Please explain Electrical? - Fiberglass RV
Old 05-22-2012, 10:21 AM   #1
Trailer: 1978 13' Scamp
Smile Please explain Electrical?
Hello all! Newbie here again. Learning about my scamp. Loving every moment. Feel like a dummy.
Can someone explain the electrical options and how they work? I see that there was a terminal for a battery. The previous owner installed a window AC and a simple refrigerator that he used with a generator. There is a water holding tank-- does it require electricity to pump! ACK!
and....what r these?!
morbank is offline   Reply With Quote
Old 05-22-2012, 12:47 PM   #2
Dennis Clinton's Avatar
Trailer: Scamp 16'
Utah
All Scamps came with a 12v battery(pretty sure). I'm not sure what the 2nd picture is-looks like a pop-out breaker with a switch and a heat sink on top. The Scamp site has a electrical schematic which should help you. Where are you in CA? If you're close to Big Bear, I'll be there this weekend and could take a look.
Dennis
Dennis Clinton is offline   Reply With Quote
Old 05-22-2012, 02:44 PM   #3
The way some of these eggs are now wired (thanx to the "high-level" of skills involved in the "journeyman electrician" repairs done by previous owners over the years) there is no rational explanation for the electrical!
On edit - I think the device in your first pic is a cigarette lighter socket - also usually referred to as a 12 volt outlet
Old 05-25-2012, 11:09 AM   #4
If you haven't read the scamp website, it is pretty informative if you dig into it a little bit about the various systems in a scamp.
I'll second that the top picture is a 12V outlet similar to what is in most cars. The bottom picture I only have guesses and would need more pictures and information to determine what it is. However, someone else on the forum may recognize it.
The water holding tank usually gets water out one of two ways. First, there can be a hand pump usually near the sink. Second there is a pump that pushes the water and typically there is a switch to turn the pump on/off. You can follow the water lines and usually find the pump.
I'm generally decent with amateur electrical stuff and willing to answer questions if you have the time.
ericw is offline   Reply With Quote
Old 05-25-2012, 02:14 PM   #5
Cindy the first photo as Dave indicated is your 12Volt plug in - you can plug anything you have that runs on 12V into it - or buy a 12Volt charger for your cellphone etc.
The second photo has me a little puzzled would need to see a bit more of the other side of the box and its location. Is it under your sink area? Could be your power breaker box or your converter although it looks a little odd to be either...
electrical
Someone please explain trailer brakes Anne F Towing, Hitching, Axles and Running Gear 6 06-26-2010 05:06 PM
Explain Kevin K General Chat 52 06-27-2009 06:24 PM
Please explain ??? Bill K Towing, Hitching, Axles and Running Gear 8 03-26-2009 10:05 AM
randy please explain that bear! potteralice General Chat 0 05-19-2006 04:58 PM
Explain Atwood Heater jefh Problem Solving | Owners Helping Owners 6 12-15-2005 01:35 PM
