Power converter on 85 Scamp 16 - Fiberglass RV
Old 04-28-2019, 09:14 PM   #1
I replaced the original interior light in my scamp with led's. They work on 12v but do not work on 120v. After some checking with a multi meter it seems the polarity changes when you flip the switch on the converter. Is that normal? My scamp has a B-W Manufactures 3200 converter.
Edward T is offline   Reply With Quote
Old 04-29-2019, 07:33 AM   #2
That is not normal.
I would check the wiring from the converter as that would be a bad thing for the battery as well as the lights!
It should blow fuses when you turn on the converter it it is connected to the battery and it would definitely not charge the battery, either.
Old 04-29-2019, 07:47 AM   #3
Paul O.'s Avatar
Trailer: '04 Scamp 19D, TV:Tacoma 4.0L 4door, SB
In 1985 nobody cared about the polarity of the light fixtures, LED lights were a science fiction!
Plugging into shore power should not make a difference. Is the problem on all lights, or on some of them? If it is some of them, swap the wires feeding the fixtures, if it is all of them, there might be a way to swap the wires at the convertor.
Old 04-29-2019, 10:32 AM   #4
It is on all the lights. The range hood still works though. It does not blow any fuses either. Btw there is only one fuse and that is in the converter.
Old 05-05-2019, 08:52 PM   #5
Dan Meyer's Avatar
Check the wiring at the battery. If your wiring is stock, -->BLACK<-- is POSITIVE.
--Dan Meyer
Old 05-06-2019, 06:45 AM   #6
John in Michigan's Avatar
Ditto to what Dan Meyer posted, i.e., FIRST make sure the battery is wired to match the polarity of the converter. Next, if necessary, correct the LED light fixture wiring to match the battery and converter.
Trillium 4500 Journal
http://www.fiberglassrv.com/forums/f...nal-81345.html
Converter issue on 2010 16' Scamp power system Lamnidae Electrical | Charging, Systems, Solar and Generators 2 07-02-2018 11:11 PM
Power Converter-Scamp wiring? Bill Nolen Problem Solving | Owners Helping Owners 12 04-17-2016 07:46 PM
Scamp Power Converter Bill A Problem Solving | Owners Helping Owners 5 06-17-2007 01:44 PM
progressive Dynamics power converter Paddy Morris Problem Solving | Owners Helping Owners 4 04-30-2006 06:09 PM
Power Converter Legacy Posts Problem Solving | Owners Helping Owners 3 05-25-2003 07:02 PM
