Progressive Dynamics PD4045 - Fiberglass RV
Old 06-06-2010, 06:11 PM   #1
Trailer: Bigfoot 13.5 ft
My new PD4045 came pre-wired on the DC side. Small lengths of wire run from the back of the unit. The positive and negative to the battery are 10 AWG. From all that I have been reading, this would necessitate putting the batteries right next to the converter due to voltage drop. The battery in my Lil Bigfoot is located in a storage box at the front. I want to locate the converter under the front bunk, which is about 5 feet from the battery. Taking into account positive and negative cables, this is a 10 foot run. From the charts I have in the books by Moeller and Barre, I would need 4 AWG wiring (Huge) because it is a 45amp converter/charger. Is this right? If so, the current 10 AWG wires coming out of the converter do not look as if they would be easy to replace due how they initiate out of what looks like a computer board that also houses the fuses. It doesn't look like this would accomodate 4 AWG wire. Any ideas on how I should proceed?
Thank you,
Carl
Carl G is offline   Reply With Quote
Old 06-06-2010, 06:59 PM   #2
Larry C Hanson's Avatar
Carl,
When I have a question like that I "Ask Randy" at this website. http://www.bestconverter.com
I bought my WFCO 8725 Power Center from him and he seemed very knowledgeable and helpful.
I use 6/2 Anchor marine cable between the battery and converter (9 feet). Probably it was
overkill but I had some on hand. I just cut the output cable a little shorter and spliced it to
the #6. I measured the different charge voltages at the battery and they were on spec.
Larry H
Old 06-06-2010, 07:23 PM   #3
Thanks Larry,
It is good to hear that you can splice the larger cable to the 10 AWG coming out of the converter. That is exactly what I will do.
Carl
Progressive Dynamics PD4045 Carl G Electrical | Charging, Systems, Solar and Generators 29 06-04-2021 03:09 PM
Progressive Dynamics PD4045 Carl G Problem Solving | Owners Helping Owners 2 06-13-2010 02:13 PM
Progressive Dynamics PD4045 Carl G Problem Solving | Owners Helping Owners 4 06-06-2010 06:56 PM
Progressive Dynamics PD4035 Victor Benz Problem Solving | Owners Helping Owners 1 06-25-2009 05:02 PM
Progressive Dynamics PD-6911 Daisy Problem Solving | Owners Helping Owners 17 01-02-2007 10:46 AM
» Trailer Showcase
l-300
breitmaulbln
Scamp
Gilda
