01-16-2017, 01:30 PM
Problems with Fiamma awnings??
I'm thinking of replacing my non-functioning awning on my 13' Scamp with a Fiamma F45S. Anyone had problems with theirs?
01-16-2017, 05:05 PM
The Fiama is a good choice.
If your old awning is a Catalina 2500, save it. They have stopped production on it and some folks will need it for parts.
01-16-2017, 05:27 PM
I need parts
01-16-2017, 07:20 PM
Trailer: Escape
Fiamma F45s
We have this unit on our Casita Independence and have used it frequently over the past year as we covered 5,250 or so miles in a wide variety of weather. Once we were used to opening and closing it it proved a reliable, simple and fast awning to use. Generally we also hang a sunshade from one of the end rafters to provide protection from the sun since that often makes sitting outside a bit uncomfortable. All-in-all the Fiamma is an excellent addition to the trailer but be careful to take the time to retract it if it gets windy or you plan to leave it unattended since I can see that a strong gust could damage the aluminum framing pretty quickly. Good luck, Glen
01-16-2017, 07:24 PM
Trailer: Escape
Fiamma awning experiences
[QUOTE=Two Step;623723]We have this unit on our Casita Independence and have used it frequently over the past year as we covered 5,250 or so miles in a wide variety of weather. Once we were used to opening and closing it it proved a reliable, simple and fast awning to use. Generally we also hang a sunshade from one of the end rafters to provide protection from the sun since that often makes sitting outside a bit uncomfortable. All-in-all the Fiamma is an excellent addition to the trailer but be careful to take the time to retract it if it gets windy or you plan to leave it unattended since I can see that a strong gust could damage the aluminum framing pretty quickly. Good luck, Glen
01-16-2017, 07:45 PM
Originally Posted by mary and bob
I need parts
I might still have a few parts, what do you need?
Your awning is likely a 10 footer, the 13 uses an 8ft awning. The case and rafters may not adapt, but the end caps, legs and joints likely will.
01-16-2017, 08:33 PM
end caps, the little "T" shaped piece that latches into the lid when closed, lock knobs for the rafters. It works as is, so nothing urgently needed but replacement parts would be nice to have.
01-16-2017, 09:21 PM
I'll check to see what kind of awning I currently have, and let you know if it's a Catilina 2500.
01-16-2017, 10:47 PM
I installed the fiamma on our scamp. It is a sweet awning. No regrets.
Russ
01-16-2017, 10:51 PM
Are you going to Sebring?
01-17-2017, 06:59 AM
Not going to Sebring Floyd. We are farther south in Florida until Jan. 28, then up to Stephen Foster SP for a couple days, then northeast to the coast of GA
01-17-2017, 11:36 AM
We have a Fiama on our new Parkliner.
The manual for it says that it should be used only as a sun shade.
That it should be closed in the rain, and strong winds.????
That seems to contradict the reasons we want an awning.
We want to be able to sit out and read, or have lunch, or just watch the people, even in the rain.
For windy days you need to add tie down ropes and stakes.
I have a challenge to seal the gap between the roof and awning case, which is uneven along its length.
01-17-2017, 11:58 AM
Trailer: 2015 Casita 17SD
We use ours in the rain quite a bit, so far it hasn't melted. It's basically a large kite, tho, so it needs to be securely tied down. The degree of tied-down-ness being proportional to the amount it has been extended.
We stuff a pool noodle above the awning to divert some of the flow down the side of the trailer near the door. Others have added gutters, this is on my list of future mods.
"...I keep blowin' down the road."
2015 Casita 17' Spirit Deluxe
2002 Toyota Tundra V8
01-17-2017, 12:27 PM
Wayne, some of that sounds like lawyer-speak to me. Manuals are reviewed and edited by lawyers anxious to avoid product liability and operating from a lowest-common-denominator perspective.
If it rains, slant the awning from end to end so it will shed water. If it is breezy, roll it in partway and/or tie it down. If there is a thunderstorm approaching, or if you are leaving camp for a extended outing, or if there is a high wind warning on your weather app, stow it. In other words, common sense.
01-17-2017, 01:59 PM
Thanks Wayne & Batbara, Jim, and Jon for your opinions. They're helpful to me. Also others who have responded
01-17-2017, 02:43 PM
Trailer: 2016 -13' Scamp
Massachusetts
We love our awning and have never had any issues with it. I always roll it securely away in the case of heavy winds. It's great to have in rainy weather, both for cooking and for getting in and out of rain gear!
It also dries quickly from morning dew so we get on the road quite quickly.
01-17-2017, 03:16 PM
Wayne;
Not positive, but I think they all say that.
Actually, our Catalina and our EZ up type things seldom provide shade while you are directly under them anyway! (depending on time of day and which direction the trailer is facing.
Last year we sat through three days of hard rain with our awning extended. we even bought a clear shower curtain to attach to the end of the awning to help keep the rain out.
It is nice to sit under the awning while it rains when you can't otherwise get outside.
I did see a Fiama collapse from the rain once, but it was not set up to allow the rain to run off. Also I think Fiama offers extra rafters which latch in place.
01-17-2017, 10:53 PM
With any awning you must not let water pool on top. Set up with lots of down and side slope. Do not leave awning deployed while you are away when high winds are forcast. (I lost a perfectly good Catalina 2500 to a freak wind storm in our absence) The Fiamma deploys quickly and easily, so I sometimes roll it up just in case before retiring at night. It's a bummer to be awakened by wind blowing the awning around, and have to get up in the wind and darkness to secure it. Water weighs about 8.5 pounds per gallon, and an awning can collect several gallons in a short time if set up wrong. All RV awnings are designed to carry the weight of zero gallons.
Russ
