Propane detector and Carbon Monoxide detector. - Fiberglass RV
Old 02-05-2006, 12:36 PM   #1
Yves Pelchat's Avatar
Trailer: Bigfoot 17 ft (15B17G)
Quebec
Hello again;
Everyone here knows that a propane leak can be deadly. Same thing for carbon monoxide. I've been looking for a propane/carbon monoxide detector for RV that operates on 12vdc. It seems all that all the models i found so far, only operate on AC 120v only...
Anyone her knows where to find a 12v propane/carbon monoxide detector?
Thanks!
Yves.
Yves Pelchat is offline   Reply With Quote
Old 02-05-2006, 02:06 PM   #2
Trailer: 87 Scamp
Southern New Jersey
Hello again;
Thanks!
Yves.
YOU MAY HAVE BETTER LUCK LOOKING FOR A 9 VOLT.
JOE DRISSEL is offline   Reply With Quote
Old 02-05-2006, 02:38 PM   #3
Trailer: Fiber Stream
Talking
I thought that Camping World stocked the 12 volt variety; but I don't know if they are located near you.
I have also seen Carbon Monoxide detectors bundled with Smoke detectors, but not bundled with Propane detectors. Am I missing something?
My Propane detector is mounted low, next to the Converter, and draws power from the trailer's 12 volt system.
My Smoke detector is mounted high and uses a 9 volt battery.
Old 02-05-2006, 03:01 PM   #4
Camping world has the 12V DC models that wire in to your 12V system. I put a fuse on mine so I can turn it off when not camping.
All vehicles with propane devices should have a CO and Gas detector(s) installed.
I installed a 9volt CO detector for the Egg that gives me a readout. Got it at Home Depot for around $35 USD. I also have 3 of them in my house.
Old 02-05-2006, 03:15 PM   #5
Al Stansell's Avatar
Trailer: 1976 13 ft Boler and 1980 Trillium 5500
Yes indeed - I won't camp without them! Frederick is right - propane low, CO2/smoke high. Here are mine:
Cheers, Alec
Al Stansell is offline   Reply With Quote
Old 02-05-2006, 06:29 PM   #6
Quebec
My Propane detector is mounted [b]low, next to the Converter, and draws power from the trailer's 12 volt system.
My Smoke detector is mounted [b]high and uses a 9 volt battery.
Thanks. I've looked at the Camping World web site, and I've seen the models that they stock. Most of them are 12V, so that's exactly what i'm looking for.
I also have an eye on a Porta-Chef grill.
Yves.
Old 02-05-2006, 10:28 PM   #7
Trailer: 1999 Burro 17 ft Widebody
I just bought a newly introduced Dual LP and Carbon Monoxide 12 VDC detector (Model 70-742 made by SafeTAlert (the same brand that CampingWorld sells). It ran about $100, which is slightly less than buying two seperate units. The only disadvantage could be that this unit is a flush mounted, requiring a 3"x4" rectangular hole in the mounting surface.
I ordered my unit through RV Pro here in Vancouver WA.
Steve
S Sato is offline   Reply With Quote
Replacing Propane Detector Penney H. & Mike E. Care and Feeding of Molded Fiberglass Trailers 10 06-26-2010 12:19 PM
Casita Propane Leak Detector Alarm David A. Problem Solving | Owners Helping Owners 4 02-11-2009 08:26 AM
Battery Operated Propane Detector? Art Davis General Chat 8 05-06-2007 04:44 PM
carbon monoxide alarm Christi V. Problem Solving | Owners Helping Owners 3 04-18-2006 08:26 AM
Propane detector Chris Z Care and Feeding of Molded Fiberglass Trailers 13 02-24-2006 10:23 PM
