post winterizing - Fiberglass RV
Old 10-23-2006, 07:24 AM   #1
Joe MacDonald's Avatar
I just installed a water heater bypass kit, and a permanent pump bypass for the anti-freeze pick-up.
I blew out the water lines, I filled 'em up with the pink stuff, now do I close the taps or do I leave them open?
My anti-freeze is rated -40, and it is not unusual to see -45 here.
Old 10-23-2006, 07:53 AM   #2
Chris Z's Avatar
Trailer: 16 Scamp, 17 Casita, 21Bigfoot now
Last year, I blew out the lines then put pink stuff in them and then I blew them out again. Why not get rid of the pink stuff now instead of waiting for spring?
I haven't seen this mentioned but why not if maybe you think the pink stuff might leave a taste?
Chris Z is offline   Reply With Quote
Old 10-23-2006, 11:19 AM   #3
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 2004 Airstream Interstate 22' B-van
Iowa
It really doesn't make much difference, Joe. Leave 'em open if you'd like I guess! I leave mine closed when filled with pink.
Chris, you can blow it out if you want, but its really easier just to flush it with fresh water in the spring on your first camping excursion. The anti-freeze really doesn't have a taste. I winterized the Big Bigfoot last week 'cause we had some sub-freezing temps, and then we used it Weds thru this morning. I just flushed the lines out with fresh water after filling the tank, and we were good to go. I dumped the tanks this morning, and let the fresh water tank and water heater drain themselves out. I'll re-winterize with pink antifreeze after work tonight.
Roger
Old 10-23-2006, 12:31 PM   #4
Brian B-P's Avatar
If a plumbing system is filled with water which might freeze, then leaving a faucet open would allow for some expansion during freezing, perhaps preventing damage. With a system which is mostly full of air, it's easy for the air to compress and expand, so I don't see an advantage to leaving the taps open - and the pipes will stay free of unwanted visitors if there's nothing open.
So, with air in the lines near the faucets, I'm guessing that it's not a big deal either way.
Winterizing Bigfoot Mike Care and Feeding of Molded Fiberglass Trailers 0 10-11-2006 10:32 AM
Winterizing Gerry Care and Feeding of Molded Fiberglass Trailers 27 10-11-2006 07:08 AM
Winterizing stevenff Problem Solving | Owners Helping Owners 7 11-29-2005 08:51 AM
"De"- winterizing Legacy Posts Care and Feeding of Molded Fiberglass Trailers 6 06-05-2003 02:44 PM
Winterizing Legacy Posts Care and Feeding of Molded Fiberglass Trailers 10 09-20-2002 09:09 AM
