Propane tank holder: going from double to single tank - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Problem Solving | Owners Helping Owners
Click Here to Login
Old 07-03-2016, 07:35 PM   #1
Trailer: 1975 Boler
Quebec
I would like to carry only one propane tank around instead of two. My clamp won't work with a single tank, just with two because the threads in the vertical rod don't go low enough to work. I know this is very basic, but how can I go around with just one tank?
Uncle Cereal is offline   Reply With Quote
Old 07-03-2016, 09:11 PM   #2
Amazon sells a couple types of single tank holders. Probably available from RV parts suppliers too. Many smaller campers, like pop-ups, only used one tank.
Old 07-03-2016, 10:12 PM   #3
Could you find some type container to use instead of the second tank? A bucket or storage box might be useful.
Old 07-04-2016, 05:56 AM   #4
Joy A's Avatar
Some years ago I made one out of strapping.
I cut 3 legs and bent them on the bottom as a foot, attaching them to the tongue with bolts. I took another piece of strapping and wrapped it around the tank to get it mould it round and then attached it to the top of the
legs. I had at least 2 to 3 inch excess on the band which was used with a bolt and wing nut to tighten and snug the propane tank in it's "new holder"
I liked this type of holder because all I had to do was loosening the wing nut and lift the tank out. Since it was so easy to remove I added a chain and a couple of locks so the tank couldn't walk off.
Joy A. & Olive
and "Puff", too
Fulltime
2019 Ram Longhorn
Old 07-04-2016, 06:03 AM   #5
Joy A's Avatar
I forgot to mention that the nuts holdiing the band to the legs are on the inside and covered with little blocks made of plastic. Those blocks are what butt up to the tank, so nothing metal hits the tank.
Joy A. & Olive
and "Puff", too
Fulltime
2019 Ram Longhorn
Old 07-04-2016, 10:02 AM   #6
Trailer: 1975 Boler
Quebec
Great ideas! Thanks!
Old 07-04-2016, 03:18 PM   #7
Gilda's Avatar
Trailer: 2011 Scamp 13'
You could search "One Propane Tank" on the "Search" button above on this website. Drop down to "Search Site/Google" and you will find other answers to similar questions.
The Gleeful Glamper
Gilda (Jill-da)
Old 07-05-2016, 06:33 AM   #8
Kevin K's Avatar
Trailer: 1983 13 ft Scamp
2 bars on my tank like photo.
Old 07-05-2016, 06:37 AM   #9
Trailer: 1975 Boler
Quebec
Kevin, you bought those braces or you made them?
Old 07-05-2016, 08:16 AM   #10
kdhanso's Avatar
Scamp sells the straps
http://www.scamptrailers.com/parts-s...ap-detail.html
Ken
Ken
kdhanso is offline   Reply With Quote
Old 07-05-2016, 11:34 AM   #11
Kevin K's Avatar
The guy I bought the trailer from changed over from 2 tanks to 1.
You don't need 2 tanks.
Also cuts down on some weight.
Old 07-05-2016, 02:07 PM   #12
I went down to one 11 lb tank on our Casita. Converted hot water heater to electric and we haven't used the stove or furnace in 7 months of camping.
Old 07-06-2016, 02:46 PM   #13
I made some hold downs and used some turnbuckles from Lowe's to tighten them .
Straps like the top of what is pictured above and attached to the angle below.
Sent from my SCH-I605 using Fiberglass RV mobile app
propane
mounting a single propane tank gillian s Problem Solving | Owners Helping Owners 7 07-25-2013 12:16 PM
Single propane tank covers DavidSo Modifications, Alterations and Updates 29 02-24-2012 08:31 PM
Single propane tank holder Kevin M Problem Solving | Owners Helping Owners 4 06-28-2009 01:17 PM
Where do I get a propane tank holder for trailer? Bobbie Mayer Problem Solving | Owners Helping Owners 15 06-04-2007 06:28 AM
about single to double LP tank conversion Legacy Posts Problem Solving | Owners Helping Owners 5 03-31-2003 07:16 PM
