Propane copper pipe corrosion - Fiberglass RV
Old 03-16-2013, 09:56 AM   #1
GMike A's Avatar
Pulling out my carpet exposed about an eight inch section of copper pipe that is pretty corroded. This is located in the closet right at the entry point. Not sure if this will impact over time and eat the pipe or form a protective layer ala black pipe rust. It would be a PITA to change it but since the unit is gutted, now would be the time if it is necessary.
Any owners who are in the refrigeration or heating industry that could shed some light on what to do would be greatly appreciated.
thanks
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 03-16-2013, 10:07 AM   #2
You can try cleaning off the corrosion and see if the copper is pitted. If it is I would replace it. After cleaning it, pressurize the line and check for leaks with soapy water, liquid dish soap is good. There was a recent discussion about whether to use black iron pipe or copper on propane lines. If you have a flaring tool you could just replace that corroded section. DO NOT use the compression type fittings.
Old 03-16-2013, 10:13 AM   #3
Dennis Clinton's Avatar
Trailer: Scamp 16'
Utah
That, my friend is the patina copper gets from being exposed to moisture. First thing, find out where the moisture is coming from. Then check to see if it has intruded into the actual pipe itself. Most likely, clean it off, remove the moisture intrusion, and your problem will be solved.
Dennis
Dennis Clinton is offline   Reply With Quote
Old 03-16-2013, 10:19 AM   #4
Brian B-P's Avatar
The clean-and-inspect approach makes sense, but I personally wouldn't bother; I would just replace it, and do it right this time.
The two large grey lines arcing across the lower left corner of the photo are presumably water lines. Some points to ponder in a better installation: Why would a propane line be cable-tied to a water line? Does the propane tubing get mechanically stressed each time the water pump starts or stops and the water line shakes? Is the propane tubing getting wet each time cold water flows and condensation forms on the water line? Is the propane tubing sitting in a pool of water, as suggested by the copper corrosion products on surrounding surfaces?
Old 03-16-2013, 12:09 PM   #5
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Those blue electric pinch-on connectors catch my eye. They are notoriously unreliable, especially in a area where corrosion is a problem. Just a heads up.
Old 03-16-2013, 01:09 PM   #6
cpaharley2008's Avatar
It looks like it was inside that piece of material which held moisture, it is patina which copper obtains with aging, not rusted, just clean it up and find the leak.
Nev-r-Dull will work on it.
Old 03-16-2013, 01:28 PM   #7
GMike A's Avatar
Agree Tom. There must have been two dozen of them in there and I stripped them all out except what you see now and that's right at the INPUT from the 7 pin, They cut the nice 12 gauge wire and added scotch locks right there and went to 14- could not believe it!!! And then down stream it goes back into 12 again.
I will have a nice bus line going from a fused box to all lights and accessories. Heavy gauge wire the old fashion way.
Mike
K5NAN
"Miss Adventures"
Old 03-16-2013, 01:37 PM   #8
Mike, I am with Jim sure looks by what looks to be signs of floor staining and the black spots on the wall covering etc that water may have been getting in from higher up?
Old 03-16-2013, 02:36 PM   #9
Thomas G.'s Avatar
Old 03-16-2013, 03:21 PM   #10
Trailer: 2014 Escape 21, Lil Joe
Mike
Do yourself a favor, order yourself a junction box from E trailer.
Eddie
Trailer Wiring Junction Box Spectro Accessories and Parts 38656
Old 03-16-2013, 03:54 PM   #11
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
The guy that designed scotch-locks should be flogged every time somebody has a trailer wiring problem. I'm almost done getting rid of them in my camper, and I've had to cut out about 12" of wire on either side to find shiny copper again, and splice a piece in with crimps and marine heatshrink.
Old 03-16-2013, 03:56 PM   #12
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Interesting that the corrosion is limited to that section of copper that's in contact with the carpet. My guess is moisture wicking, could be from anyplace.
I'm with the don't-worry-about-it-if-there's-no pitting crowd. Do be sure to get rid of the carpet that's touching the pipe, and here's some advice from a hypercareful gas user:
Once it's all sorted out, a simple pressure test of the whole propane system can be done by any gas/RV place. I have mine tested once a year at a cost of about twenty-five dollars.
Francesca
Old 03-16-2013, 04:00 PM   #13
Jared J's Avatar
Kansas
Francesca
Hijack, but can they test for CO from a cracked furnace manifold? I'm going to put a monitor in my camper, but I would like to have that checked anyway.
Old 03-16-2013, 04:04 PM   #14
Don't know if there's such a test...but if your manifold is cracked you probably want to weld/seal it up somehow. CO isn't a big hazard with propane, but certainly that manifold crack may interfere with the operation of the furnace.
Francesca
casita, propane
Aluminum Corrosion New Scamp 13' Ric Problem Solving | Owners Helping Owners 19 02-28-2013 11:37 AM
copper pipe identification barnaby Problem Solving | Owners Helping Owners 2 09-06-2012 12:22 PM
Corrosion on stove top, help please... DeeJ Problem Solving | Owners Helping Owners 3 04-24-2011 03:17 PM
Uh Oh---should we have left the pipe in??? Vickie B. Problem Solving | Owners Helping Owners 15 04-11-2011 02:33 PM
Corrosion, interior propane line General Chat 0 01-01-1970 12:00 AM
