Propane level monitoring - Fiberglass RV
Old 06-14-2013, 10:02 AM   #1
Fulltimer West of the Rockies
I just purchased a 98 16' Scamp and I was wondering how everyone monitors how much propane they have so they aren't suprised. I see Camping World has a gauge called GasWatch.
Thanks Bob
bobflhtc is offline   Reply With Quote
Old 06-14-2013, 10:04 AM   #2
David Tilston's Avatar
As is often the case on this site, good discussions on subjects develop that are not related to the original intent of the thread. There is a good discussion on the various ways to gauge a propane tank at this thread:
http://www.fiberglassrv.com/forums/f...any-58857.html
Old 06-14-2013, 11:16 AM   #3
Brian Van Snell's Avatar
Trailer: Escape 13 ft 2010 ('Ladybug') / 2003 Subaru Forester
Propane Gauge
We bought a gauge similar to this at our local Costco:
Amazon.com: Flame King YSN-212 Propane Cylinder Gas Gauge Meter: Patio, Lawn & Garden
This seems similar to the gauge sold by Camping World.
It seems to work reasonably well.
Another solution is to weigh the cylinder periodically.
I have used our propane gauge to check our home BBQ tank and the one on our trailer. It is easy to put the fullest propane tank on the trailer before making a trip.
We have a local propane supplier who will fill a 50% full propane tank and charge 50% -- some places will charge 100% even if the tank is 50% full.
Steel cylinders are less than half the price of fiberglass ones. I suggest going with the economical solution.
Brian & Maria
2010 Escape 13 "Ladybug"|2003 Subaru Forester|2012 Toyota Highlander
Brian Van Snell is offline   Reply With Quote
Old 06-14-2013, 11:31 AM   #4
Trailer: Lil Snoozy / Jeep Cherokee
Easiest and most reliable way is to purchase a fiberglass tank where you can see the level.
Do not purchase the recalled fiberglass tank made by THE LITE CYLINDER COMPANY.
Bill in Pittsburgh is offline   Reply With Quote
Old 06-14-2013, 11:44 AM   #5
I disagree. In my opinion, a float operated level gauge is the easiest and most reliable. Fibreglass tanks are not as see through as you might think. Some have said that they can only see the level when they shake the tank. Difficult to do when it it connected to your trailer. If you disconnect it, you might as well give it a lift and check the weight.
Old 06-14-2013, 11:44 AM   #6
Steve L.'s Avatar
I like this one:
Amazon.com: Original Grill Gauge: Patio, Lawn & Garden
Old 06-14-2013, 11:47 AM   #7
Originally Posted by Steve L. View Post
Problem with this one is that it useless for any other purpose. I presume it wouldn't work with my 10 lb. tank either.
Get a luggage scale instead.
Old 06-14-2013, 12:09 PM   #8
Trailer: 2008 17 ft Escape B / 2005 Tacoma 4x4 D Cab
Maybe this from Lee Valley???
Magnetic Propane Tank Gauge - Lee Valley Tools
BC Paul is offline   Reply With Quote
Old 06-14-2013, 12:16 PM   #9
Thomas G.'s Avatar
Originally Posted by BC Paul View Post
No better than pouring hot water down the side IMHO.
Old 06-14-2013, 02:48 PM   #10
Jim Bennett's Avatar
Much easier though, and less messy especially in freezing temps.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 06-14-2013, 03:34 PM   #11
I have 2 tanks and automatic switch over. Once one tank empties the regulator switches over to the other tank indicating when it has done so. You will know when the tank is empty. This way your not guessing and running around at the last minute dealing with propane. You always have enough and plenty of time to get your empty tank refilled. This is more important if heating your egg is a necessity.
Old 06-14-2013, 03:52 PM   #12
I think I may have the automatic switch over. Now for the dumb question. How can you tell? Sounds like a great way to resolve the problem.
Thanks Bob
Old 06-14-2013, 04:14 PM   #13
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
I like Bagol's suggestion of spring scale reading in lbs. Weigh your deer, your fish, your propane.
jack
Old 06-14-2013, 04:15 PM   #14
Thomas G.'s Avatar
jack
And your luggage.....
Old 06-14-2013, 04:44 PM   #15
Brian B-P's Avatar
I don't understand how pouring water down the side of a tank with the "gauge" strip stuck to it is "much easier" or "less messy" than pouring hot water down the side of a tank without a strip stuck to it; am I missing something?
Old 06-14-2013, 05:17 PM   #16
Brian B-P's Avatar
Originally Posted by bobflhtc View Post
I think I may have the automatic switch over...
How can you tell?
An automatic changeover control is normally built into a regulator, and has both a knob (usually black) to select which tank is used first, and a red/green indicator that shows whether the selected tank still has pressure (green) or has run out (red); red also means that the changeover should have occurred, so the non-selected tank should be in use.
These devices are controlled and operated by propane pressure, so they can switch prematurely, or fail to switch at all, under abnormal conditions of outdoor temperature or rate of chilling caused by the rate of propane use. In normal camping conditions they seem to work fine.
For convenience there is also a remote indicator available for at least some Marshall models which shows the red/green status, in case you want to see it somewhere that you cannot see the regulator.
Old 06-14-2013, 06:31 PM   #17
Exactly my point. Thanks for agreeing.
2017 Escape 5.0 TA
Old 06-14-2013, 08:16 PM   #18
Brian B-P's Avatar
Jim, seriously, I don't get it. The strip was mentioned, Tom said it wasn't any more convenient than just pouring hot water on the tank, and you said it was "Much easier though, and less messy especially in freezing temps." It's the same; how can it be "much easier though, and less messy especially in freezing temps"? Just sarcasm?
Old 06-14-2013, 10:26 PM   #19
Like I said in my first post, I just think the strip would be much easier to use. That's all.
I have used the water trick before, and just not a fan.
2017 Escape 5.0 TA
Old 06-15-2013, 07:19 AM   #20
rabbit's Avatar
Delaware
I would never have thought of using a fan, Jim.
jack
propane
Propane tank Level? Byron Kinnaman Problem Solving | Owners Helping Owners 35 12-27-2020 02:27 PM
TireTraker Tire Monitoring System – Review jeffz Modifications, Alterations and Updates 28 07-01-2016 04:55 AM
tire pressure monitoring systems glamourpets Towing, Hitching, Axles and Running Gear 47 10-24-2012 07:55 PM
Wireless Tire Pressure Monitoring Systems Pete Dumbleton Problem Solving | Owners Helping Owners 14 11-23-2006 07:16 AM
