Propane Furnace Vent - Fiberglass RV
Old 10-18-2017, 06:30 AM   #1
Trailer: ParkLiner
Virginia
If I'm not using the propane furnace, is there any reason I shouldn't block off the outside vent?
The wind must have been gusting at least 40 knots the other night and I could feel a strong, cold breeze coming through the inside furnace vent. When I opened the drawer directly above the vent same thing. I draped a towel over the inside vent and that helped a little, but didn't keep all the cold air out.
Huck is offline   Reply With Quote
Old 10-18-2017, 07:11 AM   #2
ZachO's Avatar
Trailer: 91 Bigfoot 17
Montana
No reason for them. I've definitely heard complaints from some people about both the propane fridge and the furnace, because of their venting requirements. It definitely opens up big holes in the camper.
If you don't use the furnace, plug it up. Just pull the fuse or something on the furnace to make sure no one flips it on by mistake, not knowing it's plugged.
Old 10-18-2017, 07:24 AM   #3
IllAnnoy
Check your furnace installation. It should take isolated fresh air into the plenum from the vent for combustion and exhaust it back out. How do you get air into your trailer through the furnace vent unless the plenum is leaking due to damage or improper installation?
If all is well with the furnace, check your fridge to see if it is sealed on the sides from allowing air into the cabinet. This is much more likely.
You can insulate it using foil covered Tuff-R and aluminum tape...
Old 10-18-2017, 11:15 AM   #4
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
Our 2016 ParkLiner also blows air through the drawer and space below the drawer where the furnace would be. On investigation, I see that it comes from the fridge vent door. There is no partition between. I have told PL that the fridge compartment is supposed to be completely sealed off from the rest of the cabinets. They said they would look into it but I have not heard a word since.
The vent openings in the fridge door are large enough to let bugs in. I tried adding window screen, but it has an odd shape that makes it tough to hold in place.
Old 10-18-2017, 11:32 AM   #5
Trailer: Currently shopping
Air intrusion.
Saw a fix for this problem last weekend. A sheet of flexible magnet material from a craft store placed over the furnace vent inside. Fixed the air intrusion and easy to remove to use furnace.
J Ron is offline   Reply With Quote
Old 10-18-2017, 02:45 PM   #6
Trailer: Parkliner
Iowa
The air intrusion is not coming through the furnace.
It comes from the fridge vent door on the outside and blows through the cabinets and around the furnace. The drawer and doors do not seal tightly.
Old 10-18-2017, 02:48 PM   #7
One thing to consider before blocking any propane device vent. Well two one obvious. The other the vents are already outside the cabin. The furnace vent is both air intake and exhaust for the firebox ONLY. The fridge has to get rid of heat someway, the vent does that and does NOT connect to the interior of cabin. Therefore I see no reason the block these vents so that you can forget you blocked them and fire up fridge or the furnace.
There's a song about that "Smoke gets in you eyes."
Old 10-18-2017, 05:30 PM   #8
Trailer: 1979 Boler 1300 / 1991 Casita Freedom Deluxe
Maine
I have to agree with Floyd or Wayne. on my Boler the vent only goes out from the heat chamber but in the same double lined tube fresh air is brought in but only into the heat chamber.
A fan then goes through the triangle shaped heat chamber to blow the heated air into the camper.
No opening to outside from inside of camper.
furnace, propane
Maxxair vent vs Fantastic vent? MinnesotaJill Modifications, Alterations and Updates 33 07-26-2014 08:54 PM
Fantastic Vent and Camco Vent Cover d_wildemann Care and Feeding of Molded Fiberglass Trailers 0 06-19-2009 05:30 AM
To Roof Vent, Or Not To Roof Vent Frederick L. Simson Problem Solving | Owners Helping Owners 5 02-22-2009 05:41 PM
Furnace Vent Donna D. Problem Solving | Owners Helping Owners 10 01-12-2007 01:23 AM
Bees in the furnace vent General Chat 0 01-01-1970 12:00 AM
