plexiglass window seal - Fiberglass RV
Old 05-24-2019, 05:51 AM   #1
FL
Hello - I am going to replace the seal on my plexiglass windows of my 1974 Scamp 13. Do you all use the lockstrip sold directly by scamp? Or is there somewhere else I can get it cheaper?
Thanks!
Melanie
campermelanie is offline   Reply With Quote
Old 05-26-2019, 03:53 PM   #2
Trailer: 13' Scamp / 1983
Montana
Melanie - I purchased the gasket directly from Scamp and had the new Lexan windows (front and rear on my 1983 Scamp) installed at an automobile windshield replacement business. The business carried an identical gasket, and it was priced similar to Scamp's, so you might be able to purchase one locally and save shipping time and expense.
There is also an inexpensive tool which is recommended to help with the job. If you do a search in the forum, you'll come up with several threads relating to the replacement and the exact tool.
I'll give you a heads up that the windows can easily still leak after replacement, so do your research for additional gasket sealers, etc.to be applied in the gasket before you start. I've had mine back to the shop twice and they still leak some.
Julie in Montana is offline   Reply With Quote
Old 05-26-2019, 06:33 PM   #3
IllAnnoy
That gasket is still in common use for replacing flat glass in
heavy equipment, like backhoes, cranes and payloaders.
Any full service glass place should have it in stock.
Installing plexiglass windows/rubber seal katycamp Problem Solving | Owners Helping Owners 7 04-13-2018 09:08 AM
Broken plexiglass window Jbfolger Care and Feeding of Molded Fiberglass Trailers 2 10-26-2012 03:07 PM
Window Gasket, Window Seal, Window Molding D Shubel Problem Solving | Owners Helping Owners 9 05-16-2011 04:30 PM
Cleaning Plexiglass Front Window Vivian Problem Solving | Owners Helping Owners 5 05-05-2008 07:57 PM
Scratches in big Plexiglass window Filbert V. Care and Feeding of Molded Fiberglass Trailers 16 04-22-2007 11:12 AM
