dave's Avatar
There was a recent post on the strangest thing you've found in your trailer. I think Sarah has the winner so far
Old 08-15-2014, 05:44 AM   #5
It appears to be a combination of stupid and cheap A common malady
Old 08-15-2014, 07:07 AM   #6
papa-t's Avatar
Glade Valley, North Carolina
Well you just can't fix stupid. Huh
I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please! John Wayne
papa-t is offline   Reply With Quote
Old 08-15-2014, 07:52 AM   #7
GMike A's Avatar
Perhaps the logic was that the holes would provide proper aeration.
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 08-15-2014, 09:04 AM   #8
tractors1's Avatar
Trailer: Escape 21 - Felicity
Or improved drainage if there are additional holes drilled to daylight underneath.....
Charlie Y
Charlie Y
Old 08-15-2014, 09:22 AM   #9
Mike Magee's Avatar
Trailer: Li'l Hauley
The PO wanted to cover it up, make it look good quickly & easily as possible, and sell it right away to some unsuspecting person. There are people like that.
In the '60s, people took LSD to make the world seem weird.
Now the world is weird, and people take Prozac to make it seem normal.
Old 08-15-2014, 10:17 AM   #10
sarahspins's Avatar
That is pretty much my plan. I don't know if the boler has fiberglass under the floor but the scamp doesn't, the floor is tabbed into the fiberglass shell. I plan on removing the upper layer of fiberglass tabbing (dremel multi-tool will aid in the removal) and then I intend to remove a section of floor about 12" wide across the back of the trailer and fiberglass the replacement floor in place and reinforce it from below so the new section doesn't flex too much.
I have a similar section of rotted floor in the front under the bunk to repair as well, but the "area" the floor covers there is smaller and I plan on replacing the whole front piece on that side.
Old 08-15-2014, 10:39 AM   #11
sarahspins's Avatar
They fixed it up for themselves and used it for a couple of years.. this wasn't a repair made immediately before the sale.
Old 08-21-2014, 11:28 AM   #12
Nh
I'm in the process of the same thingClick image for larger version
Name:	ImageUploadedByFiberglass RV1408641906.460690.jpg
ID:	75236 didn't expect A piece of plywood hiding this, the hardest part was detaching the fiberglass seem to the plywood, I used a feint oil and cut the permitter of the seem, couple of pry bars and the sheet popped out easily! Hardest part B getting the sheet out of the camper to use for template. I'm using 3/4 ac plywood that I will coat with something heavy duty. Do you have any before and after pictures?
Freerider3815 is offline   Reply With Quote
Old 08-21-2014, 12:42 PM   #13
Trailer: 77 Scamp 13
Have heard from someone in response to my floor rot repair that putting a coat of fiberglass resin on the underside is the best way to provide heavy duty protection to the wood from elements.
In the thread on my ongoing floor repairs I have a link to someone else that has done it, with pictures. Had some good ideas on how to support shell with floor removed.
Scamp front floor replacement couch removal
Last year I watched a YouTube video of doing a floor patch rather than replace, one thing that stuck in my mind because I have used it for drywall and some other types of repairs. Make the patch first, trace around it to make the cut in the floor. Get an exact match of hole to patch. The other thing I recall was they supported patch with board under floor across the hole with aluminum foil on it to keep the fiberglass from sticking. Did the top with fiberglass, removed the board then did the bottom too.
I bet I know how you ended up with the peg board under the linoleum. PO was doing a replacement of lino, possibly in advance of using it on a trip (I know I always end up doing that stuff when I'm getting ready to use it. Drives my wife nuts.) Discovers the floor rot. The floor repair is a bigger job than they have time for so.... patch with what will fit without being too thick and get the lino in so they can go camping. Planning to come back later to do a "proper" repair. Which never happened.
If PO would have found a piece of Plexiglas in the garage your repair would have been Plexiglas, if they found some sheet metal.... In short whatever was on hand that would let them finish the linoleum job. That would be my guess, why they did not fix the water leaks? No idea. Maybe they did not know how, or never camped in the rain or... are the sort that considered peg board a permanent repair of the leaking window ;-)
Old 08-21-2014, 01:10 PM   #14
sarahspins's Avatar
Roger, I suspect you are right on with how I ended up with the pegboard patch - I'm sure it's just what was handy at the time.
As far as waterproofing repairs, the underside of the original OSB in my camper is definitely coated in fiberglass resin, and it seems to work fine as a waterproofer - personally I suspect part of the reason the damage to my floor is so extensive is that the resin side was very much intact (until I started removing what I could without tools), any time water made it into the camper it just sat there rather than finding a way through and back outside.
I haven't had a chance to really set about removing more of the floor in mine, but I should have more opportunity after the kids are back in school next week.
If you see a bear, please don't do this Gina D. General Chat 17 08-30-2013 04:59 PM
So... you don't need bathroom facilities in your trailer Donna D. General Chat 36 06-23-2013 07:19 PM
PLEASE, don't let the cat outta the bag.... Doug Mager Jokes, Stories & Tall Tales 1 07-18-2010 01:57 AM
Don't let your dogs watch Gina D. General Chat 5 08-07-2008 02:59 PM
Webmaster, please don't read this! Legacy Posts General Chat 13 05-05-2003 10:31 PM
