Propane alarm - Fiberglass RV
Old 06-14-2010, 11:29 PM   #1
Trailer: Fun Finder (X139)
I bought my small trailer in April 2009.
When the propane alarm kept going off whenever I connected the trailer to house power, I disconnected it and couldn't get it to work again.
So I bought a NEW one, in May 2009. Same model as the old one.
Safe-T-Alert SURFACE Mt 12V Propane Alarm -WHITE
It cost $50.
In September 2009, my trailer battery was dying, and the new alarm kept squealing, so I disconnected it on a camping trip by separating the wires. The wires in back of the alarm were twisted together with wires from the trailer.
Now, after replacing my trailer battery and re-connecting the alarm, it doesn't work. The NEW alarm.
Does disconnecting the alarm for six months screw them up?
The trailer battery is good. I have lights without house power.
I have tried the wires (back of alarm, coming from trailer) with both combinations, although I think it's green and black together, and red and white together. But neither combination works.
Do I just buy my THIRD alarm in one year? I like that model since it fits in the same slot, under the stove to the left, between the stove and the bathroom. I need no new holes. Other alarms are thicker and don't fit in that groove as well.
Also, can I get an alarm that uses disposable batteries, like a smoke alarm? So I don't have to worry about it draining my RV battery, or disconnecting it every year? Although I did see in another forum I can take the fuse out.
Any ideas...?
paulitzlee2 is offline   Reply With Quote
Old 06-15-2010, 07:43 AM   #2
Go to the company web site and ask them.
Is it under warranty?
They need to be replaced with new ones about every 4 years.
Old 06-15-2010, 08:18 AM   #3
Joe Z's Avatar
New River AZ
Black wire in the trailer is Positive Hot (+)
White wire is Negative Ground (-)
Green wire is Negative grounded to the frame (-)
sounds like you crossed some wires and may have burnt the unit out or simply blew a fuse.....
When testing again you can temporarily put say a 2 amp fuse on the positive and another on the negative so you don't burn out the unit..... test your black wire (+) to see if it's still Hot
Joe
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
propane
CO alarm; a need? paulitzlee2 Problem Solving | Owners Helping Owners 6 06-17-2010 09:54 AM
How Important is a Propane Alarm? bcomnes Care and Feeding of Molded Fiberglass Trailers 9 01-30-2010 08:28 AM
Trailer alarm Kevin K General Chat 10 04-30-2009 08:52 PM
Casita Propane Leak Detector Alarm David A. Problem Solving | Owners Helping Owners 4 02-11-2009 08:26 AM
Fire alarm, CO alarm AND Propane alarm?? JenPB Problem Solving | Owners Helping Owners 5 07-06-2008 10:57 PM
