Problem with power cable hatch hole size - Fiberglass RV
Old 03-26-2016, 10:50 PM   #1
Trailer: '84 Bigfoot b17
Hi all you savvy f/g rv'ers,
I have a problem in that I want to replace my original power cable housing and hatch cover with one of these:
http://www.amazon.com/ParkPower-150B...ct_top?ie=UTF8
The original cable hatch housing leaked badly on the inside of the trailer wall...whether from driving or water coming down a suspended cable or... I don't know. It has to be fixed once and for all. Problem is.. The hole size in the trailer wall is 2 7/8" and all I can only find this new flanged receptacle type with a 1 7/8" opening required....big difference.
I just wanted a 3 screws and replace the housing unit (and rewire) job but REALLY not interested in having to fibreglass the big existing hole down to a smaller size. Maybe this is a bad plan. I thought eliminating one hole in the wall would be a good idea.
What have others done? Thanks a bunch!
John
Tyhee is offline   Reply With Quote
Old 03-26-2016, 11:38 PM   #2
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Others have made up a cover plate riveted to the shell to cover the existing area with the new hole size in that.
Borrego Dave is online now   Reply With Quote
Old 03-27-2016, 04:14 AM   #3
Raz
Raz's Avatar
Vermont
I had a similar problem with my water inlet. I made a plate, attached it using the existing holes, sealed with butyl tape. Raz
Old 03-27-2016, 04:39 AM   #4
Name: Ben and Janie
Trailer: 2013 16foot Scamp tug 2003 Ford Ranger
Kentucky
power cord adapter
I used the same kit you are looking at on my 2014 16 ft Scamp because I saw a mouse run up my power cord and into my Scamp very easy install no more mouse hole wish I had done it as soon as I got my Scamp home
Ben and Janie is offline   Reply With Quote
Old 03-27-2016, 08:19 AM   #5
Trailer: Casita 17 ft DLX SD
They make reducing washers . A pair of 2 1/2 to 1 1/2 electrical reducing washers may work . Not aesthetically pretty but functional and cheap
Old 03-27-2016, 08:44 AM   #6
Thank you all. A plate is what I will do as you have suggested. Now to rummage around for a nice small sheet of heavy abs plastic or something like that.
Old 03-27-2016, 08:48 AM   #7
Trailer: 2008 Casita 17 SD
I just wanted a 3 screws and replace the housing unit (and rewire) job but REALLY not interested in having to fiberglass the big existing hole down to a smaller size. Maybe this is a bad plan. I thought eliminating one hole in the wall would be a good idea.
John
Maybe I'm missing something here, but I see that you have a 17' Bigfoot. Don't you have a 30 Amp shore power/converter installed? And, if so, why would you even consider installing only a 15 Amp shore power entrance connector? Why not just let the moths out of your wallet and buy the appropriate replacement 30 Amp shore power male inlet plug and do it right?
Not that you may want to get this elaborate, (pictures below,) but the commonly installed power access hatches with the little "mouse door" flaps aren't the best. The reason they are installed is, like everything else from any trailer manufacturer, the cheapest way they can go to save a buck. They certainly aren't the best constructed hatches out there by a long shot. The "up side" is that you can replace them with a good quality hatch and not have to deal with the leaky crap the factory installed.
I cut the original opening out and installed a larger, actually usable, hatch, to replace that ridiculously small inaccessible one that is all but useless. Additionally, I cut the cord off from the converter and tied the ends into a newly installed shore power cord outlet with its own independent marine grade 30 Amp twist lock, By removing the permanently mounted cord and installing a 30 Amp twist lock female end onto it in the side of the trailer, I made the shore power hookup much easier, especially by not having to wrestle with it inside that small access hatch, or having it get caught on everything else that is inside of that area.
And if you are freaking out about cutting a hole in your trailer, just remember, every window, hatch, utility access opening, etc. have all been cut into your fiberglass trailer at the factory. They didn't sweat blood worrying about it, why should you?
30 Amp Shore Power Inlet Plug: http://www.westmarine.com/buy/marinc...-inlet--147454
Old 03-27-2016, 09:58 AM   #8
Casita Greg, thanks for the extra details, but I am pretty sure I am only playing with 15 amps on my 1984 Bigfoot. We are thinking along the same lines though ...the job will be done right and never leak again on my watch!
Old 03-27-2016, 10:11 AM   #9
Make sure the power inlet / receptacle is male not female . If you install a female in the side of your trailer then your trailer extension cord will have two male ends . When you plug the cord into the campground's pedestal the other end of the cord will have exposed metal blades which will be energized . Think of your trailer as an appliance , appliances have a male end on their cords for a reason.
Old 03-27-2016, 11:42 AM   #10
Yep thanks, understood Steve. I ordered the exact part in link above.
Old 03-27-2016, 12:06 PM   #11
Greg's receptacle is the best. You can get a matching watertight plug that not only plugs in and locks but also has a watertight screw connector.
Look here : Stuccu: Best Deals on Marinco 301EL B Buy Exclusive Deals 70 OFF Save Big Lowest Price On Marinco 301EL B Best In Stock Fast Free Shipping. Up To 70% off!
Best Shore power cable hotrodaj31 Electrical | Charging, Systems, Solar and Generators 4 04-22-2015 06:10 PM
Trillium '75 power cable Dietrich Electrical | Charging, Systems, Solar and Generators 10 10-28-2014 11:06 AM
Retractable AC main power cable BrandonC Modifications, Alterations and Updates 2 02-09-2013 05:19 PM
Square Cable Hatch Deb & Chuck Commercial Posts and Products 2 10-28-2012 05:47 PM
Wanted: Lil Bigfoot power Cable Hatch MsRubyLu-Kathy Parts: Buy | Sell | Trade 15 09-30-2012 07:16 AM
