propane smell? - Fiberglass RV
Old 05-12-2008, 07:08 AM   #1
I had both my tanks refilled but one isnt working.... after the water is in the tank I turned on the left tank.... nada... wont lite the hotwater pilot ight . so I switch over to the right tank... poof.. it lights.... ok..
Now I get whiffs of propane from the tank that doesnt work... smells like its from the regulator and the tank is off?? I guess I may need to replace both regulators and fittings?? i used the soap method when i hooked them back up and saw no bubbles..
the smell is only when the right tank is on...
Old 05-12-2008, 07:43 AM   #2
BobB's Avatar
Regulators don't have an infinite lifespan. If you have concerns, you should have it checked by someone qualified to do so. Propane stuff is not really DIY.
Old 05-12-2008, 08:28 AM   #3
Christi V,
Have you tried swapping the tanks, left for right? The left tank valve may be defective.
Do they both feel about the same weight? The inoperable tank might not have any gas. It's possible the second tank didn't actually get filled, or they grabbed an empty tank from the rack if you exchanged tanks.
Did you use soap on the rubber hoses? Soap the whole system that is accessible, the entire regulator, valves, etc. Don't forget to test with the valves open so the system is pressurized. For example, I once found a leak in the middle of a brand new, 10' piece of gas pipe. That was after replacing all 12 fittings four times, pressurizing the system then watching the gauge slowly drop to zero each time. This was to be enclosed behind drywall, so the leak had to be found!
Suggestion.... besure to rinse well because the soap solution is corrosive over a period of time, rust will form and copper or brass turns green. A spray bottle filled with water helps to rinse under and back-sides of things.
Eventually you will figure it out! In the meantime, I empathize with your frustration.
Kurt & Ann K.
Old 05-12-2008, 08:35 AM   #4
Christi V,
Kurt & Ann K.
I just had the tanks refilled( Only halfway) but the left one is not working as I turned it on and couldnt light the pilot light.... I plan on taking it in and having the fittings replaced and the rubber hoses too...
yes i used soap after i had hooked them back up..no leakes.. it seems to only smell when the right tank is on... i dont want to mess with gas... POOF isnt good....
Old 05-12-2008, 09:03 AM   #5
I may be the burner didn't light immediately because the gas lines were full of air and it took a while to purge it and get gas. By the time you tried the other tank maybe all the air was purged out.
danny m is offline   Reply With Quote
Old 05-18-2008, 12:07 PM   #6
Phil Underwood's Avatar
Trailer: Bigfoot 21ft (25B21RB)
you can do a leak down check with a nanometer
Phil & Denise Underwood
1973 13ft Lovebug
1998 17ftCasita FD
Phil Underwood is offline   Reply With Quote
Old 05-18-2008, 06:50 PM   #7
Pete Dumbleton's Avatar
Make your own manometer:
http://www.rverscorner.com/manometer.html
propane
Smell remover Rands E. Problem Solving | Owners Helping Owners 12 03-04-2022 11:54 AM
A Smell Vicki A. Problem Solving | Owners Helping Owners 4 04-14-2010 07:16 AM
That New Smell Tamid Problem Solving | Owners Helping Owners 3 08-18-2009 08:29 PM
New Trailer Smell Ray N General Chat 9 04-15-2009 08:47 PM
Gas Smell Legacy Posts Problem Solving | Owners Helping Owners 4 07-05-2003 12:26 PM
