09-26-2011, 07:33 PM
Trailer: 83 Burro
Problem with Condensation
Our second camping trip in our Burro 13'--had issues with condensation inside. Temps outside in the low 50s- had an electric heater going inside with the top vent cracked.
Condensation inside got the bedding wet where it comes in contact with the wall. Is there anything that can be done to combat the condensation? Are we lacking insulation? Any help would be appreciated. Ed in Michigan
09-26-2011, 08:29 PM
Your burro is a great trailer, but insulation may not be it's strong point. I suggest buying a roll of Ozite in the color of your choice at your local big box hardware store, then apply it around the wall in the bed area ( maybe from the base to the bottom of the window). It is a nice soft almost fabric rug which may act as a barrier in that area. Also as you have been doing, open the roof vent a little more and turn up the heat if you can . that will convect more heat ( leave the windows closed)
Trying not to breath might help but that's probably not practical.
http://www.ozite.com/rprod.cfm?item=rp7
BTW;
I know it may not be appealing to name your trailer with your own name,but I sure like the name "Edward our Burro"
09-26-2011, 09:09 PM
My Fiber Stream is single wall fiberglass shell with no insulation or interior wall covering. We always have fine condensation, but I keep the bedding dry.
We had 2 Thermarest Z-Lite Closed-cell Sleeping Pads left over from our tent camping days. I cut each pad into 5 pieces; along every other accordion fold, so I have a double thick row of barriers lined up vertically around the perimeter of the cushions/mattress pad/sheets/blankets so they do not come into contact with the fiberglass shell. We have a King bed in the Fiber Stream. You won't need quite as many pieces.
09-27-2011, 03:12 AM
Trailer: Bigfoot 17.0 1991 dlx
If you don't have a fan that would help move the air out.
09-27-2011, 05:02 AM
This may not fix your problem, but on our first trip out in our EggCamper (which is somewhat insulated), we had a lot of condensation. Then we learned that if you leave a vent or window opened about an inch, the condensation isn't a problem. Simple and free. I was amazed at how well this worked.
Ron
09-27-2011, 01:45 PM
i agree with ron f----keeping both a window open--or 2---at least an inch plus keeping the roof vent open has kept our condensation concerns to a minimum even in subzero temps. good luck.
09-27-2011, 03:05 PM
Trailer: 1972 Boler 13 ft
We bought some bubble foil insulation, cut to cover the outside wall about 4 or 5 inches higher than the cushions and slid down to the benches. It is easy to put in or take out according to the weather.
09-27-2011, 03:27 PM
Trailer: U-Haul CT13 ('Pearl')
I put the bubble insulation between the shells on my U-Haul. I had a little condensation, mostly on windows. It was in the 40's and we used no heat.
09-27-2011, 04:23 PM
Trailer: 83 Burro
Thanks for the tip Floyd! And.......that Edward "our" Burro is an excellent suggestion..I like it!
10-02-2011, 12:32 PM
Trailer: U-Haul 1985
Hey Ed, I camped at the same place as you, (at the TCT Ralley) and its interesting that I had no issues with condensation. Uhaul doesn't have insulation just like the Burro, and I also used electric heat and cracked the vent. I wonder if it is because there were 2 people in your camper giving off more heat and exhaling, etc?
10-03-2011, 06:53 PM
Trailer: 83 Burro
Could be the fact that there were two of us. We camped this last weekend at Hartwick Pines and temps hit the low 30s.........same issue with windows and skylight cracked. We used towels as a barrier......seemed to help. I think we're going to try a suggested barrier of carpet like material sold at big box stores...
10-03-2011, 08:58 PM
I've been thinking of doing something like that to give just a little extra insulation around the sitting and sleeping areas. I'll have to take a look at whats out there. This is the disadvantage of these 'smooth interior' trailers because they don't usually have insulation between the shells. Sure would be nice if there was a way to insulate between the shells. I've slipped bubble insulation behind my kitchen cabinets and pushed it as far out as possible to either side (and the same with my closet). but there are a lot of areas that I just can't insulate.
10-04-2011, 10:28 AM
I put a maxxi window vent in mine so I could keep a side window open a bit when its raining & I cant leave the roof vent open. Helped a lot with keeping the condensation.
Condensation....
FredericL |
4 |
05-13-2009 04:57 PM |
Condensation on walls
Gerry |
12 |
10-19-2008 02:36 PM |
Condensation
Valerie G |
2 |
01-22-2008 05:23 PM |
Condensation
bdiscount |
37 |
04-26-2006 03:15 PM |
condensation
Legacy Posts |
16 |
03-04-2003 06:37 AM |
