Propane Regulator Replacement - Fiberglass RV
Old 08-04-2006, 07:57 PM   #1
Trailer: 13 ft 1980 Boler
I have a 13 foot 1980 Boler. I had to replace the propane regulator as the old one was leaking. When installing the new regulator I noticed an oily propane smelling liquid coming out of the propane line from the trailer, when reconnecting the line to the regulator. What is this? Is this normal? Any help appreciated. Thank you.
Don Nicodemo is offline   Reply With Quote
Old 08-05-2006, 10:48 PM   #2
Pete Dumbleton's Avatar
There are oils added to gas fuels to impede corrosion in the big tanks -- Sounds like you had some sort of buildup in your system. You might want to disconnect the line at the regulator and blow out the line from insided with compressed air.
You might also want to check out the line at a later date because it's possible the oil is coming from your tank.
If you still have the old regulator, you might want to try taking it apart to see if it is clogged with oil from the tank.
Old 08-06-2006, 05:34 PM   #3
You may want to purge the tank and lines.I had a similiar problem a few years ago. The oily build up was from a bulk delivery truck left over residue.I ended up back flushing with acetone.
DAVID K is offline   Reply With Quote
Propane Regulator Greg G. Care and Feeding of Molded Fiberglass Trailers 7 07-14-2010 07:46 AM
Question about propane regulator Bobbie Mayer Problem Solving | Owners Helping Owners 13 02-14-2010 03:29 PM
Propane regulator Dana T Problem Solving | Owners Helping Owners 1 09-20-2009 02:34 PM
DUAL PROPANE REGULATOR - For Sale Marv Watson Classified Archives 0 09-15-2009 09:49 AM
Propane regulator Kevin K Problem Solving | Owners Helping Owners 9 04-24-2008 05:08 PM
