https://www.pellandent.com/One-Eighth-Inch-Glazing-Bead
I think it is this trim, there are two sizes. Rain headed in Tues if u can trust weatherman. I dont have time to order unless I do big tarp that has been blowing off overnight every time… dont get me started. Local RV store had only the most recent trim used on their models, no help.
It has taken 3-4 hours. I cleaned the frame down to bare metal, aluminum prep coat, black
paint coat yesterday. The aluminum etcher
paint did not work. Now I am working on the rubber. They used the black window goo that never dries, think black booger from hell.
I will try to re-use. Took a long time to get boogers out of channel and off the rubber, then the front was coated with silicone. Got most of it and more focused on the key surfaces now.
I am unsure if I should slather the black goo into the channel, or just apply it where the glass touches the frame. Also, I may apply it like a caulk on the outside rim.
The sealant I have is meant for auto windshields. Its a glue. Local rv place had nothing and auto parts had nothing else
