Please Help....TOOLS - Page 3 - Fiberglass RV
Old 07-22-2015, 06:44 AM   #29
Originally Posted by SallyBEE View Post
Thanks everyone! All good words of advice and I had forgotten that he does play a bit with his ham radio so he will need a bit of space for that.
Well then add some RG-58U and PL-259s to the tool box
Old 07-22-2015, 07:39 AM   #30
The Minimalist's Avatar
Louisiana
Originally Posted by mary and bob View Post
Was this mentioned, safety triangle for if you do have to work along the road. But any truck driver will tell you they seem to be regarded as targets, and get run over.
It's very important to use these properly. If all else fails, read the directions.
Clif
Old 07-22-2015, 11:23 AM   #31
Things to add to above lists if not mentioned.
rubber mallet to install the hub cap.
a pry bar to remove the hub cap.
a clicker torque wrench to check the lug nuts.
for the fridge on my 13 foot Scamp. A very long Phillips blade screwdriver. The metal shank needs to be at least 14" long so to get the handle out of the compartment and still reach the screws holding the burner guard. I had to use this just last month to remove spider webs from inside the burner on my last trip. saves a whole lot of swearing. You will also need a very short screwdriver to get the little screw at the end of the burner.
Bearing Packing Tools Deb & Chuck Commercial Posts and Products 1 06-06-2012 06:22 AM
Tools and rivets and stuff sfoss Care and Feeding of Molded Fiberglass Trailers 5 02-06-2012 06:47 AM
Tools explained DannyH Jokes, Stories & Tall Tales 5 10-30-2010 07:22 PM
Need new tools for Bandon Gina D. General Chat 4 03-28-2008 11:12 PM
