Plexiglass vs Polycarbonate (Lexan) - Fiberglass RV
Old 08-11-2015, 12:17 PM   #1
Thee Jimbo's Avatar
Plusses and minuses of each. I am told that lexan might be a better replacement than plexiglass. Lexan wont break etc. However I have never seen a "broken" front or back window on a scamp plus I am installing a gravel guard.
Thoughts?
From what I have read:
Plexiglass:
cheaper
scratches - can be restored by sanding and buffing
resistant to breaking - when breaks pieces are large and dull edged
Polycarbonate:
15% more expensive
untreated sheet discolors in 5-7 years of sun exposure
scratches - cannot be restored by sanding and buffing
Also I have been quoted 350-400 for two cut windows installed, maybe 300 for installed plexiglass is the cheapest option. Does this sound about right or shall I keep shopping around??
Ive looked for other threads comparing, but didnt find it so donna if you know of an existing thread, point me there please.
Thanks All
Thee Jimbo is offline   Reply With Quote
Old 08-11-2015, 12:28 PM   #2
Ian G.'s Avatar
You are correct in those general comments. Poly also has a much greater impact resustance but is also more flexible. I personally installed Poly in my Boler.
You can do the windows yourself, here is everything you need to know.
Front & Rear Windows
Old 08-11-2015, 12:58 PM   #3
Thee Jimbo's Avatar
Great link. Thanks. One post ineed said it was worth the fifty bucks to have the glass shoonomstall.cuz sometimes these suckersncan be a realnuou-kmow-what to.put in
Old 08-11-2015, 01:36 PM   #4
John Linck's Avatar
Trailer: 1990 Scamp 16 ft
Poly/Lexan is much easier to cut at home. Cuts well with a sabre or band saw. Plexi just melts and fuses back together. I believe both cut by scoring deeply and snapping, though that can be tricky, especially curved cuts.
John Linck is offline   Reply With Quote
Old 08-12-2015, 07:22 AM   #5
The polycarbonate is tougher but scratches easier.
Sent from my SCH-I605 using Fiberglass RV mobile app
Old 08-12-2015, 10:21 AM   #6
Trailer: 2008 17 ft Casita Spirit Deluxe
I cut Lexan by scoring/snapping with no problem, but they were straight cuts. I took a stained glass class, and it was the same method but even a little easier. If I had to do curves,which were a little trickier, for me, I'd just call around to stained glass artists' shops and sweetly ask for someone to do the cuts. They'd do it a lot cheaper, than a window place, I think. Maybe even free if you sound pitiful enough...
Ruth C. is offline   Reply With Quote
Old 08-12-2015, 10:37 AM   #7
tractors1's Avatar
Trailer: Escape 21 - Felicity
Lexan/Poly is what covers headlights & tail lights on vehicles. Cuts fine on a table saw with an 80 tooth or finer carbide blade, also easily shaped with a router if you make a template to follow for your window shape. Edges smooth well with medium sandpapers. I use it in 1/8th to 3/16 thicknesses.
Plexiglass doesn't hold up well to road grit and ANY abrasives when you wash the trailer.
Charlie Y
Old 08-12-2015, 01:04 PM   #8
Trailer: Shopping for new RV
LEXAN is the best choice.
Uplander is offline   Reply With Quote
Cleaning Plexiglass Front Window Vivian Problem Solving | Owners Helping Owners 5 05-05-2008 07:57 PM
Tinting plexiglass windows Flygal Problem Solving | Owners Helping Owners 9 05-01-2008 12:26 PM
Scratches in big Plexiglass window Filbert V. Care and Feeding of Molded Fiberglass Trailers 16 04-22-2007 11:12 AM
Cleaning plexiglass james kent Care and Feeding of Molded Fiberglass Trailers 4 04-22-2006 07:12 AM
Plexiglass Cleaners?? Byron Kinnaman Problem Solving | Owners Helping Owners 10 01-06-2006 12:57 AM
