Propane level monitoring - Page 3 - Fiberglass RV
Old 06-15-2013, 03:10 PM   #29
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Originally Posted by Thomas G. View Post
From your link:
Someone else posted the link, and I did not read it. Definitely going to have to check them out in 2 weeks time when camping with my friend who uses them.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 06-15-2013, 03:13 PM   #30
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Oops, I guess it was BC Paul that posted it.
Old 06-15-2013, 04:01 PM   #31
Brian B-P's Avatar
I know a couple people with them and am fairly sure they don't pour hot water on them to read them. Almost positive. On Canada Day weekend there will be a trailer there with them, and I will quiz then on their experiences.
Now we're getting somewhere...
If the propane is in use, and preferably at a high rate (not just the refrigerator), then the propane is chilled by the vapourization required to keep up with vapour withdrawal. Up to the liquid level the tank wall will be much colder than above it, where the propane is vapour. You can feel, or see (as condensation or even frost), or measure (with Tom's non-contact thermometer or an LCD strip) the difference in temperature... no hot water required.
If the propane is not flowing, everything is at the same temperature, and there is no way for a temperature measurement to determine level. Thus, the instruction from the Magnetic Propane Tank Gauge web page which Tom quoted. The strip (or other temperature measurement) shows where the liquid conducts heat more effectively than the vapour.
Originally Posted by Brian Van Snell View Post
The original question from Bob asked about whether a simple propane gauge which can be obtained for about $15 would let you know whether you have enough propane.
The answer is "it depends"...
When the gauge shows the propane level is low we can get the tank filled or swap it with one we know has enough propane.
It depends on whether or not the propane is in use. If the propane is flowing, the chilling effect lowers the pressure, and when remaining amount gets low enough the temperature (and thus pressure) drops, as indicated on the GasWatch or similar gauge.
If the propane is not in use, it is at the surrounding temperature. Since the cheap gauge measures nothing but pressure, and the pressure depends on nothing but temperature, the reading will be the same regardless of the propane level. One drop left or completely full gives the same reading.
These pressure gauges tell you if you are about to run out, while using the propane. If you check it before leaving on a trip, while no propane is being burned, it will always tell you that you have lots left, even if you have almost none.
Of course, we've been through all of this before, with the same conclusions because the science has not changed, but many members seem unwilling to look at the old discussion threads.
Old 06-16-2013, 05:06 PM   #32
Trailer: Lil Snoozy / Jeep Cherokee
David, I have never found it difficult to see the propane level in my tank. I have never tried checking in low light conditions such as at night, but would imagine seeing under those conditions to be difficult.
Bill in Pittsburgh is offline   Reply With Quote
Old 06-17-2013, 05:51 AM   #33
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
For those unfamiliar:
One style of the changeover regulator. It is pointing to the left tank which is being considered empty (because of the red band) but is drawing from the right tank (assuming there is gas in it). Turning the black knob over to the right would cut out the left tank making it safe to remove it and refill while leaving the right tank as the source. The band would then turn green assuming gas in the right tank.
I've used mine for years with no issues. I make it a point to refill the newly empty tank immediately, even if camping. I'm always out exploring the area and can find a hardware or UHaul store to refil. Propane is a common household fuel in rural areas and refill stations aren't hard to find.
propane
TireTraker Tire Monitoring System – Review jeffz Modifications, Alterations and Updates 28 07-01-2016 04:55 AM
TriMetric 2025-RV-F Battery Monitoring System baron100 Commercial Posts and Products 0 01-13-2013 04:25 PM
tire pressure monitoring systems glamourpets Towing, Hitching, Axles and Running Gear 47 10-24-2012 07:55 PM
Wireless Tire Pressure Monitoring Systems Pete Dumbleton Problem Solving | Owners Helping Owners 14 11-23-2006 06:16 AM
Propane tank Level? Byron Kinnaman Problem Solving | Owners Helping Owners 32 12-23-2005 10:57 AM
