Propane questions..... - Fiberglass RV
Old 05-09-2014, 06:05 PM   #1
Trailer: Compact Junior
When I bought my early 1970's Compact Junior last fall I lit the stove and everything seemed to work fine.
It's been a long cold spring here but I'm getting ready for my first camping trip with her in a couple of weeks.
I went out to light the stove but when I turned the gas on at the tank there was loud hissing and the clear odor of propane.
These are old tanks, and I'm sure newer campers use more modern hook-ups. I also suspect that I may not be able to refill these older tanks.
I tried to remove the left hand tank but the connection at the tank wouldn't come loose and I don't want to muscle it. Both tanks seem to have a lot of gas in them.
So my questions are how can I dispose of these old tanks with a lot of gas in them? And how much "new" do I need? I assume new tank(s), new regulator, not sure if I need new line. The stove did work last fall.
If I get new tanks I would probably just want one, and may want a smaller one, maybe a ten pounder.
I have a nice propane camping stove and about 15 one pound canisters on hand and may be content to use them in the future. Might like to carry a spare or battery on the tongue instead of big tanks.
First order of business though is to get rid of these.
john madill is offline   Reply With Quote
Old 05-09-2014, 06:16 PM   #2
David Tilston's Avatar
The Blue Rhino one can be exchanged at places that do that. I can't tell because of the black plastic cover, but the other tank looks like it as well. The outside thread is the key. If the valve has that, it is good for exchange.
But that regulator looks really old. I think that is your problem. That and the tubing you are connecting to the tank with. You should have rubber propane hoses. Get all that replaced. You should mount the regulator to something as well.
Old 05-09-2014, 06:22 PM   #3
appears the right tank is not connected.
Old 05-09-2014, 06:23 PM   #4
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Since the tank only "hissed" after you opened the valves, I think it likely that David has called it right- the problem is in the connections. It may be something as simple as needing tightening right at the tanks, though. There's nothing special about newer connections- the tank on the right clearly has the older valve on it, but nothing about that design would produce the symptoms you describe. The best way to dispose of propane is to use it. I think once you've established where (if anywhere) leaks are coming from you should correct those defects and do just that.
The right-hand tank is not of course refillable due to its older, now unapproved valve. Your choice in that department is to replace the valve or trade in the tank.
Old 05-09-2014, 06:34 PM   #5
The newer tanks have a Triangular valve handle as on the left Blue Rhino tank. The right tank looks to have the old style rounded valve handle and can not be refilled. At one time Blue Rhino would take those old tanks in on trade and refit them with the new valves but I think they no longer do that. John, you do realize that the older tanks that had a female thread are left hand thread?? I have a 7 lb and a 11 lb tank, (correct name is cylinder) but they are much more expensive than the common 20 pounder, and no one has them for exchange. A Blue Rhino driver gave them to me as they don't want them. To dispose of old tanks I have to pay a fee at my local transfer station (dump), and the tanks have to be empty. If you're not going to use them, give them to someone that has a gas grill.
Old 05-09-2014, 06:38 PM   #6
thanks Dave.....
Just took a closer look. Yes, the tank on the left has the exterior thread. The right tank doesn't have it.
I'll have to visit a nearby rv shop and seeing about getting things updated.
Still not sure what to do with the old unfillable tank.
Old 05-09-2014, 06:45 PM   #7
you good people are so fast....!!!
While I'm responding to Dave I get great responses from Darwin, Bob and Francesca!
thanks to all of you.
Bob, by left hand thread do you mean the old rule "lefty loosey, righty tighty" is reversed?
Old 05-09-2014, 06:52 PM   #8
FTTRV's Avatar
Trailer: tp
You should for safety replace the regulator, the hose from under the trailer to the regulator and the hose from the regulator to the tank.
Chuck
Old 05-09-2014, 07:03 PM   #9
Trailer: 17b Escape
Can those hoses be changed out by a layman or do they need to be replaced by a gas fitter?
J Mac is offline   Reply With Quote
Old 05-09-2014, 07:58 PM   #10
Yes, the tank valve that has internal threads are backwards from the normal "righty tight", so it will be "righty loosey"
Old 05-09-2014, 08:08 PM   #11
The triangular valve handle designates the valve as being the new required OPD valve, or "Overfill Protection Device". Those valves have both the old internal (female) left hand thread and the newer style external right hand thread. I would use up that old tank and then find a way to scrap it.
Old 05-09-2014, 09:08 PM   #12
Both tanks in your pics have the internal threads required for use by your present pigtail connection. The older one without external threads is not refillable. I advise using up the propane in it and disposing of the cylinder. In my opinion and on a cylinder this size, it's more expensive than the bottle's worth to change out the valve.
Here's a heads up:
It's my understanding that those will be accepted in trade at Blue Rhino retailers. Didn't used to be true, and there's a long story behind it. In any case, do take it on down to Home Depot/wherever and give that a try. Best way to get rid of it, in my opinion....and since Blue Rhino bottles no longer have proprietary valves, you'll end up with a (relatively) new, certified, refillable bottle that you can fill up anywhere.
But use up the propane first!
Old 05-09-2014, 09:26 PM   #13
FTTRV's Avatar
Trailer: tp
Propane lines
I could do the work but I am on the left coast so it is to far to go for me. Most anyone with tools can do the job. Test for leaks using soap in a spray bottle.
Chuck
Old 05-09-2014, 10:53 PM   #14
As far as disposal goes we have recycling/transfer station locally where old tanks can be taken - full or empty at no fee. Where they are correctly purged of propane if you haven't been able to for what ever reason use up whats left in it.
Here in Canada when you go to refill a tank they will check the date stamp on the collar if its more than 10 years old they will not fill it.
propane
propane line questions olderishguy Problem Solving | Owners Helping Owners 5 10-05-2013 01:31 PM
Propane heater BTU & Line questions for Uhaul D Davis Problem Solving | Owners Helping Owners 14 09-24-2012 04:28 PM
A few questions ... okay, more like a lot of questions! shelley w Problem Solving | Owners Helping Owners 6 07-04-2012 10:25 PM
Replacement windows, questions, questions. CliveAlive Modifications, Alterations and Updates 4 07-13-2006 07:32 AM
