propane pigtail - Fiberglass RV
Old 01-07-2012, 01:27 PM   #1
Gordon Kinslow's Avatar
Trailer: Boler 1300
propane pigtail
I seem to be at a loss, I have a two stage Marshall 290 regulator that has a POL connector attached directly to it which then connects to the tank. I want to install a acme type one connector,but they all seem to have a 1/4 inch inverted flare connector on the end, I need a 1/2 Inch inverted flare. Is there such a type of pigtail from rv dealers. Or do I need a new style regulator to accept a 1/4 inch flared end. Thanks in advance
Gordon Kinslow is offline   Reply With Quote
Old 01-07-2012, 06:00 PM   #2
DannyH's Avatar
Trailer: 1976 Scamp 13 ft
There may be a better solution than this, but Low's and/ or Home depot may carry a brass reducer that goes from 1/4" to 1/2". I bought most of my propane connections from them. One solution is to put in the respected flares and use the reducer to connect them. This may not be the best solution as you end up with multiple connection in this area. If it was me, I would look at getting another regulator to minimize the connections.
Post what you ended up with for a solution.
Dan H
DannyH is offline   Reply With Quote
Old 01-07-2012, 06:39 PM   #3
Trailer: Boler 1300
Thanks I may go and have a look to see if Kent or CT has 1/2 TO 1/4 reducer, I would assume if they don't leak it will be fine.
Old 01-07-2012, 06:50 PM   #4
cpaharley2008's Avatar
For some reason, I'm thinking the connection to the regulator downstream is a pipe fitting, not flared.
Old 01-07-2012, 07:10 PM   #5
Trailer: Boler 1300
I will bring it in to the everything dealer and see what they say or have.
Old 01-07-2012, 07:11 PM   #6
Trailer: Boler 1300
I will bring it in to the rv dealer and see what they say or have.
Old 01-07-2012, 09:35 PM   #7
Trailer: Boler 1300
Dealer has the hose I require 1/4 mpt pigtail.
Old 01-08-2012, 12:35 PM   #8
Trailer: Boler 1300
This is what i was looking for, most of them come with 1/4" inverted flare, but this one has 1/4 npt
Old 01-08-2012, 12:51 PM   #9
Look here also. It is a great site and I order from them often.
Extend-A-Stay Standard Propane Kit - $63.69
Old 01-08-2012, 01:46 PM   #10
National pipe thread- NPT
was it 3/8 or 7/16?
Old 01-08-2012, 01:46 PM   #11
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
Try this site also. Really good prices and selection at Tweety's
Camco RV Pigtail LP Hose 20" x 1/4"
Trilliums Rock!
Old 01-08-2012, 05:57 PM   #12
Trailer: Boler 1300
1/4 npt
propane cap carole sullivan Problem Solving | Owners Helping Owners 5 05-11-2008 08:13 PM
Propane Frig Kevin K General Chat 5 04-29-2008 09:37 PM
Propane christineb Care and Feeding of Molded Fiberglass Trailers 12 11-26-2005 10:41 PM
Protecting the trailer pigtail Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 10-05-2002 01:14 PM
Propane pit? General Chat 0 01-01-1970 12:00 AM
