Portable room AC in camper? - Fiberglass RV
Old 02-16-2019, 11:18 AM   #1
Trailer: 2019 Scamp 13' with 2015 Nissan Frontier V6
Alabama
My 13' Scamp did not come with AC. Has anyone ever tried using a portable room AC in their camper? If so, did it work? I am talking about the type of portable AC that is free standing and is vented with tubes out a window.
I found one on Amazon that only uses one tube for venting and thought that might work.
Thanks!
Vicki
Vicki Hale is offline   Reply With Quote
Old 02-16-2019, 11:38 AM   #2
Raspy's Avatar
Trailer: Black Series HQ19 on order
Smith Valley, Nevada
I have one with a single tube, in my guest house, about 400 sq ft. It draws a lot of air from the room to expel it's waste heat outside. So, you'll end up leaving a window open and exchanging a lot of air with the outside. Kind of counter-productive. I'd say it will only be marginally effective. A twin tube one that pulls in outside air to cool itself, might be better. A window type unit would probably be much better. Look at how Little Snoozy does theirs.
Raspy is online now   Reply With Quote
Old 02-16-2019, 08:42 PM   #3
Alabama
Thank you John
Old 02-17-2019, 10:58 AM   #4
RJnNC's Avatar
Trailer: 1982 Burro 13'
Vicki, a friend of mine had her free-standing A/C installed in the closet of her 13' Scamp, exhausted outside using a dryer vent. It worked great, so I'm planning on doing the same thing with my 13' Burro.
RJnNC is offline   Reply With Quote
Old 02-17-2019, 11:07 AM   #5
Trailer: 1972 Boler 13
AC
I use a small window air conditioner that is set on a board and tent poles. The board has holes drilled to allow the tent poles to stabilize. I removed the side windows to do this. Traveling I have a plexiglass window fitted to the opening. I have done this for 8 years after a young man looked at my elaborate venting system and suggested I just do this ( thanks Bryce !) The gap around the ac I have filled many ways, the simplest being clear packing tape.
adkboler is offline   Reply With Quote
Old 02-17-2019, 01:23 PM   #6
Mike Magee's Avatar
Trailer: Li'l Hauley
It will work, but only if you get a 2-hose design... one hose for intake and one hose for exhaust. I tried a 1-hose portable in my Hauley, and the vacuum was so great I could hear the whistling as it sucked air in around the door gasket. I basically had to leave the door ajar a bit for the AC to breathe. So it was sucking hot air in from outside as fast as it generated cool air.
The other problem is space: where to put it in your 13'. If that's a problem, consider either a 'window' AC or a 'mini split' AC like this https://www.walmart.com/ip/RolliCool-10-000-BTU-Mini-Split-Air-Conditioner-Access-Cooling-Dehumidify-Auto-Fan-Modes-via-App-Remote-450-sq-ft/573438420
I intend to get one of the latter for this summer's camping.
In the '60s, people took LSD to make the world seem weird.
Now the world is weird, and people take Prozac to make it seem normal.
Old 02-17-2019, 05:24 PM   #7
Trailer: Boler 13' 1974
Portable A/C
Have a free stander in our 13 Boler. Vents through adapter plate using eye-brow window above stove. Can hang meat in there!!
Butsky is offline   Reply With Quote
Old 02-17-2019, 07:18 PM   #8
Alabama
Thanks Ronald.
Is your AC the 2 tube style or the 1 tube style?
I was thinking of using the window over the sink for the exhaust as well.
Vicki
Old 02-17-2019, 07:20 PM   #9
Alabama
Thanks RJ.
Is hers a one hose style?
Old 02-17-2019, 07:21 PM   #10
Alabama
Thank you Kathy
Old 02-17-2019, 07:32 PM   #11
Alabama
Thanks Mike.
Do you plan on mounting the outside unit to the trailer frame or hooking it up on site? I looked at those mini-splits but did not know if they could withstand the road travel if on the frame.
Old 02-17-2019, 08:40 PM   #12
Trailer: Hymer Touring GT
Illinois
You're in luck, as this topic has been brought up before. I was searching last week for experiences as we were hoping to get our hands on a Bigfoot without AC and thought that barring a rooftop install, one of those portable units might fit the bill--if we could afford to give up the floor space. My parents use one at their place to cool their master bedroom during the summer. Same one they had when I still lived at home and it cooled my room just fine (they had a window AC in their room). But they are still running whole house AC, just set at 78, so that unit is only augmenting what the house is providing, not cooling straight from 96 degrees and humid.
I will include a series of links below discussing the pros and cons of various portable AC methods. They include a variety of solutions--window AC in the window, window AC in the closet, portable AC in the trailer, portable AC outside. Somebody even put a ductless AC unit in a Scamp with the compressor on the tongue. The consensus, as Raspy said, is a two hose portable model inside the trailer; the window AC unit also seems to be a popular option, but I would rather give up floor space than a view.
Portable Air Conditioner
Portable Air Conditioners
Venting portable AC into RV
Air Conditioning a MUST?
Portable air conditioners?
Anyone using ClimateRight AC?
P.S. I don't know how the FGRV forums parse their links, but I promise you those are all related to portable air conditioners. If you don't believe me just hover over them and see where you're being pointed to!
Justus C is offline   Reply With Quote
Old 02-17-2019, 09:03 PM   #13
Portable A/C
Ours is the single large hose. I fashioned some cheap ductwork into an adaptor plate which friction fits onto the window frame. I posted pics of this last spring or so. Only drawback, a bit noisy. Cools down our "Shellie" very quick, and on only periodically. When not needed, we just leave the unit off our "dance floor" and stow in tow vehicle until needed. Others who have seen our set up, love it!
Old 02-17-2019, 09:08 PM   #14
A/C pic, in Boler
ID:	127957. Sorry about angle
portable toilet and portable shower Ruth G Plumbing | Systems and Fixtures 8 04-20-2012 12:36 PM
FGRV as Play room/ Guest room CharlynnT General Chat 5 09-19-2010 09:43 AM
Add a room - screen room enclosure for awning John Carter Classified Archives 0 08-10-2010 06:06 PM
Wanted 8ft trimline awning screen room or add a room Rob H Classified Archives 0 06-08-2010 09:35 PM
Looking for Add-A-Room - Bug Screen Room Deb & Chuck Classified Archives 5 03-19-2010 11:11 PM
