PLS help with installation with roof top AC for 13' scamp! - Fiberglass RV
Old 08-21-2012, 11:02 AM   #1
Trailer: Scamp 1999 13' Standard
Ohio
Hello!
Well, we went ahead and found a 13.5 BTU unit online (roof top) AC unit for our 1999 scamp.
However, when I called the factory to ask if they had any suggestions about doing the electric, etc. he said that when the factory sells them with AC units in the roof they are supported more. Apparently that means this one isn't full supported to have a unit installed in the rooftop.
He said it CAN be done, but noone from service was in until tomorrow.
Is there anyone else who has installed this on the roof of a 13' unit that did not COME with AC?
I had no idea this would be a problem and now we have a $550 unit arriving tomorrow......
please help!!!!!!!!!! TIA!
Jeanne
jwannacamper is offline   Reply With Quote
Old 08-21-2012, 11:20 AM   #2
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
I assume by "supported" you mean structural reinforcement to the roof rather than "represented as being designed for AC installation and so warranted" or whatever the boilerplate would be. You can't possibly have any warranty left on a '99 trailer so on that angle you're free to cut and try but you will be happy that you found out in the long term. So put the carton in the garage until you get the gospel from Scamp and have the work done. Or send it back and eat the shipping and restocking fee. Or resell it. I don't think you'd feel any better if you hadn't discovered this until a diy install failed.
jack
Old 08-21-2012, 11:30 AM   #3
I only have bad news. I have read on this forum before that those roofs were not made to support AC. I went to Scamp's website and found this link that basically said something similar with more details.
Sorry...
ericw is offline   Reply With Quote
Old 08-21-2012, 11:59 AM   #4
Its true unless your Scamps roof was built with the reinforced roof its not going to work out well. Perhaps someone else has solved the problem but I have a hunch its not going to be a real easy fix..... may involve a lot of fiberglass work on the roof for starters. I know that others who have put in after market ac's often mounted them in the lower cabinet area for that reason.
Jeanne, on the links that were provided to you previously on this topic, roof vs window mount - post #11 indicated what would happen if you put a roof mount on a scamp that was built originally with one.
Old 08-21-2012, 03:50 PM   #5
Ohio
Oh no...
and Carol when I posted the question about the AC I don't recall seeing anything that said no to a roof AC or a red flag, I must have missed that. I don't want one in the window and we don't really have room for one in the side. And I didn't want a big one sitting inside a 13' scamp....it would take up the entire space.
I wish the company who sold it (and another one locally that I told what it was going into) would have raised the question of support.
I can only hope and pray that the technicians can help. The man said it CAN be done, but my husband isn't a fiberglass guy (altho he can do almost anything)....I feel like a fool that I didn't catch this.
Old 08-21-2012, 04:58 PM   #6
Trailer: 77 Scamp 13
Bummer!
My guess is that Scamp would avoid any modification for AC that was too radical, they would not want to have totally different manufacture process for building roof top AC model of camper.
Thinking it through there are only a few ways to prevent sagging.
  • Thicker material. ( 1 inch board will sag less than 1/2 inch board given same load and span)
  • Ribs or ridges to stiffen. ( the ridges running front to back on scamp roof help make it stiffer on it's longer span)
  • Shorten the span. ( a 3 foot board will sag less than a 6 foot board of same thickness under the same load)
  • Load transfer. (corner braces, or the closet being attached to both wall and roof)
You can see examples in the scamp, closets shoten roof span as does the twisted metal support for cabinets. Ribs formed into roof, or the metal bar on hinge side of door provide extra stiffness where needed.
I'm hoping they did not go with the easiest from the perspective of manufacturing, just add thickness to the roof, that would be hardest to do as a modification But they could have done multiple things. Thicker roof, ribs of some sort at opening, vertical support in the closet to shorten the span.
Hopefully since they said you need to talk to the techs, there is some option available.
Old 08-21-2012, 05:06 PM   #7
Installed in the bottom of the closet seems popular location, you lose some storage but is stock location on many scamps.
The other place that is sort of unobtrusive is in the back wall so it comes out under the dining table, supported by the bumper. Using a remote control that might not be too bad. Especially if you leave your dinette as a bed most of the time.
Old 08-21-2012, 05:42 PM   #8
cpaharley2008's Avatar
I think she ordered a roof only mount, why 13.5 for a 13' footer is beyond me, it will make it into a meat locker. Hopefully she can resell it at a small loss. Another 7 P's lesson
learned here.
Old 08-21-2012, 05:47 PM   #9
learned here.
You have a point, had not noticed the 13.5k btu, I think most folks get away with 5k or 6k in a 13 ft.
So what are the 7 P's?
Old 08-21-2012, 06:09 PM   #10
Ohio
learned here.
Wish I would have heard this information on my original thread asking for help finding a smaller unit. Oh well guess it's a learning curve. :/ Besides we don't really know any RVers. And when I contacted a local supplier telling them what we have and what we think we wanted there was no comment about this being too much, even tho I asked didn't this unit seem like it produced too much for a small trailer?!
I am sure we will have to return it and figure something else out at this point.
Thanks for everyone's input.
Old 08-21-2012, 06:34 PM   #11
Jeanne,
This forum is for some guidance and help but should not be relied upon solely in you making decisions. You need to become an informed buyer and will after ownership. You have 10 posts so hopefully 200 more will make you more knowledgeable. Do you belong to the Scamp forum also a good source of information. If I had read your question I may have suggested an alternative, but there are over 100 new posts here daily. There is also rv net- another forum. I belong to a half dozen and learn from all of them.
Old 08-21-2012, 06:41 PM   #12
Ohio
Thanks. After this challenge, I think we'll be fine. I just wish I would have called Scamp. I didn't think a thing b/c I see lots of pictures with scamps - with roof AC units mounted.
Live and learn. I'm just sorry I didn't do more research.
Hopefully we can return with shipping costs b/c I completely talked to the guy about what it was going to be installed in and told him I was unsure of the under unit. Had I known (and seen a picture) of the size of that thing I would have thought twice.
Oh well, live and learn like I said. Thanks again for all the help.
Old 08-21-2012, 06:44 PM   #13
Ohio
Sorry...
Eric! More reasons why I should have consulted Scamp, dag! Thanks for posting!
Old 08-21-2012, 06:47 PM   #14
rabbit's Avatar
Delaware
P[roper] P[rior] P[lanning] P[revents] P[**s] P[oor] P[erformance. One of the problems with queries to an interest group is that no one may be all that interested on the day you need help and the next day the answer to your prayers may show up. Take multiple polls. Let things percolate. Read the literature. Identify the expert (if you can) and steal from the best. In the meantime, study specs, formulae, rv books, Google every subject for the Ah-has, the caveats, and the "don't go theres."
jack
pls help with small ac unit for 13' scamp?! jwannacamper Problem Solving | Owners Helping Owners 3 08-14-2012 07:14 AM
Roof top airconditioner Brian E Moon Modifications, Alterations and Updates 7 08-08-2012 10:07 AM
Fantastic Fan spacer installation on top of a Boler kevin61 Modifications, Alterations and Updates 1 07-05-2009 05:55 PM
boler roof vent installation charlenep Problem Solving | Owners Helping Owners 1 05-24-2009 09:14 PM
Roof top A/C for 13' Boler Fred B Problem Solving | Owners Helping Owners 2 03-24-2009 06:58 AM
