Propane and towing - Page 3 - Fiberglass RV
Old 10-17-2014, 11:38 AM   #29
Seems the people that run the tunnels and ferries don't think it is safe??
International marine safety laws require all propane tanks to be shut off when traveling on ferries - big or small ones.
Old 10-17-2014, 02:16 PM   #30
sokhapkin's Avatar
SW Florida
Originally Posted by joe romas View Post
x2
i can't agree more:d
+1.
Sergey
www.callwithus.com
Old 10-17-2014, 02:58 PM   #31
To weat or not to wear seat belts.
Same old argument.
Old 10-17-2014, 03:39 PM   #32
Dan Meyer's Avatar
That is because propane is heavier than air, and they don't want an accumulation of propane in the low point of the tunnel or hull of a ship.
If using propane while moving was so dangerous, it would have been outlawed as a motor fuel a long time ago.
-- Dan Meyer
Old 10-17-2014, 03:50 PM   #33
Raz
Raz's Avatar
Vermont
-- Dan Meyer
good explanation. Raz
Old 10-17-2014, 05:40 PM   #34
sokhapkin's Avatar
SW Florida
Same old argument.
Wear. Definitely. They are your life savers in the case of accident, aren't they?
Sergey
www.callwithus.com
Old 10-29-2014, 12:48 PM   #35
sokhapkin's Avatar
SW Florida
Count yourself amongst the fortunate ones Many here including myself have found that the tugs charge line can not keep up with the 12v consumption of the fridge while towing. True of both the tugs I have used for my current trailer - one with factory tow package and one that had to have the charge line added to it.
Possible reasons for your good fortune is the gage of your charge line and as yours is a newer trailer the fridge may be more conservative on its 12V usage?
I think that the reason of my good fortune is in the wire gauge. Gauge 10 is problem free. I recently purchased used 2013 F150 without towing package, it has tow wiring in the cab, but the wire harness from the cab to the rear of the truck misses tow-related wires (charge line and electric brakes). I added wires myself. The (relatively short) inside cab wiring for charge line is done with 12 or maybe even 14AWG wire! I'm almost sure that tow package wiring from the cab to rear is done with the same wire size. Sure it is not enough to power the fridge and charge the battery.
Let's see how it will work, maybe I will have to replace in-cab charge wire with gauge 10 too.
Sergey
www.callwithus.com
Old 10-29-2014, 02:11 PM   #36
The Minimalist's Avatar
Louisiana
Check to see if those wires aren't connected to relays that energize more substantial conductors.
Clif
Old 10-29-2014, 03:29 PM   #37
sokhapkin's Avatar
SW Florida
Charge wire is connected to the dedicated relay/fuse in the fuse box in the engine compartment.
Sergey
www.callwithus.com
propane
Towing with the Fridge on Propane? buddy hammond Care and Feeding of Molded Fiberglass Trailers 49 08-30-2017 05:24 PM
Liability and overweight towing (split from Towing 13' Scamp...) Bob Miller Towing, Hitching, Axles and Running Gear 88 04-18-2014 05:10 PM
Propane on/off? while towing adimiro Problem Solving | Owners Helping Owners 15 11-09-2006 07:47 PM
