Please help. Sourcing out leaks after rainstorm - Page 3 - Fiberglass RV
Old 06-14-2012, 02:39 PM   #29
Well first off its not a good idea to put all your weight onto the roof - its not meant to hold much weight so when your up there try and keep your feet on the ladder and spread your weight out. Depending on the how the vent is constructed/type and if the screen is removable and its size you may be able to reach up from the inside through the vent itself to get the rivets out and replace.
Removing the window isnt as scary as it sound and I would save the money on an RV place. All you really need is two people and the second person is only really needed to make sure the window doesnt drop to the ground when your release the inside frame & to hold the window on the outside when your re install it.
It may look like the person who did the window repair did it correct but without taking it off you really are not going to be able to see how much butyl he used and if it actually sealed it well around the whole window.
Did you run some weed wacker plastic/trimmer line through the window weep hole of the window? If not try it - could simple be the weep holes are clogged.
Old 06-14-2012, 02:57 PM   #30
Tim Wood's Avatar
Trailer: Class B for now
NY
Tracy, When you cleaned out the weep holes, did you do like Carol mentioned used something stiff like the trimmer line ? Before you pull the windows I would try cleaning them out good. And if your vent is leaking, I would pull that and re-install correctly with butyl tape. Like already mentioned once you do pull out a window its not a really big deal to do the job right and re-install. Same thing with the vent. Tackle one problem at a time and you will get it done.
Old 06-14-2012, 05:02 PM   #31
Trailer: 77 Scamp 13
If the weep holes are plugged the window will leak without a doubt. Water backs up in the track and overflows.
You know the vent leaks so your on the right track to start there. If you still see water at the window after the vent fix I recommend a search using a bucket and plastic cup.
Only apply water to window one area at a time, starting at bottom, go inside and check for water after doing each section. Then you will know where leak is by what part of window you applied water to. Trick is to be certain inside of window is totally 100% dry. If blotting with a kleenex picks up any water your leak is where you last applied water.
We generally tend to think it's the frame of window to trailer but I had a window leak that was the glass frame to window frame rubber seal coming loose. Water ran down edge of screen, filled up track (clogged weep hole) then leaked down wall.
I'm sure you will do fine with a vent or window remove and re-seal. Our reservations and concerns about doing this type of work are generally worse than the job warrants.
Old 06-14-2012, 05:13 PM   #32
Trailer: purchasing a Boler
I poked my awl into the weep holes....is there a track that runs from one to the other? If so then I will have to find something to feed into them. It is going to pour rain very shortly here so and I will go stand inside the trailer and see what I see.
CheekyTracy is offline   Reply With Quote
Old 06-14-2012, 05:14 PM   #33
And please, please, please DO NOT try to fix a leak by puttying/caulking etc on the inside!
Remove windows if you have to. Use Butyl tape (NOT PUTTY) and then reinstall the window so that it squashes the butyl out as you tighten things up.
Window drains MUST be clean
If it is a sliding window - how are the seals that the window slides against, and where the fixed and sliding parts meet?
If you go on the roof to work on the vent, there is a very good chance the roof will flex enough to mean that you will now have a VERY MAJOR repair to do. Use a ladder or a scaffold of some sort to support your weight - the roof was not intended to be that strong
Old 06-14-2012, 05:31 PM   #34
An awl will not do it for you. If you have a weed wackier the nylon that is used to cut down the weeds works well - you need something thin and flexible put fairly stiff to feed right into the weep hole.
Old 06-14-2012, 05:58 PM   #35
ok thank you carol....I will try it again. I don't have a weed wacker. I live in a loft apt and no longer have any yard work tools! I'll have to buy some. I am sure I can use it for something!! lol
Old 06-15-2012, 07:42 AM   #36
So after it started raining last night, I checked the trailer right away and the water is leaking and pooling onto the inside window track almost immediately and dripping from the bottom corner onto the bench. I am going to try the weep holes again as I don't think I did it properly last time. Tomorrow is the only nice day in our forecast so pulling the vent and/or windows will have to happen then however I don't have the resources at the moment, manpower or otherwise, to do it myself. I guess we'll see what happens.
Old 06-15-2012, 09:17 AM   #37
To keep the water damage down you might want to consider just duct taping the window and the vent in the meantime
Old 06-16-2012, 11:53 AM   #38
Trailer: 13 Trillium
Ah yes, duct tape! As funds abound here I fixed a crack in my fiberglass with duct tape.....big ol' "X" over the crack with OUCH written on top!LOL That was my quick fix, still dealing with the windows. Seriously, as far as duct tape goes, some tape can leave a real nasty residue that hardens like cement. I wasn't worried as eventually that whole area will get sanded out when I can repair it properly. Check with Donna - she is no friend of duct tape!
lhanna is offline   Reply With Quote
Old 06-16-2012, 02:53 PM   #39
LOL your right I should have added a note on the residue issue - but if nothing else to use Duct tape does the trick of at least attempting to stop further water damage for a few hours.
Old 06-16-2012, 09:26 PM   #40
I bought the weed wacker line....fished it through my weep holes ... it sprinkled a bit this morning and all was dry but the kicker will be tonight/tomorrow as more rain is expected. Haven't resorted to the duct tape yet but won't rule it out!
Old 07-16-2012, 08:09 PM   #41
oh, woe is me!
Since I have a ever-narrowing window of opportunity to relocate before the end of summer, about two weeks ago I took my Boler to be serviced instead of trying to pull and reseal the windows and roof myself. The two side slider windows (not original but installed by PO) and the roof vent (original) were removed and resealed using Butyl tape. This weekend was the first time it rained since the repair and to my disappointment, the side window which originally leaked the most is still leaking badly soaking all my bedding and the bunk cushion. I cannot figure out where it is coming from but it appears that all along the bottom edge of the window sill is wet. I am curled up in a ball in the fetal position as we speak!! lol Now what??
Old 07-16-2012, 08:47 PM   #42
Terribly frustrating those leaks but since you paid someone else to reseal the windows, can't you take it back to them?
leaks
Leaks Brian in Ontario Care and Feeding of Molded Fiberglass Trailers 7 08-28-2012 09:07 AM
Leaks John Cotrill Problem Solving | Owners Helping Owners 6 10-20-2011 11:21 PM
Oh No! It leaks! lhanna Problem Solving | Owners Helping Owners 36 08-11-2011 06:38 PM
Help with leaks earnie Problem Solving | Owners Helping Owners 6 09-19-2010 02:20 PM
Fixing leaks Tom Byron Problem Solving | Owners Helping Owners 11 12-23-2009 09:27 AM
