Proper adjustment to sway bar - Fiberglass RV
Old 08-23-2006, 02:49 PM   #1
Trailer: X-treme Lite 160
I recently purchase a used Olympian sway control bar. I was not lucky enough to also get the installation instructions. What is the best way to set the proper friction for best control? I don't want to start out to tight but yet I do want the bar to be tight enough to work. Also, has anyone every used a Weight Distribution Hitch on a Toyota Highlander before?
Thanks,
Gary Little
Gary Little is offline   Reply With Quote
Old 08-23-2006, 04:52 PM   #2
Trailer: Fiber Stream
Talking
I just pull mine as tight as I can without straining, until it stops. I check that I can loosen it by hand without having to resort to a wrench. I have never measured foot-pounds of whatever...
Old 08-23-2006, 07:25 PM   #3
Bill MacDermod's Avatar
Trailer: 1999 17 ft Casita Spirit Deluxe ('Inn EggsIsle')
We had a trailer hitch installer at Rock Crusher this year that said to snug it up then 1/4 of a turn
Love being Inneggsile
heading sloowly up the eastcoast to our next 2 month (Aug and Sept) camp hosting gig at Camden Hills State Park in Maine
Bill MacDermod is offline   Reply With Quote
Old 08-23-2006, 07:51 PM   #4
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van and 1996 Precision 21' Sailboat
Iowa
The friction on the sway control bar is set using the bolt at the bottom. The handle at the top is used merely to employ the friction. The bolt and a wrench are used to increase the amount of friction as necessary. When the handle is tighted, you shouldn't be able to move the bar manually. It will, however, provide adequate friction for sway control. Tighten or loosen the bolt with a wrench for more or less control.
As far as using WDH with a Highlander, your car is a unibody. Unibodies are designed to accept stress in specific directions. Unless Toyota specifically designed the unibody of the Highlander to accept the stresses of a WDH setup, there is the potential of causing the unibody to buckle under stress. I'd contact Toyota to find out what their assessment is.
Roger
Old 08-24-2006, 07:08 PM   #5
Roger
Thanks Roger,
I will set up the sway control bar as you mentioned. That is great info on the WDH also. I did find in my owners manaul that Toyota does not recommend using a WDH. I'm sure it is because of the Unibody construction as you said.
Thanks again,
Gary Little
Old 08-24-2006, 11:08 PM   #6
Pete Dumbleton's Avatar
Here's a link to a PDF by Draw-Tite on friction sway bar installation and use:
http://p.hostingprod.com/@drawtite.com/N34...structions'
Here's a quote from that PDF:
QUOTE
4. When towing during slippery conditions such as wet, icy, or snow-covered roads or on loose gravel, turn
on/off handle (5) counterclockwise until all tension is removed from unit. Failure to do so could prevent tow
vehicle and trailer from turning properly.
END QUOTE
Do you get a proper response Chester Taje General Chat 8 12-15-2006 05:07 PM
Brake Adjustment Legacy Posts Towing, Hitching, Axles and Running Gear 7 08-19-2003 03:19 PM
fridge adjustment? Legacy Posts Problem Solving | Owners Helping Owners 6 07-19-2003 02:51 PM
The importance of proper weight distribution Legacy Posts Jokes, Stories & Tall Tales 6 03-21-2003 06:48 AM
» Trailer Showcase
Boler
ralphy
Cafe Egg
Gerda, H
