problems with furnace - Fiberglass RV
Old 05-05-2015, 02:24 PM   #1
Trailer: airstream
I have a 1996 casita witha NT12SE suburban furnace that won't light. Have used Harry Young's majic trouble shooting guide that helped greatly. It has come down to everything working except no gas. Have no power to the solinoids on the electric gas valve. The manuel switch is fine. Is Harry still out there or is anyone familier with this problem? thanks Eric
sorceress is offline   Reply With Quote
Old 05-05-2015, 05:35 PM   #2
Bill Nolen's Avatar
Trailer: Had Scamp 13', want another small trailer.
I once had a problem with a gas top range because the RV's battery was almost dead.
Just a thought...
Bill
Bill Nolen is offline   Reply With Quote
Old 05-05-2015, 06:08 PM   #3
Trailer: airstream
furnace problems
Thanks Bill, already have it out and apart, it's being bench tested with a 12 volt power supply, thanks again.Eric
Old 05-05-2015, 09:46 PM   #4
4 things have to happen before the furnace will attempt to light.
Furnace switch has to be on and temperature has to be below shut off point by at least a few degrees so a demand for heat is activated.
Battery voltage has to be right.
Fan has to be up to speed. Fan air flow switch has to activate. To release propane from the safety switch.
Propane has to be on and and at the pressure safety switch. Light the stove, both burners and check them on highest setting.
Old 05-05-2015, 09:49 PM   #5
tractors1's Avatar
Trailer: Escape 21 - Felicity
Did you put a jumper across the thermostat in case those contacts are bad?
Charlie Y
Charlie Y
Old 05-05-2015, 10:55 PM   #6
Other than no propane, the common problems listed the one that trumps all others is the Sail Switch. Either from being gummed up, from switch failure or from inadequate airflow.
For starters, try starting the furnace several times while connected to the TV's charging line. It's voltage is usually higher than battery or charger and will spin the fan faster. On some models you can reach in with a wire with a hood on the end and manually pull the sail forward to trip the switch Last is jumping the switch to test and then replacing it when the furnace fires off..
I never look at any of the other problems before ruling out the sail switch
Old 05-06-2015, 12:25 PM   #7
Trailer: airstream
, Thanks Steve, I have the unit out on the bench. Using a 12 volt power supply, hooked up to propane with reg. The sail switch and the gas switch are OK. When I try and fire it up, fan kicks on, sail switch moves but get strange sporadic voltages that don't hold, at the gas switch, low voltage. is there anyay to jump the soliniods to see if it fires up? thanks Eric
Old 05-06-2015, 02:57 PM   #8
tractors1's Avatar
Probably the contacts in the sail switch. Easy to replace since you've got it on the bench - I had to do the same thing in another Suburban furnace.
You can take the wires off the sail switch and jumper them directly to 12V and see if the solenoid stays open.
Charlie Y
Charlie Y
Old 05-06-2015, 04:46 PM   #9
Trailer: airstream
thanks Charlie, I used a continuity tester on the sail switch, shuts on and off fine, but I haven't put 12 volts to the two wires. Will try that. Can I jump the solinoids on the valve with 12 volts? can't seem to find out what voltage they are. Also they seem grounded to the chasis when not in use. Also will the solinoids make an audible click when the open?Thanks again.Eric
Old 05-06-2015, 06:12 PM   #10
tractors1's Avatar
I don't recall the solenoid making an audible click. I was bench testing to see how low the voltage could go and still run the furnace when I did a lot of winter camping on mountains during ski season. Think it was down around 10.5 volts and the furnace would still run.
One side of the solenoid should be grounded, but the other should read a few ohms (the coil resistance) unless the solenoid itself is shorted - which can happen. But then you should blow a fuse...........
Charlie Y
Old 05-06-2015, 08:34 PM   #11
Trailer: bigfoot
Here is at troubleshooting sequence to go through to check what's working and what isn't working. Sounds like it may be the gas valve or dirty orifice , but I hope this info helps
http://bryantrv.com/docs2/docs/suburban_dd_nt.pdf
ken jon is offline   Reply With Quote
Old 05-06-2015, 08:37 PM   #12
Trailer: bigfoot
Should've mentioned that it the info is on page 14
Take care
Old 05-08-2015, 02:45 PM   #13
Trailer: airstream
Thanks, i'm going to go through nthe check list in a few days, will let you guy's know. I realy appreciate the help.Eric
Old 05-17-2015, 11:32 AM   #14
Trailer: airstream
Hi, finally got to go through the troubleshooting guid, Got to the valves and one had 12 volts, the other was all over the place in voltages. The valves were marked + and - so I jumped them and turned it on. When I jumped the rear one it clicked, but unit did not cycle, when I jumped the front one, same thing. So what I figure is board is bad, not supplying enough current to click on the electric valves.what do you think? thanks Eric
furnace
Furnace problems Fishhouse Problem Solving | Owners Helping Owners 5 12-14-2013 12:38 PM
Scamp furnace fan problems jhock Problem Solving | Owners Helping Owners 6 11-28-2013 08:03 AM
Furnace or No Furnace Crackedegg Problem Solving | Owners Helping Owners 7 09-09-2012 07:30 AM
Boler furnace problems. BolerBrad Problem Solving | Owners Helping Owners 1 07-24-2012 06:07 PM
Problems with titles - what are my options? DannyH Problem Solving | Owners Helping Owners 11 05-31-2009 06:13 PM
