Pop rivet question - Page 2 - Fiberglass RV
Old 12-09-2012, 08:42 AM   #15
I had a problem with the round inserts turning in the hole, so I use the square ones. Used a small square file to shape the hole.
mary and bob is online now   Reply With Quote
Old 12-09-2012, 09:02 AM   #16
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Great idea. I've found lubing the thread helps along with using an electric screw gun, but square definitely is best.
Old 12-09-2012, 11:46 AM   #17
Sue and Henry's Avatar
Name: Sue and Greg
Trailer: 1982 Burro 13 foot and a 2015 Casita Spitit Deluxe 17 ft.
Francesca, no pretty rocks for me after your story! Thank you Mary and Bob and Thomas. I'll watch for loosening. I know the whole thing moves a lot when we wander down the road.
Sue and Henry is offline   Reply With Quote
Old 03-14-2013, 05:59 AM   #18
Trailer: 1980Trillium 1300
Pop rivet
Here is my suggestion and through my own experiences, it would work on any material(alum, fiberglass, steel, wood, plastic...). Make sure the length of rivet is OK, put a proper washer in the other side of rivet before pulling the trigger. In my case, most of the times, I use the heads of old rivets when I drill them out for repacement as washers for new ones... Give it a try, Buddy...
Old 07-07-2017, 11:06 AM   #19
scamps and rivets
hi, the mention of rivets with scamps reminds me that i better get set up for it. is there a standard rivet size for use with the scamp? mine is 2004.
thanks,
jon of sequim
jondsw is offline   Reply With Quote
Old 07-07-2017, 11:30 AM   #20
If you are fitting a wood shelf then fit it carefully, hold it in place and mark top and bottom.
Drill a hole between the lines and then use a stainless steel screw with a dab of sealant under the head and screw it into the shelf.
Stronger more leak resistant and will ass support to the shell as well.
If yoy want it even stronger run a bead of PU sealant around the shelf abd screw and glue it in place.
To get a really good bomd cut out the Ensolite insulation, rough up the glass and glue.
I did my whole 16' Scamp rebuild this way
Old 07-07-2017, 01:18 PM   #21
Originally Posted by Sue and Henry View Post
Ah. I'll bet that's it. I figured I needed stainless steel. Maybe I'll switch out for aluminium.
Hand riveting stainless steel larger than 1/8" diameter is going to be difficult to pull with a hand riveter.
But don't forget you can rent power tools. The advantage to that is you know you need to work quickly and get them all done in one short session to minimize your rental fee
Old 07-07-2017, 02:55 PM   #22
Roy in TO's Avatar
Or there is a heavy duty one from Harbour Freight for $20 on sale
https://www.harborfreight.com/heavy-...tle-66422.html
https://www.princessauto.com/en/deta...ol/A-p8048882e
Power riveters (air) regular prices are regular priced at $80 USD or $100 CAD
They frequently go on sale as well
https://www.harborfreight.com/14-in-...ter-61482.html
https://www.princessauto.com/en/deta...er/A-p8549776e
Pop rivet gun... clearcut Problem Solving | Owners Helping Owners 8 11-10-2012 09:20 PM
Pop Top Camper Question melissab General Chat 8 02-10-2011 10:16 AM
Rivet gun question DannyH Problem Solving | Owners Helping Owners 12 01-11-2010 05:09 PM
Rivet Question Gail Shook Problem Solving | Owners Helping Owners 9 09-26-2008 04:02 PM
Rivets, rivet caps, rivet gun BOBSMITH Care and Feeding of Molded Fiberglass Trailers 7 06-11-2008 09:24 PM
