Porch Light - Fiberglass RV
Old 06-09-2003, 06:56 PM   #1
Porch Light
Hi everyone!
Trying to fix all the bugs in my new purchase and noticed that the porch light does not work. I tried a new bulb and also cut and re-spliced the two wires in the light housing. The bulb was old and worn, so I just matched one up from Walmart.
Anyone have a clue as to what # bulbs are needed for this and the other ones? All of the numbers are either worn or missing on the bulbs.
To the porch light. Has anyone replaced one of these and have any clues as how to install them? Looks like they are riveted to the shell. There does seem like there was a little condensation inside the housing. Then again, I tried a voltmeter to the bare wires and didn't get any readings at all.
Thanks in advance!
Old 06-09-2003, 07:27 PM   #2
porch light
Dave:
My 2000 had the porch light go bad in one year. It gets all the runoff from the door gutter.
No problem to replace. Drill out the rivets. A new fixture is cheap.
Put come caulk across the inside top of the new fixture. :)
Old 06-09-2003, 08:17 PM   #3
Don,
Thanks for the answer! I will call Casita and order one (along with a few other odds and ends).
Old 06-10-2003, 06:19 AM   #4
Camperschoice.com
Extra fixture is M121 at Campers Choice. They come with a clear lens. Add the amber replacement lens (M151). Helps reduce the bugs! Total $7.75 + shipping. This same lens is a direct replacement for the ones on Casitas. (Some other lenses look like they will fit, but tabs must filed down to fit.)
Old 06-10-2003, 07:53 AM   #5
George- thanks for that info! I bought what you reccommended and a few other things. Pretty good prices at that site.
Old 06-10-2003, 08:55 AM   #6
Light
Dave,
Do a search on Porch light. I've been documenting my porch light troubleshooting process etc.
Old 06-10-2003, 09:50 AM   #7
Walmart sells those porch lights. Come with both clear and amber lenses. Under $10. cdn
Nancy
Old 06-10-2003, 10:05 AM   #8
Lamp Numbers
quote: < Anyone have a clue as to what # bulbs are needed for this and the other ones? All of the numbers are either worn or missing on the bulbs. >
Dave,
Here is a link to a light fixture/lamp number table I created a while back. The information was taken from my '99 SD Casita.
http://forums.casitaclub.com/thread_view.c...cfm?Thread=4521
Old 06-10-2003, 10:21 AM   #9
Nancy- thanks for the heads up. I am doing a Walmart run later today and will check it out.
Jim- that's an awesome list to keep handy. Much thanks!
lighting, lights, porch light
3-Way Porch Light peterh Modifications, Alterations and Updates 23 01-21-2011 04:43 PM
What do you think of this as a porch light? Donna D. Care and Feeding of Molded Fiberglass Trailers 18 09-21-2010 07:50 PM
Solar porch light Mike Taylor Modifications, Alterations and Updates 21 08-28-2010 12:48 AM
Porch Light Kevin K General Chat 15 08-11-2008 01:59 PM
Added a Porch Light Jayson Wall Modifications, Alterations and Updates 6 07-11-2007 07:42 AM
