Poor fit of Scamp door. - Fiberglass RV
Old 09-25-2010, 08:20 PM   #1
Mark G.'s Avatar
Trailer: 16 ft Scamp
I must say…. When my Scamp door was hung at the factory the person that did the work must have been drunk or stoned.
The upper hinge was OK but the lower wasn't even close to horizontal. All in all the entire door was not straight.
It wasn't even cut correctly…..
The unfinished front edge had a wave you could surf on.
Anyway……
Today I removed the door, put a tape line on the long sides, worked them over with my grinder and re-drilled the lower (door side) hinge holes.
The result……
Now my door has parallel hinges, straight sides and fits the door frame correctly.
Took about an hour.
Mark G. is offline   Reply With Quote
Old 09-25-2010, 08:39 PM   #2
Pictures?
Old 09-25-2010, 09:02 PM   #3
Mark G.'s Avatar
Originally Posted by Donna D. View Post
Pictures?
Yes….. I should have thought of that before hand.
Really, the difference is very subtle but the door glides open and closed now.
Before, the springs in the lower hinge would make noise and bind.
Old 09-25-2010, 09:08 PM   #4
The year of your trailer isn't in your profile, so I haven't a clue how old the trailer may be..... Did you replace the brass in the hinge before you rehung the door?
Old 09-25-2010, 09:38 PM   #5
Mark G.'s Avatar
Oh sorry. My scamp is a 98. An unused 98 (camped in twice).
Hinge hardware is as new so I didn't replace.
Old 09-26-2010, 06:14 AM   #6
Trailer: 2009 Scamp 16 ft / 2014 Ford E-250 cargo van
Putting a little lube on the brass ball helps with the binding and noise.
Bill K
Old 09-26-2010, 06:49 AM   #7
Sounds like a great fix. Come on down to the NOG and show off your solution! NOG - N. Oregon Gathering - October 8-10, 2010
Will a Scamp 13' fit through a standard garage door? Robby Bricker Care and Feeding of Molded Fiberglass Trailers 12 05-11-2015 03:35 PM
Improving door fit due to body sag Roy in TO Modifications, Alterations and Updates 41 06-02-2013 05:25 PM
Will this fit my Scamp? Russ V. Problem Solving | Owners Helping Owners 7 04-13-2008 08:23 PM
POOR POOR BUNNY !!! Dan Quinn Jokes, Stories & Tall Tales 1 05-02-2006 05:56 PM
