Propane level monitoring - Page 2 - Fiberglass RV
Old 06-14-2013, 04:44 PM   #15
Brian B-P's Avatar
Originally Posted by BC Paul View Post
Originally Posted by Thomas G. View Post
No better than pouring hot water down the side IMHO.
Originally Posted by Jim Bennett View Post
Much easier though, and less messy especially in freezing temps.
I don't understand how pouring water down the side of a tank with the "gauge" strip stuck to it is "much easier" or "less messy" than pouring hot water down the side of a tank without a strip stuck to it; am I missing something?
Old 06-14-2013, 05:17 PM   #16
Brian B-P's Avatar
Originally Posted by bobflhtc View Post
I think I may have the automatic switch over...
How can you tell?
An automatic changeover control is normally built into a regulator, and has both a knob (usually black) to select which tank is used first, and a red/green indicator that shows whether the selected tank still has pressure (green) or has run out (red); red also means that the changeover should have occurred, so the non-selected tank should be in use.
These devices are controlled and operated by propane pressure, so they can switch prematurely, or fail to switch at all, under abnormal conditions of outdoor temperature or rate of chilling caused by the rate of propane use. In normal camping conditions they seem to work fine.
For convenience there is also a remote indicator available for at least some Marshall models which shows the red/green status, in case you want to see it somewhere that you cannot see the regulator.
Old 06-14-2013, 06:31 PM   #17
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Exactly my point. Thanks for agreeing.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 06-14-2013, 08:16 PM   #18
Brian B-P's Avatar
Jim, seriously, I don't get it. The strip was mentioned, Tom said it wasn't any more convenient than just pouring hot water on the tank, and you said it was "Much easier though, and less messy especially in freezing temps." It's the same; how can it be "much easier though, and less messy especially in freezing temps"? Just sarcasm?
Old 06-14-2013, 10:26 PM   #19
Like I said in my first post, I just think the strip would be much easier to use. That's all.
I have used the water trick before, and just not a fan.
2017 Escape 5.0 TA
Old 06-15-2013, 07:19 AM   #20
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
I would never have thought of using a fan, Jim.
jack
Old 06-15-2013, 07:31 AM   #21
Groan......lol
2017 Escape 5.0 TA
Old 06-15-2013, 07:36 AM   #22
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I use the hot water trick but in conjunction with a non-contact thermometer - same one I use to check my hubs.
Of course I could just touch the tank to feel the temperature difference , but would that be hi-tech?
Non-Contact Pocket Thermometer
Old 06-15-2013, 09:37 AM   #23
papa-t's Avatar
Glade Valley, North Carolina
I have two tanks, so I just watch for the green to turn to red and if you have both tanks on it will switch over automatically. If you have only one tank. I like the lift method the best to check the weight or carry a spare tank.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
papa-t is offline   Reply With Quote
Old 06-15-2013, 10:00 AM   #24
Thomas G.'s Avatar
Originally Posted by papa-t View Post
...... I like the lift method the best to check the weight or carry a spare tank.
My tank is bolted tight. To lift it, I have to loosen a bolt and undo the hose. Not convenient for me.
Old 06-15-2013, 02:30 PM   #25
Brian B-P's Avatar
I still don't get it. The strip might be easy to read, but you still need to pour hot water to use it, so I don't know where the ease of use comes from.
Old 06-15-2013, 02:46 PM   #26
Brian Van Snell's Avatar
Trailer: Escape 13 ft 2010 ('Ladybug') / 2003 Subaru Forester/ 2012 Toyota Highlander
Let's not overcomplicate!
The original question from Bob asked about whether a simple propane gauge which can be obtained for about $15 would let you know whether you have enough propane.
I think the answer is "yes".
We have been using one for four years and have never had a problem with it. When the gauge shows the propane level is low we can get the tank filled or swap it with one we know has enough propane. Simple.
Brian & Maria
2010 Escape 13 "Ladybug"|2003 Subaru Forester|2012 Toyota Highlander
Brian Van Snell is offline   Reply With Quote
Old 06-15-2013, 02:48 PM   #27
I know a couple people with them and am fairly sure they don't pour hot water on them to read them. Almost positive. On Canada Day weekend there will be a trailer there with them, and I will quiz then on their experiences.
2017 Escape 5.0 TA
Old 06-15-2013, 03:07 PM   #28
Thomas G.'s Avatar
From your link:
A special thermochromic ink changes from yellow to orange when you pour water down the length of the gauge. Within a few seconds, the portion of the gauge that returns to yellow indicates the level of propane.
propane
TireTraker Tire Monitoring System – Review jeffz Modifications, Alterations and Updates 28 07-01-2016 04:55 AM
TriMetric 2025-RV-F Battery Monitoring System baron100 Commercial Posts and Products 0 01-13-2013 04:25 PM
tire pressure monitoring systems glamourpets Towing, Hitching, Axles and Running Gear 47 10-24-2012 07:55 PM
Wireless Tire Pressure Monitoring Systems Pete Dumbleton Problem Solving | Owners Helping Owners 14 11-23-2006 06:16 AM
Propane tank Level? Byron Kinnaman Problem Solving | Owners Helping Owners 32 12-23-2005 10:57 AM
