Propane regulator - Fiberglass RV
Old 09-19-2009, 08:27 PM   #1
Trailer: 1973 Compact Jr
It's time for me to replace the old single-stage propane regulator and hose, both of which are of unknown but significant age.
On my trailer the regulator is mounted on the tank (well, it has the POL fitting that screws directly onto the tank) and there is a rubber hose that connects the output of the regulator to the trailer. This means the rubber hose is carrying only low-pressure gas.
Generally speaking, I like the idea of subjecting rubber hoses to low, not high pressure.
However, I have seen pictures of some modern trailers (e.g. Escape) that have the regulator mounted on the trailer with a rubber hose running from the tank(s) to the regulator. This seems strange to me because it means the rubber hose is carrying the full pressure, which on a hot day can be well over 100psi. What is the advantage of mounting the regulator on the trailer instead of on the tank?
Oh, and the reason I need to understand the advantages of each system before ordering the regulator is that for a tank-mounted regulator a horizontal regulator would work best on my trailer, while for a trailer-mounted regulator, a vertical regulator would be better.
Thanks!
Reason for edit -- correct spelling errors
Dana T is offline   Reply With Quote
Old 09-20-2009, 02:34 PM   #2
Talking
For my Fiber Stream it would be having one regulator between two propane tanks.
Old photo showing tanks with cover removed.
propane
Propane Regulator Greg G. Care and Feeding of Molded Fiberglass Trailers 7 07-14-2010 07:46 AM
Question about propane regulator Bobbie Mayer Problem Solving | Owners Helping Owners 13 02-14-2010 03:29 PM
DUAL PROPANE REGULATOR - For Sale Marv Watson Classified Archives 0 09-15-2009 09:49 AM
Propane regulator Kevin K Problem Solving | Owners Helping Owners 9 04-24-2008 05:08 PM
Propane Regulator Replacement Don Nicodemo Problem Solving | Owners Helping Owners 2 08-06-2006 05:34 PM
