propane not flowing - Page 2 - Fiberglass RV
Old 06-18-2014, 11:56 AM   #15
Trailer: Aliner folding & Weekend Warrior toy hauler
Ohio
You are referring to a safety device to prevent catastrophic leak events, It consists of a small ball that sits in a chamber. With normal LPG flow the gas goes around the ball and works normally. With a big rush/flow of gas the ball will move and block the orifice allowing only a tiny amount of gas to pass.
After triggered, the ball will continue to block the orifice due to the LPG pressure holding it in place. To reset the safety device, the cylinder valve needs closed and pressure in the system reduced. The ball then drops into its normal position and will allow normal gas flow once again.
Do you all also know that the portable LPG bottles are correctly called a DOT cylinder? An LPG ASME 'tank' is permanently mounted like in a motorhome.
Shopping for a fiberglass TT
Currently own;
2009 Pontiac Vibe pulling a 2009 Aliner Sport = 22 MPG
1998 Ford E150 pulling a 2006 Weekend Warrior toy hauler = 8 MPG
beemerphile1 is offline   Reply With Quote
propane
Not fiberglass, but why not wooden trailers? John Linck General Chat 68 03-10-2018 12:58 PM
Floor Polish? buff or not,,, wax or not. ampline Care and Feeding of Molded Fiberglass Trailers 10 08-26-2013 06:58 PM
Not really a sighting, and not for sale either Gina D. General Chat 6 02-18-2010 01:56 PM
Composite (not steel) propane tank Amy M Problem Solving | Owners Helping Owners 8 11-27-2009 04:12 PM
Not fiberglass, Not a Trailer Adrian W General Chat 2 11-23-2009 04:45 PM
