Propane mount - Fiberglass RV
Old 08-22-2015, 09:06 PM   #1
Trailer: 2000 17' Casita Freedom Deluxe...Tow vehicle 2015 Toyota Tacoma Dble Cab V6 Prerunner
Propane mount
I need to fabricate some type of mount for my 20 lb gas cylinder ..... Anyone done this that wants to share their idea (pics would be great)
Looking for some simple system
Thanks in advance
Old 08-22-2015, 09:14 PM   #2
Look on Amazon, "propane tank mount". I like the one by Nashfuel, but there are others
Old 08-22-2015, 09:54 PM   #3
What I have done for several LP tank mounts is to make a frame out of angle iron to fence in the base ring and then secure the tank via the base ring with blind bolts at the front and back, using standard existing holes in the base rings. It has a clean appearance, they never come loose and stealing a tank is next to impossible. They can be removed for refilling if necessary in about 5 minutes.
Old 08-23-2015, 10:37 AM   #4
Maybe I misspoke i have brackets on the tongue (small tabs) that fit the base of the cylinder... What I'm looking for are some type of straps/ chain turnbuckle system ideas
Sorry for any confusion
I was also considering threaded rod and unistruct
Any thoughts ideas or pics ???
Old 08-23-2015, 10:42 AM   #5
Bump
Old 08-23-2015, 11:39 AM   #6
You might try eBay, I have seen replacement LP tank tie-downs in the RV parts and supplies category.
Old 08-23-2015, 11:44 AM   #7
Bob
Thanks you always seem to have some ideas( i didnt even think of checking with Scamp).... As Homer Simpson says DUH
Old 08-23-2015, 11:57 AM   #8
Price and shipping cost wise, Scamp and Camping World are usually my last choices. But sometimes they may also be the only source.
Old 08-23-2015, 06:43 PM   #9
Trailer: '84 Scamp 13' & 2001 Casita 17' Spirit Deluxe
Arkansas
I have a small (8') Starcraft Meteorite Pop-up trailer in addition to the teardrop & MFG trailers (use it for hunting/fishing trips, me only). When I bought it the propane cylinder was held to the 'A' frame rack only by bungees (towed it home from Tyler, TX like that but was sure worried). I'd seen a 'tie-down' arrangement using metal straps & threaded bolts so I looked in my 'junk pile' & found some 5/16" 'all-thread' & 3' or so of 3/4" x 1/8" steel strap. I cut the all-thread into usable lengths, drilled appropriate holes in the tongue rack & bolted the all-thread on. Cut needed lengths of the steel strap & bent it in a shop vise to fit the propane cylinder, with a 90degree tab on each strap. Drilled the tab to fit the all-thread, 'hooked' the upper end of the straps to the cylinder 'collar' & tightened 'em down using 5/16" wing nuts. I suppose someone could take the nuts off & abscond with the cylinder but if they're willing to go to that much trouble, guess they can have it... They've been painted but without primer & are needing it again. Since it's my hunting/fishing rig I dunno if I want it to look too good
Harvey is offline   Reply With Quote
Old 08-23-2015, 07:22 PM   #10
Thanks that is sort of what i had on mind
Pics are great
Old 08-23-2015, 07:34 PM   #11
Harvey's rigging is good. There are commercially available straps that are very similar.
I would add a cable or chain with padlock to both discourage theft and keep the tank from being lost if the bolts or straps failed. It would only take 30-60 seconds to remove the chain or cable when it was time to refill.
Old 08-23-2015, 08:23 PM   #12
Arkansas
Good idea Gordon! I'll look into acquiring one of the cable type bicycle locks to better secure the cylinder. My camper is often left alone for hours in some pretty remote locations. I'll probably feel better with the cylinder secured in some way along with the hitch lock I use on the coupler...
Old 08-23-2015, 09:32 PM   #13
I found that my safety chains could be employed to padlock the propane tanks when not hooked up. Only did it once for the picture though.
Old 08-23-2015, 09:42 PM   #14
IllAnnoy
I sure like the look of this one, mine is similar only without that clever quick release and hinge!...
propane
Mount for 1 gal propane tank WDavidG Modifications, Alterations and Updates 23 07-18-2015 09:04 AM
Installing Safe T Alert Surface Mount Propane Detector: Hard Wired CampyTime Problem Solving | Owners Helping Owners 14 04-17-2014 12:18 PM
Propane tank / Battery mount Trillium 4500 1978 Gumpit Modifications, Alterations and Updates 14 11-20-2010 09:15 AM
Special awning mount jrnutpaul Modifications, Alterations and Updates 15 12-18-2006 07:38 AM
Fiberglass chassis mount camper Kurt & Ann K. General Chat 11 11-26-2005 04:06 PM
