Portable Propane Heater - Page 4 - Fiberglass RV
Old 02-01-2013, 09:13 AM   #43
santacruzer's Avatar
Trailer: Escape 19
There was a tent heater on the market several years ago that intrigued me, and I was toying with the idea of adapting my first tent trailer, which had no heater at all, to utilize something like this. Made by Zodi, the same folks who make the portable shower. They had a few heater models. For some reason, or maybe a lot of reasons, they're all no longer available. There's still a link up on their web site, however:
Zodi.com tent heaters The safest tent heater EVER! *over 40 camping comfort products
I can appreciate several inefficiencies of having something like this OUTSIDE your tent or trailer, but it looked like a safe solution on one level. I'm still hoping to find one at a flea market or garage sale someday, but for another purpose other than the trailer.
2009 Tacoma 4DR TRD 4wd
2007 Tundra 4DR TRD 4wd
2012 Escape 19
2007 Norwegian Elkhound "Baxter"
santacruzer is offline   Reply With Quote
Old 02-01-2013, 09:21 AM   #44
Originally Posted by santacruzer View Post
And I don't totally trust CO detectors. Here's a link I uncovered when I was looking into placing a CO detector in a building, per our new California law requiring them. Apparently the science of good CO detection is still developing. The next to last paragraph spells it out, some are reliable, some ain't. Bottom line for me is...don't put all that much faith either the heaters, their safety devices, or the alarms designed to alert you.
Sound advise! Since you posted the above I went looking for an email I received from one of the larger RV websites on the topic of CO detectors in the last year or so. I must of deleted it but as I recall it indicated that many of the CO detectors found in RV's do not alarm until well over 50 ppm, leaving many with a very false sense of security. The advise they gave was to test your detector at least twice a year, replace it every 5 years. If you have a brand that you cant find a lot of consumer testing reports on replace it with one you can and pick the one that consistently makes the highly recommend lists.
Old 02-01-2013, 09:55 AM   #45
Trailer: Escape 19
The instructions on the CO detector in my Escape specify testing it before every trip, and after any period of storage. The problem is, all most of us can really test for is a dead battery! Who knows if it's calibrated correctly? Certainly no one in MY circle of friends! Consumer Reports did an article and some comparisons a while back, and made the point that having one IS better than not, choose carefully, locate properly (NOT near the stove or heater), and replace regularly. To my embarrassment, I must admit I have not checked the brand that was installed in my trailer!
2012 Escape 19
Old 02-01-2013, 01:31 PM   #46
Brian B-P's Avatar
Everyplace this subject comes up, the famed "2002 catalytic heater study" comes up, too- as if results from the testing of a single tiny model of a type predating low-oxygen shutoffs is of any value in a discussion of modern, safety-shutoff equipped catalytic heaters.
Yes, it is of value, because the misinformation that this reference was provided to combat is the idea that catalytic heaters magically produce no carbon monoxide (or significantly less than non-catalytic designs) in normal operation. Low-oxygen shutoffs - which do not even exist on most of the models of catalytic heater discussed in this thread - don't come into play until long after the heater has produced measurable CO.
Who among y'all has actually read that oft-referred to study?
I only skimmed it and read selected sections.
And, more importantly, the much bigger study of which this was just an offshoot, the concurrent examination of radiant propane heaters? (Link) That's by far the more important and relevant study in any discussion of portable propane heaters
This document is freely available from the CPSC; there is no need to go through .docstoc
The report specific to the catalytic heater is essentially an extract of the parts of the full study which are relevant to catalytic heaters. Since the subject for which I provided the reference was the behaviour of catalytic heaters, it was the more relevant document. I apologize if I confused anyone by this selection.
Properly designed, EQUIPPED, maintained, and operated propane heaters of both kinds, if approved for indoor use, are perfectly safe to use indoors...
I never claimed any of these heaters were unsafe, although nothing (even a outside-vented furnace) is perfectly safe. Remember, as Carol has reported, that safe indoor use of an unvented heater is never unattended. Also, conditions which do not trigger a oxygen-depletion shutdown still involve generation of carbon monoxide, as shown in both of the CPSC reports.
Old 02-01-2013, 08:48 PM   #47
Mike Magee's Avatar
Trailer: Li'l Hauley
Next we can talk about the dangers of generator combustion emissions... when the wind changes and blows exhaust fumes toward and into the trailer.
How to prepare Tofu
Step 2: grill some meat
Old 02-17-2013, 05:49 PM   #48
EddyEd's Avatar
Trailer: 72 Cloud
Wisconsin
I bought the middle sized Mr. Heater "Buddy" right before winter and have used it numerous times in my 13' Cloud and it is wonderful. I bought the 20# hose and regulator for it as well and just put the tank outside the door and run the hose up under the door (I have a small gap from age, its a '72) and the heater goes just inside the door. Warms the camper up warm enough to take my jacket off when it is nearing the 0 mark outside. My propane heater that is built into the camper couldn't even get it close to that warm even when it was still 30 out so I am very happy with the "Buddy". Yes I get some condensation but I was getting condensation anyway so that is just something I have learned to live with when the temps drop below 40. I always keep a window cracked and the top vent open an inch or two and it still stays comfortable in the camper. Keep in mind my idea of comfortable mind you is I can take my jacket off and not be in pain from the cold. I also never run my "Buddy" at night when I sleep, I know lots of people do but it scares me and I save a lot of propane by turning it off when I am asleep. I use a very well made mummy bag and stay toasty warm all through the night. Just an fyi as well I was able to get about 5 or 6 days out of my 20# tank with temps fluctuating between 35 and 0 all week, not running it at night, and turning it down to low most of the time. I will be removing my original propane heater before the spring thaw in order to make more storage room and using nothing by the "Buddy" from now on.
EddyEd is offline   Reply With Quote
Old 02-18-2013, 07:40 AM   #49
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Sounds just about like my experience, Tyler!
I'll never go back to a "conventional heater", either.
Francesca
Old 02-18-2013, 08:54 AM   #50
Trailer: Bigfoot 1981 Trailer
I have a few propane hoses that I plan on using for the Buddy Heater. Is a regulator needed or is built into the heater.
Old 02-18-2013, 09:04 AM   #51
EddyEd's Avatar
Trailer: 72 Cloud
Wisconsin
You need to get a regulator/filter (is that the same thing?) according to the manufacturer it scrubs the oils/rust/dirt from the propane which you might get from the bigger tanks and keeps the inner workings of the "Buddy" from getting clogged up and ruined. The one I bought was like $8 from Menards on clearance.
I have read posts from other "Buddy" users thought that state they have never used the filter attachment and they have never had a problem. I like to be cautious though, nothing like ruining a good camping trip because the heater broke.
Old 02-18-2013, 09:21 AM   #52
RLP
Trailer: 72 Boler
The Buddy's have a built in regulator. That's why you can use them with a standard 1 lb bottle or larger which are at high pressure. The built-in regulator reduces the pressure accordingly to fit the pressure requirements of the heater.
The filter is a separate screw-on device which attaches between the regulator and bottle or hose. I agree with EddyEd, an inexpensive add-on to make a "happy camper".
RLP is offline   Reply With Quote
Old 02-18-2013, 09:22 AM   #53
Thanks for the reply. I just contacted the manufacturer and using a 20 lb. tank with a hose only requires the filter, which is also a regulator, so an additional regulator is not needed and should be changed once per year. This filter is necessary as using the heater without it could plug up the heater.
Old 02-18-2013, 11:01 AM   #54
A question for Buddy Heater users:
My hard-plumbed heater is one that can be used directly off the trailer's gas supply/regulator. Can the (regulator-equipped) Buddy be used that way or must one use a separate "unregulated" gas supply?
I ask because inside trailer pressure is already regulated, and it's my understanding that this can cause problems with gas equipment that already has its own regulator.
Thanks!
Francesca
Old 02-18-2013, 12:07 PM   #55
Thanks!
Francesca
I would call customer service and ask that question. 1 800 251 0001....let us know what they say....Jim
Old 02-18-2013, 05:00 PM   #56
RLP
Trailer: 72 Boler
Francesca - As far as I know, many if not all propane appliances need regulated pressure of 11 inches W.C. (water column). This equates to a very small pressure of approx 0.5 PSI. The 11 inches W.C. has a very small leeway - something like 10.5 to 11.5 W.C. Using two regulators in the same line will drop the pressure way to much and the device will not work, period.
I use the Portable Buddy which has a built in regulator so I run it off a standard 20lb bottle. I can only assume the other Buddy models have a built in regulator as well.
I have a similar situation as you in that my fridge and cook top are receiving regulated pressure from the main regulator near the tank. To use the Buddy from the same tank I installed a T fitting on the gas inlet side of the regulator. This gave me an additional outlet (high pressure) to which I attached a small brass shut off valve (ball valve) and a long propane hose that goes to the heater. I also use a propane BBQ outside the trailer, again with built in regulator, and simply move the long propane hose from heater to BBQ as needed. Works like a charm.
When I pack up to hit the road again, I close the brass shut off valve at the main regulator, disconnect the long hose and stow it away.
propane
Portable propane shower Brian Tin Problem Solving | Owners Helping Owners 26 01-09-2011 08:07 PM
Portable Propane Barbara Gardin Problem Solving | Owners Helping Owners 18 10-16-2008 10:00 PM
Portable Propane Heater to Blame? Byron Kinnaman General Chat 1 10-31-2006 04:44 PM
Portable Propane Instant Water Heater UncleJosh General Chat 24 03-20-2006 12:15 PM
Mr. Heater Buddy Portable Propane Heater Legacy Posts Problem Solving | Owners Helping Owners 16 08-03-2003 12:01 PM
