problems with furnace - Page 3 - Fiberglass RV
Old 05-19-2015, 03:37 PM   #29
Trailer: airstream
OK Bob will do.thanks Eric
sorceress is offline   Reply With Quote
Old 05-20-2015, 06:50 AM   #30
Trailer: 1999 Casita 17' SD
Ohio
Most but not all gas appliances in our trailers have a secondary regulator in their valves and the furnace does.
Could that regulator be out of adjustment
Also be careful when working around your control board, When I was working on quieting down the fan noise I killed it
My plan and it worked on the bench was using a PWM board controlled by a heat sensor have the fan speed follow the temperature inside the furnace.
It worked well starting slow and as the temperature went up so did the fan speed and the converse when the flame was shut off and the temperature went down.
The result was the furnace didn't come on and go off with a roar.
The experiment was a success but there was too much added to my liking
On my Suburban water heater the instructions are given on testing and adjusting the internal regulator no such luck with the furnace.
Joe
Old 05-20-2015, 09:35 AM   #31
Bob in Mb's Avatar
Trailer: Surf-Side
Manitoba
When you find your problem and a solution make sure you clean your flame sensor before you put everything back together . It will probably be your next problem .
Bob in Mb is offline   Reply With Quote
Old 05-21-2015, 07:19 AM   #32
Trailer: airstream
Hey I have a question, since they don't make a 12se anymore, and I can't find the valve for sale, will a nt16se fit in the same place, I think I have located a used working one. Thanks Eric P.S. shame to junk this one, it looks brand new.
furnace
Furnace problems Fishhouse Problem Solving | Owners Helping Owners 5 12-14-2013 12:38 PM
Scamp furnace fan problems jhock Problem Solving | Owners Helping Owners 6 11-28-2013 08:03 AM
Furnace or No Furnace Crackedegg Problem Solving | Owners Helping Owners 7 09-09-2012 07:30 AM
Boler furnace problems. BolerBrad Problem Solving | Owners Helping Owners 1 07-24-2012 06:07 PM
Problems with titles - what are my options? DannyH Problem Solving | Owners Helping Owners 11 05-31-2009 06:13 PM
